Question about Bernina Bernette Deco 600
Not catching stitches / bobbin correctly
I had my machine service not too long ago. They did correct all the tension and cleaned the machine. I was working right along and broke a needle, so I changed the needle and it was working fine. Then bobbin thread runs low (not out). so I take remaining thread of bobbin and fill it back up. Problem is now I can't get the bobbin thread to catch. I've assured the need is not bent, is inserted correctly and threaded right. I thread the bobbin as shown. Just won't catch. I do notice when I take the bobbin plate off and watch the machine work there is no movement at all. I'm assuming that the machanics are suppose to move the bobbin thread toward the needle so that it can catch. though I'm not an expert, I'm just surmising. Anyway, I'm getting really frustrated. I've cleaned out he bobbin area.. I just don't know what else I can do? Does anyone think retiming would work? How do I retime this machine?
Any help sure would be appreciated!
Lisa
  • 1 more comment
  • chward61462 Nov 15, 2008
    I have what sounds like the same problem with my Deco 600. It is several years old. Worked great to begin with but the last 5 -6 years has been a big paper weight! I love my ULT 2001...no problems at all.
    Any help with the deco?
    Thanks...
  • toohappy Jan 07, 2009
    I have the same problem. The needle is not catching the bobbin thread and nothing is moving in the bobbin area. It had been knotting really bad and then bam, nothing. HELP!!!!
  • mcpecans Jan 21, 2009
    I have the same problem, will not catch bobbon thread, and nothing is moving in bobbon area.
Your timing has been messed up by breaking the needle.  When the needle hit the bobbin race, it shoved the needle bar up and now the needle is not in the correct position to catch the bobbin thread when the race rotates.  The needle has a little dip in the back, called the scarf.  When you take the neddle plate off and watch it move, you should see the little hook pass through the scarf.  That's how it makes the locking stitch and picks up the bobbin thread.  Unfortunately, you will need to take this in to a dealer or service place to have them adjust the needle bar height.  It's not a complicated task so see if they can check it while you wait.  It may be more difficult to fix, like retiming the machine.  But it doesn't sound like you've done any major damage to the mechanism.
Posted on Feb 08, 2009
    Problem Solver:
  • 9 Answers
When you broke the needle I think you have moved the shaft that brings the needle down ,you can adjust it !
Posted on Nov 18, 2008
Most of the time the bobbin stitch is correct. Occasionally there is a loop in the bobbin thread. Any suggestions as to what this could be?
Is it actually the bobbin thread that loops or is the loop appearing on the underside of the fabric as you stitch? If it is a loop under the fabric, that's usually an indication it is an upper thread issue. Thread irregularities that appear on the topside of the fabric are generally bobbin related.
First thing to try is installing a brand new needle. Verify it is the correct needle for the fabric and thread being used.
All About Needles
Sometimes, the fabric being stitched will "grab" the thread and hold it for a second before releasing and will cause a loop. In this case, a needle with a larger scarf and eye may be helpful.
You might also open the upper tension as much as possible, RAISE the presser foot and run a piece of UNwaxed dental floss through the tension disk a few times to clear out any gunk that may be stuck there. A piece of pearl cotton dipped in rubbing alcohol and squeezed moist/dry will also work.
Remove the upper thread. RAISE the presser foot and rethread the top thread from the beginning. Use only fresh, good quality thread--NO old or bargain bin variety! Try using the same thread in the top and bobbin. Make sure the thread is firmly seated in the tension disk and the thread path is correct. Check that there are no burrs or snags in the thread path that could be catching the upper thread. Especially, check that the thread is not catching on the spool "slit" that holds the thread when in storage. Every time the thread navigates around the thread spool, it could be catching on that slit just enough to cause a loop.
Try changing the bobbin. There could be something amiss with the current bobbin--could be nicked or could even be the wrong bobbin for the machine. Also, make sure the bobbin is loaded and turning the correct direction in the machine.
Set the upper tension to the midway point. This is usually the starting point, although it will probably require some tweaking. Test your stitch and adjust the tension so the upper and bobbin threads meet in the middle of the fabric. Neither thread should dominate one side of the fabric or the other.
Understanding Thread Tension Threads
Last thing to try is a different presser foot.
If you still have the intermittent loop, you might want to take it for service. Could be a problem within the tension disk.
Nov 05, 2016 | Sewing Machines
Zig Zag stitch isn't consistent top stitch is sporadic
Remove all the thread from your machine. Make sure to clean around the feed dogs and bobbin area. Loosen the top tension disk all the way to zero & raise the presser foot. Dampen a piece of pearl cotton with rubbing alcohol and pull the pearl cotton gently down between the tension disk a couple of times. Consult your owner's manual and oil as instructed in the manual using ONLY fresh good quality sewing machine, applying 1-2 drops each spot indicated. Install a brand new needle. Avoid old, fuzzy, or bargain bin thread. With the presser foot in the RAISED position, rethread the top thread--verify it is threaded correctly. Reset the upper tension to about halfway between the high & low number. Make sure the bobbin case is threaded properly and verify the bobbin is turning the correct direction in the bobbin case. Install bobbin case in the machine. Test stitch on a scrap piece of fabric.
If it continues to malfunction, you may need to take it for service.
Dec 29, 2015 | PfaFF Creative 7570
I have a pfaff 1475 and i can not get the tension correct. it is very loose on rt he bobbin side and perfect on the top side. HELP
......... when you did the bobbin drop, did it drop some then stop? Is the bobbin in the correct way (can go in two ways - thread feeds differently into / under the tension 'finger')
Jul 03, 2015 | PfaFF Sewing Machines
Juki.co.jp
Make sure you are threaded correctly. Also be sure that your bobbin is sitting in the casing correctly. If the timing is right and the hook is catching, the thread may not be pulling through correctly. Clean your machine as well. Make sure your tension spring is clean and doesn't need to be tuned up.
May 01, 2014 | Juki Sewing Machines
My New Home skips stitches. I have cleaned it, changed needles, adjusted the tension and tried different bobbins .
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
it's also possible that the machine could be slightly out of time
Aug 29, 2012 | Sewing Machines
Missing Stitches
if you have verified the needle is the right one for the machine model and in correctly (long groove the correct direction), that the bobbin is wound and in the case correctly, try a different material and/or thread. If the problem persists, take the machine to a better mechanic/shop. It sounds like it is out of sync. (hook rotation to needle throw).
Jul 06, 2012 | Janome Sewist 525S Mechanical Sewing...
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
Bobbin thread tension issues
There might be a piece of thread or lint caught in the bobbin tension preventing it from functioning correctly.
Feb 24, 2010 | Janome L-344 Mechanical Sewing Machine
Won't stitch properly
ever tried adjusting the thread tension control? clean if possible
tighen it more, loose tension adjustment causes loose stitch and tangling of the thread.
Jun 25, 2008 | Janome D'cor Excel 5018
The top thread will not grab the bobbin thread to complete a stitch.
its common, but easy to fix,,,ok......first things first, 1. bobbin in bobbin case correctly 2. machine threaded correctly 3. tension set around 3-4 upper 4. when was the last time machine was serviced
Jan 20, 2008 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
789 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
