Question about HP Computers & Internet
My web cam has stopped working and is not recognized by software.
  • Paul Hansen Oct 05, 2008
    It worked! Thank you very much! I actually did it through the device manager because I couldn't find it in the control panel list of programs...or I didn't recognize it...whatever. Anyway, after I unistalled the program through the device manager, I turned off the computer. When I powered up again, the software automatically was installed.
  • 749 Answers
Un-install the software through the control panels' "add/remove software " utility.....Re-install the software
Posted on Oct 05, 2008
What should i do to enable my web camera?
Go to device manager an ensure that the drive is installed and that the device is being recognized.
If the device is recognized install a compatible web cam software that will allow you to utilize the web cam.
Nov 28, 2015 | Computers & Internet
How can i install a usb web camera
If the web camera came with an installation disk, use the disk to install drivers then plug the web camera in a USB port. The computer should recognize it. If it is properly recognized it will work with all applications that support a webcam (Skype, MSN, Google chat..) If it is not recognized and you do not have an installation software, you should go to the manufacturers web site to download appropriate drivers.
Apr 21, 2011 | Computers & Internet
I have a Dell 530 S Dell Inspiron. Its Webcam has stopped working. Any solutions
The very first step is of course to check your web cam connection. Most web cams use the USB port to connect to the PC, so check if your USB cable is properly plugged. For build-in web cams this steps does of course not apply. Many new laptops have a build-in web cam. Also try connecting your web cam directly to your PC instead of through a USB hub (if you are using one).
The next thing is to do is to check your Windows Device Manager and see if the hardware is recognized and installed properly.
It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem.
Other devices in Windows XP device manager
If the device is not recognized in Windows XP, Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers.
In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer.
After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.If your problem is not fixed then you have to buy a new one.
Hope the above information will be helpful to you.
Thanks.
Oct 08, 2010 | Dell Inspiron 530 Desktop Computer
I have problems with my hp web camara it freeze it a lot on messanger any help
If your web camera freezes check your Windows Device Manager and see if the hardware is recognized and installed properly. It might be that the hardware is recognized as a camera, but the right drivers are not installed. The yellow explanation mark will indicate a problem. If the device is not recognized in Windows XP, it will be listed under Other Devices
In either case you can try to update the drivers. Right-click the device, and in the pop up menu select Update Driver Software. Then follow the instructions on screen, but make sure you allow Windows to search the web for updated drivers. In case no driver for the web cam can be found, you can try a third party driver finding program that scans your PC for installed hardware and allows you to install missing drivers.
If this fails, the next step would be to un install the software that came with your web cam. Use the Add or Remove Programs feature in the Control Panel. If that does not work you can use a third party un installer. After un installing the software, restart your PC and then reinstall the web cam software. In most cases this will solve the problems. Depending on the software, you might need to unplug your web cam during the software installation.
If the drivers and web cam software are correctly installed, and you still it freezes, there can be a problem with the program settings. Most chat and meeting software have a configuration option to select the video source for the web cam feature. If you have multiple devices that qualify for video, you might need to select your web cam device as the source for the web cam feature in that program. Some web cams and programs require additional software, although that should be installed with the web cam if things are right. But is does not harm to check if your Java, Flash and Quick time software are installed and up to date. But certainly check your DirectX software, since all video applications, including web cams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c – Windows Vista: DirectX 10).
Thank you !!
May 30, 2010 | HP EW192AA Webcam
Windows 7 does not recognize the Web Cam
instal Picasa 3, it recognizes all web cam without any driver
Nov 05, 2009 | Creative Labs Live! Cam Notebook Pro...
My web cam is not working
Try installing your software again with the camera unplugged then attach the cam and see if it is recognized. If it will not, go into Add/Remove software in control panel and remove the cams program and try reinstalling. If you plug the cam in and get no response saying you have a new device your cam may need to be replaced.
Sep 30, 2009 | QPS QSIPBL2 Network Camera
My web cam does not work when I go to youcam it doesnt recognize or the camera doesnt work. But online the notice I have a camer but it doesnt work
Did you have software installed to use the WebCam? You need software to run the WebCam. Install the web cam software in your PC. Look in your program folder to locate webcam software. Then you access the web cam through this software. Your problem must be solved.
Thanks
Apr 12, 2009 | Computers & Internet
Web cam driver software
send me a more infomation about the your web cam driver
1.send the product make name
2.model no
Mar 24, 2009 | Computers & Internet
Unable to install intex webcam
1. Go to: http://www.intextechnologies.com/webpages/download-driver.aspx
2. Under the "Download Drivers" section, click "PC Web Cam".
3. Click "Night Vision 500K (IT-305WC)"
4. Click "Win XP/Vista". This will start the download of your web cam's drivers.
Dec 24, 2008 | Ezonics EZCam III Webcam
Vupoint FS-C1-VP scanner installed
i have vista home and mine worked fine until i installed a web cam and then it just gave up. But now it works great - here is what i did
unpluged both the scanner and the web cam
uninstalled everything to to w/ the scanner and the web cam.
Installed the driver from the CD and restarted my machine
Install the Photo 6 software
plug in the scanner - works like a champ.
have not reinstalled the web cam
Oct 02, 2008 | Office Equipment & Supplies
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
