Question about Apple MacBook Pro PC Notebook
Macbook - screen white/blank after turning on
I was working on my macbook and it bogged down with the spinning wheel staying on and not doing anything so I shut down the computer by holding down the start button. When I turned it back on only the white/blank screen came on with no apple logo and it won't go any further. I can here computer noise and the fan comes on. Any ideas?
  • chikonahoka Jan 26, 2009
    i got the same problem. i had Safari and Numbers open. the safari seemed to hang, with the spinning wheel going on, so i quit Numbers, thinking it would help. They both stalled, so i tried to get to Finder to force quit, but surprised when i couldn't. so i turned it off using the power button. but i cannot get back on - the screen is blank white, the start up sound is there, but it goes no further. i don't want to lose my files!
  • 9 Answers
Sounds like it could be a corrupted OS; have you tried forcing it to start up with the OS disk, holding down the 'C' key? That's the first place to start...
If it won't start up like that, you probably have a hardware problem. (You can get excellent troubleshooting guidance at: http://www.ifixit.com/Guide/Mac/ ) depending on your level of geekness, and assuming the warranty is expired?
Good luck
dennismacfreak
Posted on Nov 17, 2008
  • 846 Answers
If you've deleted your nvram and you're still getting a white screen and it doesn't even try to boot, i would assume there is an issue with your logic board. If you're out of warranty, somebody has to openthe Macbook screen and replace the part. The part is available onebay. Here's aguide on how to disassemble a Macbook. Maybe a tech savy friend can do it for you. If you want to pay to have somebody do it for you there are third party Macbook Repair Services.
Posted on Jul 26, 2010
    New Friend:
I have a problem with my macbook. When I hold option and start in the same time it just show me recover HD. Please I need a help what should I do next.
Posted on Jan 18, 2014
4 Suggested Answers
SOURCE: When I turn my MacBook air on a blank White screen
Leave the Macbook air turned on until the battery goes dead. Then Connect to power and start it up. That should solve the problem. You problem was caused by not letting an update install in full.
Posted on Aug 01, 2010
TechStuff
  • 11 Answers
SOURCE: Turning on my macbook- all i see is white screen and 'no' sign
Apple has a troubleshooting document about this here: http://support.apple.com/kb/TS1892
Normal procedure is to reset the NVRAM and PRAM then "remind" your Mac where to find the system folder. (This problem sometimes happens when the system folder is moved, renamed or deleted.)
It may be necessary to reinstall the operating system. (Fortunately, if you use the "archive and install" option, you can do this without erasing the hard drive or losing your user data.)
Posted on Nov 19, 2008
  • 20 Answers
SOURCE: MacBook won't start up.
If you have your Mac OS X Install disc, insert it into the drive.
Restart the computer and hold down "C" while booting.
Choose your language.
Select "Disk Utility" from the "Utilities" in the menu bar.
Select your Macbook's hard drive in the left sidebar.
Click the "First Aid" tab thats along the top of the viewer window.
Click "Verify Disk" (not verify disk permissions)
If this shows errors click "Repair Disk"
Once completed close the Disk Utility window.
Restart the computer.
If this fails to fix it as well then your next option would most likely be recovering your files from the macbook either by booting into target disk mode (hold down T at startup) and transferring them via a firewire cable, or removing the hard drive and hooking it up to another Mac to get the files. Then do a clean install of Mac OS X using your installation discs.
Posted on Feb 15, 2010
Why macbook not turn off blank screen
If the Apple laptop (or desktop) doesn't shut down properly, try pressing and holding in the power button for 3-5 seconds. This will force a shut down. Good idea to wait a few minutes before attempting a restart again.
Aug 30, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
There is a spinning wheel on the screen and I can't shutdown or dO anything
the spinning wheel indicates that the computer is trying to either read or write to the hard drive.
It might be an indication that your hard drive is starting to fail. Backup if you can.
Try booting from the Mac OS install disc. insert the disc and restart while holding down the "D" key on the keyboard. If everything boots OK and doesn't act "weird", your hard drive is failing.
Dec 25, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Our MacBook doesn't do anything but stay on a white screen that just shows that apple going around in circles in the middle of the screen.
You got the rainbow spinning wheel of death, which means take out the RAM chips and re-insert. Now try. Nothing? Replace the RAM chips with RAM chips you know are working. Now try-Nothing? Install disc one of the install disc Apple gives you and go into the system utilities and repair disc permissions and also click on repair disc after that. Now try-Nothing? Replace the hard drive and re-install the OS. Now try-Nothing? Your fu.kd my friend, which means you got a logic board problem.
Sep 04, 2010 | Apple MacBook Mac Notebook
Won't turn on
The problem in blank white screen is the display (LCD). Send it to a technician for repair. The blinking folder with a question mark is conflict on drivers. Have you installed a software lately? If you do please uninstall it. Maybe that is the cause of having a blank white screen.
Jul 12, 2010 | Apple MacBook Pro PC Notebook
When the computer turns on theres just a blank white screen
Also, try holding down the power button until you hear a beep.
May 18, 2010 | Apple MacBook Mac Notebook
Feb 15, 2010 | Apple MacBook White- 2.1GHz Intel Core 2...
Dec 16, 2009 | Apple MacBook Air
Macbook won't start!
that normally happend when the macbook do not find the software you can read this apple post http://support.apple.com/kb/TS1440
Jun 24, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Monitor non functional
Am I correct in understanding that your MacBook is operating properly, but when you attach your external monitor it doesn't show anything?
I often connect my black MacBook 2GHz to my flat screen's VGA port. Sometime the screen doesn't respond for one reason or another. The fastest solution is typically to mirror the screens then return to normal. When that doesn't work, it's usually enough to restart the MacBook while it's still plugged in to the external monitor. If neither of those work, try connecting to a different monitor or finally try replacing the connector.
Unfortunately those connectors don't have the best life spans. (See Apple's customer reviews on DVI connectors.)
iKnow Apple Dan (919) 280-3101
Aug 02, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Macbook - BLANK SCREEN!
Itunes is very tricky and its freezes computers very badly.try to take out battery and than turn on computer slowly,Soon if you can you need to reinstall itunes maybe to start to work better.
Jun 04, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple MacBook Pro PC Notebook Logo
5,767 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
