Question about Canon PIXMA MP600 all-In-One InkJet Printer
Paper jam my printer says there is a paper jam but, i cant see anything jammed. can you help?
The printer is not feeding the paper right
Posted on Oct 05, 2008
    Problem Solver:
  • 14 Answers
Have you tried turning the printer off and back on again, along with the pc?
Have a paper jam in my pixma ip4500 and cant see the paper anywher to take it out?
Paper jam I suppose is the commonest of all printer problems as it can occur due to strayed, stuck bits of papers in pathway of paper tray, outlet, roller etc. I would recommend cleaning the paper inlet, outlet, and other possible areas to avoid a paper jam situation.
Follow the given steps to clear paper jam
>Clear any loose paper from the paper tray. This will help you locate the jam. You will find it either in front, near the paper tray, or in the rear.
->To clear a paper jam near the paper tray, grip the paper and pull it firmly but gently from the printer. If you find a stack of papers jammed, grab from the middle of the stack and pull.
->For a rear jam, remove the back of the printer. When you find a free edge on the paper, grip it firmly and pull it out.
->Replace the back cover. Press the "Resume" button or turn off the printer, and then turn it back on. Your settings should reset.
->Try printing another document
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Mar 15, 2013 | Office Equipment & Supplies
My printer keeps saying there is a paper jam and makes a funny click-click-click noise when I repower it.
There is probably something jamming the cog's that feed the rollers and paper,
If you cant see anything such as a paper jam, then try flipping the printer upside down, and give it a gentle shake.
It's surprising how many times a paperclip or something has fallen into the opening or paperpath of a printer.
Good Luck
Mar 24, 2011 | Office Equipment & Supplies
HP C4280 paper jam
there are a lot of paper sensor in it. i dont say buy new one , check sensors where they are and try to clean
Oct 10, 2009 | HP Photosmart C4280 Aio Printer
Printer is saying theres a paper jam but i cant see anything was working fine then it made a funny noise and stopped
Hello sir; Paper jam ,it doesn't real mean paper jamming inside, it could be something else, such as paper clip, or staples etc. check very carefully you will find out something stuck over there.
Aug 18, 2009 | Office Equipment & Supplies
Screen says paper jam, can't find anything
close properly your paper jam cover at the back of your printer down side. if not clean and check the sensor for paper jam.
May 20, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
HP 2360 Paper Jam
pls look the swich for paper inside, maybe the switch did not tuns back to his position
Oct 15, 2008 | HP Deskjet 2360 InkJet Printer
Paper jam
It's pretty rare to not be able to manually clear a paper jam. Occasionally, after you clear a jam, some paper gets stuck in the mechanism where your fingers can't reach. In that case, part of the printer mechanism needs to be taken apart to get to the jam. Like I said, it's pretty rare, but when it happens, your only option is to take the printer to a certified printer repair shop or back to the place where you bought it to get it worked on. Unless you know what you're doing, I wouldn't recommend using tools inside the printer yourself. You run the risk of damaging the mechanism and making your current problem worse.
The HP web site does publish a couple of solutions. Have a look at the information on the following two links and see if there's anything you may not have tried yet:
Clearing a Paper Jam
Clearing a Carriage Jam
Post back whether or not either of these links worked out for you. Good luck.
Oct 01, 2008 | HP PSC 1610 All-In-One InkJet Printer
'paper jam' error on canon pixma ip4300
ring canon support on 0844 369 0100
or try
support.canon-europe.com
they suggested i do a roller cleaning - but i cant find this option ?
Jun 24, 2008 | Office Equipment & Supplies
Cannon copier pc940 paper jam
canon i960 -three flashing orange lights (paper jam error) but no paper is jammed. The print cartridge1.gif will not slide to center either-- I have tried to get the printer into service mode, but cannot get there because the orange lights never stop flashing.
Dec 06, 2007 | Cannon Canon i960 Photo Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
56 people viewed this question
old marine
old marine
