Question about HP Photosmart C3180 All-In-One InkJet Printer
Photocopying problem in All-in-one Hp printer
Dear Sir,
I was someway around to find the correct solution for the case given by artgeek101, but not sure to much. Here is the link for the problem:
Artgeek 101 problem
any help and comments on the answer given by me will be appreciated..
Regards
Ellin
  • Puneet Jain
    Puneet Jain Oct 15, 2008
    Thanks for your help buddy.
  • Felix Lopez
    Felix Lopez May 11, 2010
    Although HP is not in my area of expertise, It looks to me that the unit has a bad scanner unit. Does he get the same results when copying in color? Tell him to do a copy test with the lid open; a black page should come out. This is a great waste of ink but will serve like a radiology test that will reveal what the scanner unit actually sees.
  • HP Master
  • 1,879 Answers
Have him check for density, brightness, contrast. if that doesn't work, scanner gone bad
Posted on Oct 15, 2008
How do i increase photocopying/printing speed of hp deskjet 1510?
1. Reduce the scan resolution.
2. Scan in black/white or greyscale rather than color.
Sep 12, 2014 | Office Equipment & Supplies
Turning silent mode
Sir/Madam
Please Go To Official HP Printer Trobulshootpase Link Given Below And Perfom The Step Mention On The Website,http://h10025.www1.hp.com/ewfrf/wc/document?cc=uk&lc=en&docname=buu01831
I Hope You Resove Your HP Printer problems,In Case You Still Having Problems Then Follow Us On
HP Printer Support
Jan 16, 2014 | HP OfficeJet Office Equipment & Supplies
Print quality problems
Sir/Madam
I Suggest You Visit Below Link And Follow The step Written For HP Printer,I m Sure You Fix Your Hp Printer Problem,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01177917&lc=en&cc=uk&dlc=en
In Case You Still Having HP Printer Problems Hen Follow Us For
HP Printer Support
Jan 16, 2014 | HP Office Equipment & Supplies
My hp 5200 printer prints extra sets of multi page documents when only 1 copy has been selected for output. Is this a printer setting that I can change? Is there someway to reset to its default settings?
Here ya go sir, this is a cold reset option and it will reset all back to factory defaults so if there are setting you want back, you may want to print out a config report prior to resetting...
1. Turn the printer off.
2. Turn the printer on. When the printer begins its memory count, press and hold down until all
three printer control-panel lights flash once and then remain on. This might take up to 10 seconds.
3. Release .
4. After SELECT LANGUAGE appears on the control-panel display, press or until COLD
RESET
is highlighted.
5. Press . The printer performs a cold reset and then continues its power-on sequence.
6. Check all I/O settings and reset any customer-set printer configuration values.
hope this helps and if so please mark this as a fixya for me sir...
Jul 02, 2010 | HP LaserJet 5200 Printer
Scanner function does not appear to work. All
i would say possibly you are missing out on something..because if the other functions particularly photocopying are working then this should work..as in if the photocopying function works then the scanner is ok cause basically in photocopying the machine scans then prints... perhaps check whether you are correctly following procedure to scan..most hp all in ones have a button on them that you press and it automatically initiates scanning and simultaneously the software on the pc is initiated..try this,if not then try reinstalling the hp software..hope this helps..regards
Jun 04, 2010 | HP Photosmart 2575 All-In-One Printer,...
I have use the HP Deskjet D1360 series printer paper jam
Simple and slowly remove the jamm'ed paper. Please be sure to inspect the system in detail (you may need tweezers) for any small pieces of random paper laying around.
After this you should be set please let us know if this issue persists as this would be a sign of other issues.
Thanks
Frank
Live-Tech
1-888-361-8511
May 24, 2010 | Office Equipment & Supplies
Lines rule across my print out paper at photocopying mode
Make sure you don't have a scratch on the glass of the scanner. If you have a mark, or scratch that matches the line ruled on your print, then there is your problem.
It;s also possible the scanner is jerking as it goes across the bed, which is causing the line. Is the line solid, dashed, bold, thin or just kinda there?
Mar 14, 2009 | HP DeskJet F380 All-In-One Printer
Hello Sir i have a problem with hp deskjaet printer. .when print command is given the characters are not printed correctly.
  1. In the printer under Print Quality and Manual Settings, change the Graphics Mode setting from Auto to HP-GL/2.
  2. Use the Enhanced (PCL XL) driver.
Jan 14, 2009 | HP DeskJet 1280 InkJet Printer
Photocopy problem
try to check the flatbed area there's a small parts that will missing.
Feb 15, 2008 | HP LaserJet 3030 All-In-One Printer
Hp 1317 psc
you didn't describe your problem briefly. 1. Check if you photocopy anything, it is coming out correctly you are doing. it means your scanner is perfectly allright. 2. if you are not able to photocopy with this printer, it means your scanner is not working properly. But if it photocopying properly and in windows it is not scanning it means software is not working properly, try to arrange new software from anywhere and try.
Sep 24, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
