Question about Dell Inspiron XPS Gaming Mouse Pad KU170
Dell XPS 1 keyboard characters not wrking
Hi i am using an on screen keyboard.
all of a sudden the characters aren't working right.
i cant press any characters.
i had this comp. and keyboard for like one month.
sum1 help PLZ!!!!!!
  • jac312 Oct 20, 2008
    my keyboard has the same problem. the xps keyboard... really is bad. the media keys on the right side and i have tested out that the fn sleep works. whats bothering me is that nothing else works. very discouraging.
5 Suggested Answers
  • 998 Answers
SOURCE: XPS One Keyboard's Characters not functioning
Try to re-sync the keyboard to the computer. Here’s the procedure:
1) Turn the computer on.
2) Turn on the keyboard
3) Press the sync button on the rear of your computer’s left speaker.
4) Press the sync button on the keyboard. ( I believe it’s on the bottom of keyboard)
The sync button has a symbol next to it, (2 arrows going in clockwise direction).
Ensure that the keyboard battery has not run low.
If that doesn’t work, look for a Bluetooth icon in the lower right hand corner of your desktop and double click on it to open the Bluetooth configuration utility. See if there’s a configuration file for the keyboard. If there is, delete it and then re-detect Bluetooth devices.
Hope this helps.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Posted on Oct 20, 2008
MPetro302
  • 298 Answers
SOURCE: Dell Wireless KeyBoard Not working
you can download the software & drivers from Dell.com find the drivers or support section and enter the model number.
Posted on Apr 17, 2009
  • 15 Answers
SOURCE: key pad doe not work
This means the number lock is on - in the upper right hand corner of the keyboard is a series of 4 keys.  Far right is delete, then (from the right) insert, Prnt Scrn, and Num Lk.  Hit the Num Lk key, and the number 9 with the padlock should shut off.  Your keyboard should now work normally.
Any more problems, let me know!
Posted on May 26, 2009
  • 40 Answers
SOURCE: my dell xps one keybooard is not working
first, uninstall it completely. Change your batteries. Turn off your computer. Boot up, log on as administrator. Install the software for the keyboard, now plug it in and the add new hardware wizard should see it. If that doesn't work take it back to the place of purchase for an exchange. It is a hardware issue at that point.
Posted on Jun 28, 2009
  • 4 Answers
SOURCE: Laptop keyboard will sometimes type the wrong characters
Try doing this::
1) You might be infected with a malicious software. Download this tool from microsoft and scan your harddrive.http://www.microsoft.com/downloads/info.aspx?na=90&p=&SrcDisplayLang=en&SrcCategoryId=&SrcFamilyId=ad724ae0-e72d-4f54-9ab3-75b8eb148356&u=http%3a%2f%2fdownload.microsoft.com%2fdownload%2f4%2fA%2fA%2f4AA524C6-239D-47FF-860B-5B397199CBF8%2fwindows-kb890830-v2.11.exe
Hope it helps
2) Use flea power: Power down your PC and remove the battery, press the power button for atleat 5seconds, fix your battery back. and switch on
Posted on Jul 06, 2009
I have a dell xps that came with a wireless/bluetooth keyboard with mouse pad and i have another dell xps 420 that i'd like to use the wireless keyboard on...they are both dell xps's and both
Wireless/Bluetooth keyboards and mice can only be used with one device at a time it is like a bluetooth headset once it is paired with a phone it will 99.99% of the time only work with that phone and that phone only, Wireless keyboards and mice are setup on the same principal once they are paired up with 1 PC to use on another PC you have to remove the pairing. The worst case scenario is that the second PC's Wireless/Bluetooth has failed. I hope this helps.
Sep 03, 2012 | Dell XPS 420 PC Desktop
Dell labtop mother board many characters not working
You must be talking about the keyboard not the motherboard. If allot of keys and characters not working you might have to have the keyboard replaced.
Feb 25, 2011 | Dell XPS M1330 Laptop
Hi. my laptop keyboard on my studio xps 1640 has suddenly stopped working. no backlight and no reaction to any of the key inputs whatsoever. any ideas to what it might be?
There is not so much that could be done to repair a keyboard. Disassemble the laptop, check the ribbon cable connecting the keyboard to the motherboard. If the ribbon cable is loose, tighten it. If it is tight, replace the keyboard with a new one.
Oct 08, 2010 | Dell Studio XPS 16 Notebook
Keyboard not registerin any character
Remove the battery of the keyboard if it is not working and install new one and then press connect button from the keyboard side and the receiver side also. connect button is in back side of the keyboard.
Nov 27, 2009 | Computers & Internet
I have a Dell XPS M1710 laptop. The touch pad does not work.
Unless it is a hardware fault open the control panel>system>mice and uninstall the touchpad. Then rebott. It should solve the problem.
Jul 23, 2009 | Dell F3534 Touchpad
ALT Codes
I'm a little late to the game, but...
I share James's frustration. Seems like a dumb thing for Dell to economize on. Here's my workaround, for what it's worth.
  1. Open the Windows on-screen keyboard (osk.exe). And, for later ease of use, pin it to your taskbar. (Detailed instructions: click on the Windows start button, type osk.exe in the search box, right-click on the program, select Pin to Taskbar.)
  2. On the virtual keyboard, open Options and select "Turn on the numeric keypad." After saving the setting, press the NumLock button.
  3. Here's the tricky bit: press and hold Alt on your physical keyboard, and then press and hold Fn, again on your physical keyboard. You're holding them both down, right? Keep doing it. Now enter your four-digit code on the virtual (on-screen) keyboard. Release the physical keys. You should have your special character.
Hope it works for you.
Jan 21, 2009 | Dell Inspiron Mini 9 Notebook
Hope this helps.
Thank You.
Oct 20, 2008 | Dell Inspiron XPS Gaming Mouse Pad KU170
Vertical lines in my laptop screen
the lcd (liquid crystal display) is damaged at this time, nor the inverter, that is of course inside of your pc, im afraid you need to send this to a repair shop
cheers
Aug 12, 2008 | Dell Inspiron XPS M140 Notebook
Dell Inspiron XPS Gaming Mouse Pad KU170 Logo
364 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
