Missing dll file
When i boot up my PC i get warnings for a system32.mlang.dll file. it wont let me do a system restore or anything to fix it. is there a way i can fix this without buying another windows xp disc? i cant get it on the net because it wont let me get online either. thanks in advance
    Novelist:
  • 124 Answers
Hi shecter2003, if you can get inside of windows, try doing this:
1. Click Start > run > cmd
2. A black box should show, type there sfc /scannow then press Enter
That should fix and scan all of your system files & it should fix most dll file errors. Check this out for reference.
Hope this helps.
Posted on Oct 05, 2008
Says windows root>\system32\hal.dll. is missing or corrupt, can't use laptop Please advise, regards Jason
some system on your windows has corrupted, it caused by a virus or bad disk
you need to restore your system to fix this issue
if your laptop build in windows xp and you have a restore disk just follow these steps
1. turn on your notebook
2.quickly press ctr and f11 simultaneously
3. click restore when "Dell PC restore" message appears
4.click confirm (it means you will lost all data in drive which contains your old operation system)
5.wait and click finish when the process of restore finish
if your laptop build in windows vista you can follow these steps
1. turn on your laptop
2. quickly press f8
3. when "Advance Boot Menu" message appears just click repair
4. select language and click next
5. log in and click ok
6. click dell factory restore and click next
7. click yes on the box "format hard drive and restore the system"
8. when the process finish click finish
if you don't have a restore disk build in your laptop you need a windows cd installer to reinstall your os
Jun 06, 2011 | Dell Inspiron 6000 Notebook
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Tip
Add Remove Programs list is blank -- Windows 2000
Usually It happens due to some virus activity or any corruption in system files. So when you go to Add Remove Programmes, It shows nothing but a blank space.
· To resolve this issue with Internet Explorer 6.0 installed, repair Internet Explorer 6.0:
Click Start, and then click Run.
Paste the following command in the Open box, and then click OK:
rundll32 setupwbv.dll,IE6Maintenance "C:\Program Files\Internet Explorer\Setup\SETUP.EXE" /g "C:\WINDOWS\IE Uninstall Log.Txt"
Because this command is case sensitive, you should copy the command, and then paste the command in the Open box.
· To resolve this issue with Internet Explorer 5.0 or 5.5 installed, repair Internet Explorer 5.0 or 5.5:
rundll32 setupwbv.dll,IE5Maintenance "C:\Program Files\Internet Explorer\Setup\SETUP.EXE" /g "C:\WINDOWS\IE Uninstall Log.Txt"
If the Add/Remove Programs tool still does not function properly, shows no content, or if you want to try to fix this issue without upgrading to later versions of Internet Explorer, check the following registry keys to make sure that they contain entries:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\App Management\ARPCache
Note If the previous registry keys are blank, the Add/Remove Programs tool may also be blank.
Use the command line REGSVR32 [path\filename] to register each of the following files:
%systemroot%\System32\Appwiz.cpl
%systemroot%\System32\Mshtml.dll
%systemroot%\System32\Jscript.dll
%systemroot%\System32\Msi.dll
Program Files\Common Files\System\Ole DB\Oledb32.dll
Program Files\Common Files\System\Ado\Msado15.dll
%systemroot%\System32\Msdart32.dll [not registerable]
%systemroot%\System32\Mshtmled.dll
%systemroot%\System32\Mswstr10.dll [not registerable]
If the Add/Remove Programs tool displays incomplete information or is blank, verify the file dates. Where possible, register the following files:
%systemroot%\System32\Gdi32.dll [not registerable]
%systemroot%\System32\User32.dll [not registerable]
%systemroot%\System32\Msvcrt.dll [not registerable]
%systemroot%\System32\Ole32.dll
%systemroot%\System32\Shlwapi.dll [not registerable]
%systemroot%\System32\Imm32.dll [not registerable]
%systemroot%\System32\Indicdll.dll [not registerable]
%systemroot%\System32\Urlmon.dll
%systemroot%\System32\Version.dll [not registerable]
%systemroot%\System32\Lz32.dll [not registerable]
%systemroot%\System32\Comctl32.dll [not registerable]
%systemroot%\System32\Clbcatq.dll
%systemroot%\System32\Oleaut32.dll
%systemroot%\System32\Mlang.dll
%systemroot%\System32\Shell32.dll
%systemroot%\System32\Shdoclc.dll [not registerable]
%systemroot%\System32\NetapI32.dll [not registerable]
%systemroot%\System32\Secur32.dll [not registerable]
%systemroot%\System32\Netrap.dll [not registerable]
%systemroot%\System32\Samlib.dll [not registerable]
%systemroot%\System32\Ws2_32.dll [not registerable]
%systemroot%\System32\Ws2help.dll [not registerable]
%systemroot%\System32\Wldap32.dll [not registerable]
%systemroot%\System32\Dnsapi.dll [not registerable]
%systemroot%\System32\Wsock32.dll [not registerable]
%systemroot%\System32\Plugin.ocx
%systemroot%\System32\Wininet.dll [not registerable]
%systemroot%\System32\Crypt32.dll [not registerable]
%systemroot%\System32\Msasn1.dll [not registerable]
%systemroot%\System32\Msls31.dll [not registerable]
%systemroot%\System32\Imgutil.dll
%systemroot%\System32\Cscui.dll
%systemroot%\System32\Cscdll.dll [not registerable]
Now Restart your system.. and Voila !!
Your problem is gone..
on Jan 24, 2010 | Computers & Internet
The file <windows root>\system32\hal.dll.
Restart the PC. The hal.dll error could be a fluke.
Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
Recover data from any bad sectors on your hard drive. If the physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Feb 15, 2010 | Dell Latitude E5500 Laptop
"<Winnt_root>\System32\Hal.dll missing or corrupt:
  1. Verify the boot.ini file is found on the computer by using a boot diskette or use your Windows CD to get to the MS-DOS "C:\>" prompt.
  2. From this prompt edit the boot.ini, verify that it is pointing to the correct operating system, and that no anomalies are found within the file. Below is a listing of what to verify
  • If only one operating system is on the computer verify that the boot.ini only has one operating system listed. In some situations an alternate configuration line may be added for the same operating system, leaving the improper line.
  • Verify that the "default=" line as well as the operating system line are the same and that they are pointing to the correct operating system.
Verify that the computer has the hal.dll file
From the MS-DOS "C:\>" prompt quickly determine if your computer has the "hal.dll" file by typing "dir hal.dll /s" at the prompt. If the computer returns a "File not found" message, the hal.dll has been deleted.
To recover this file boot the Windows operating system CD and choose the option to "Restore", "Repair", or "Recover." This option will prompt you for the Windows installation to use, the administrators password and will allow you to restore the proper file. At the MS-DOS prompt type the below command.
expand C:\i386\hal.dl_ D:\windows\system32\
In the above example "D" would be the letter of your CD-ROM drive and "C" the letter of the drive your operating system is installed on. For example, your disc drive may be D: and your hard drive is likely C:.
Jun 04, 2009 | Compaq Presario 5000 PC Desktop
if you have a windows cd you can do a system restore from it or at the boot screen some computers have a system recovery so you can use system restore without a disk, if you can use system restore, restore your computer to a earlier time and that should solve your problem
MLANG DLL. IS MISSING
This happened with MS Windows some times if you don't want to say..it's often :)
Okay, this what you should do:
Download the missing file from here: http://www.dlldump.com/cgi-bin/testwrap/downloadcounts.cgi?rt=count&path=dllfiles/M/MLANG.DLL
Then, follow the instruction below:
How to install/uninstall MLANG.DLL? 1. Unarchive the package and use the files from Release folder if you're running windows 9x/Me or Release Unicode if you are running windows 2000/XP
2. Copy DLL files in system32 folder [C:\WINDOWS\system32]
3. Click on Start > Run
  • To install the dll files, type: regsvr32 MLANG.DLL
  • To uninstall the dll files, type: regsvr32 -u MLANG.DLL
  • run.gif 4. In the end, you should receive a message saying that your file was successfully installed/uninstalled
    P.S.: If this information was helpful, please rate this solution.
    Mar 23, 2009 | Microsoft Windows 98 for PC
    Install missing dll file
    Dear
    If u have missing .dll file (download from web)
    copy .dll file to c:\windows\system32
    go to run and type (if ur dll file is abc.dll)
    regsvr32 abc.dll
    and press enter n ok
    Oct 19, 2008 | Computers & Internet
    Operating system missing gone on my advent 8315 laptop
    windows could not start because the following file is missing or corrupt:<windows root>\system32\hal.dll. please re-install a copy of the above file.
    Oct 18, 2008 | Computers & Internet
    Computers & Internet Logo
    David Payne
    David Payne
