Question about Home
Cold water suply filling up header tank in loft thru hot water suply on shower.
Have just installed a new power shower with shower pump, A trevi 45 twin pump. Now have this problem with the cold water suply filling up the header tank in the loft thru the hot water suply pushing all the hot water thru the tank into the header tank in the loft out the over flow into the road. This only hapens when the shower is not switched on. Can you help please is it the pump or the mixer tap on the shower at fault.
  • Anonymous Mar 14, 2014
    Shower mixer knob turns back towards cold by itself.
  • Anonymous Mar 22, 2014
    Shower runs cold, no hot water coming through although tanks and taps give hot in same and other rooms?
    Scholar:
  • 44 Answers
Hi did you run a seperate cold water supply from the storage tank to the shower pump & also a seperate hot supply from the hot water cylinder, it sounds as though the cold water is crossing into the hot service & pushing its way up to the tank as its the only way it can go, sounds as though the cold water connection to the shower is not tank fed & possibly directly off the water main.?
Posted on Dec 15, 2008
I have a combination hot water tank with thermostate, with the cold water header tank attached. If i place this in the loft will i be able to run a shower off of it.
Posted on Oct 12, 2009
We added anti freeze into our water hold tank. There is a pink film on the bottom of the tank. How do we clean the film out of the tank?
problem is there is an RV for your system. you will need to do the following.
Drain all holding tanks, fresh water and sewage
  1. Attach garden hose to fresh water fill and fill tank.
  2. Turn on pump switch and open cold water side of all faucet/ shower fixtures. Leave open until water runs clear. Repeat for hot water side.
  3. Flush toilet until clear water runs into bowl.
  4. Dump tanks again.
  5. Sanitize water system. use a water sanitizer
  6. If a water filter is installed, drain lines, remove filter assembly, clean and reinstall with new filter.
  7. When ready to use the water heater, turn by-pass valve to open position to allow water to enter and fill the hot water heater tank.
May 10, 2017 | RVs
Why do we need to have to continuously adjust the temperature of the water when we're taking a shower. We have a new Rheem gas .hot water tank
It *may* not be a problem with the water heater itself necessarily. When you say "keep adjusting the water temperature when you're taking a shower" I presume you're talking about turning the shower hot/cold knob(s) and not the temp thermostat on the water heater itself.
If so, when it starts to run colder, turn the knob all the way to full hot. Is the water then very hot? If so, the water heater is working fine & doing its job, and the problem is likely to be in the shower faucet mixing valve itself. Sometimes a faulty one will expand the inner seals/cartridge as hot water flows thru it, and starts to (wrongly) restrict the hot water flow, thus causing the constant need to "turn the dial up a notch".
Oct 29, 2014 | Rheem Water Heaters
Grohe mixer will only start the pump on cold. Is the unit faulty.
Ive written a solution twice but for some reason it wont let me post it.I will try to abbreviate it.
You dont say how much flow it has when the pump isnt running but I suspect there isnt enough to turn on the sensor unless all the flow is one side. ie all cold.
May 06, 2012 | Grohe Plumbing
Installation manual for oak tree stove
No idea here this is not a car question and iam not a plumber but i did have a emersion heater years ago and the cold feed from a header tank in the loft went into the heater and their was two feeds one from the tank and one direct from the mains with a special non return valve in the main line feed --why it didnt just fill from the header tank i have no idea but from that i would say the feed for your heater would be much the same with a header tank in case the inlet supply froze up ? Sorry iam a car mechanic so i have no idea but the return inlet pipe would be my logical choice
Dec 21, 2011 | Cars & Trucks
Low water pressure
When it was installed was there any copper sweating done? If so, the valve cartridge can get fried if not removed prior to the immense heat from a torch.
Jan 23, 2010 | Moen Posi-Temp Single HandleTub And Shower...
I am putting in a new shower and want to put in a pump to increase the flow of water to the shower head,what pump do I need? I will put it next to the hot water cylinder in the airing cupboard,I also want...
First of all, the normal water pressure is anywhere from 50 to 70 lbs. Why do you need a pump? What you need is just water pressure. The shower head will only put out a fraction of that pressure with the valve body inside the head. Since you do not say what water pressure you have, check all the pressure lines to make sure there is no blockage. As for the water tank, well, 50 gallons is always better.
Dec 01, 2009 | Cars & Trucks
Whirlpool Energy Smart water heater not hot
I think some one mis informed you, the normal temp on any water heater from the factory is 120, it should not go above that for reasons of sevear burns, as far as it't smart part it's just a name, you will lose a couple of degrees just comming torm the tank to the faucets, the water heater will allways keep the temp in the tank at what ever it is set at, it doesn't have the brains or computer to know what time of day it is but when the cold water comes in to the tank it comes thru a dip tube that goes to aprox 1 inch from the bottom of the tank, if you take a long shower and do not have a energy efficant shower head you can use up to 5 gals, per min of hot water where an energy efficant one only uses 2.5 or less and still has the same pressure at the shower head, the temp in your water heater tries to stay at the setting it is at depending on how much is used at one time meaning washing machine, filling tub or dishwasher at the same time, it lets more cold in as the hot goes out and as you know it can only heat up so much at a time and the cold water is just going across the bottom of the tank, so the name is just that no diffrent then any other water heater unless you went to a tankless water heater.
May 29, 2009 | Water Heaters
WATER HEATER ELEMENT IS NOT WORKING NEED TO REPLACE IT.
is there one or two,, turn off power drain it down, use the water heater element wrench remove the wires and the element, install new element snug it tight, start filling the water heater while it is filling reinstall the wires, turn on a hot side faucet only let the air out, wait till you have a full flow of water out of the faucet then turn the power back on to the unit, the thermostat should beat 120 degrees,
Feb 21, 2009 | Select Brands 20012 500°F Heating...
Home Logo
1,049 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
