Question about Cameras
When turned on, my Olympus 700 Stylus digital camera shows a thin green vertical line on the right side of the viewfinder--7/16 of an inch to the left of the right edge of the viewing area. Part of this line from the bottom up appears on the images downloaded into my computer. However, when the intensity of the light is increased, the visibility of the line in the viewfinder and downloaded image is decreased. What is the problem and can it be corrected?
  • margita14 Oct 06, 2008
    Sorry, I have not been leaving comments. I have been trying the various suggested solutions. I still have the green line on viewfinder and the partial line on the downloaded image. I'm continuing to seek solutions, for if it's actually a ccd problem, I will probably need to purchase a new camera.
    I followed your instructions and still have the problem. Nothing changed at all. Thank you for the help.
    Scholar:
  • 116 Answers
Try blowing the cool air blower of very high speed for couple of minutes on the device in the power OFF condition.if there is any dust particle it will automatically blow away.and then on the device and check if the problem repeats again or not mostly it will be solved.but if it is still there remember if the device droped some where or dashed to something in the near to problem day.then the lens would have been slightly cracked and that cracked line on the lens is coming in to the images you click.so its necessary to replace the ccd lens.take it to the service center.
Posted on Oct 06, 2008
  • 1,183 Answers
The problem is fixable , but you would require a service tech to the job. The camera has very small components inside and would require precison tools and a steady hand.
You can contact olyumpus support for best results , they would charge you somewhere around 150$ for service .
Thanks
proton
    Sergeant:
    Champion:
  • 435 Answers
Hi, Since its a line and not a pixel.  Your CCD sensor seems to be fine.
Either the circuit to the CCD sensor or the software is faulty...
Since its disappearing with high intensity of light, it seems Red and Blue (out of 2 colors Red, Green and Blue) are working but less intense than Green.
Trying to reset to factory defaults is worth a try. But if it doesnt work, you can do it with the pictures you download.
You can use some software like photoshop to select the vertical line and play around with its "Green" value and thus getting back the original picture.
When you say visiblity is decreased, I assume you mean the picture looks better (like almost without green line).
  • Karthik P Oct 06, 2008
    It would also be a good idea if you can post both the images (less light and more light)
    I meant the one shot in less intense light and other shot in highly intense light.
    thanks,
    Sergeant:
    Champion:
  • 298 Answers
Sounds to me like a pixel problem with the CCD,... a thread will not cause this.you my need to take it in for repair.
  • kristopher betzler
    kristopher betzler Oct 06, 2008
    siawolf's solution sounds like it should work, good luck and have a good day.
  • 749 Answers
This is caused by the failure of one or more pixels on the CCD. Run the Pixel Mapping feature to check and adjust the CCD sensor and image-processing functions. Wait about one minute after taking or viewing pictures to allow the Pixel Mapping function to perform properly. If the camera is turned off during pixel mapping, you must start over. To run pixel mapping, turn the mode dial to any shooting mode except [GUIDE]. Press the [Menu] button above and to the left of the arrow pad. Use the arrow pad to select the [SETUP] menu, and then press the [OK/FUNCTION] button. Use the Up and Down arrows to scroll through the Setup menu to the [PIXEL MAPPING] item. Use the Right arrow to select [START]. Press the [OK/FUNCTION] button to activate pixel mapping. Once the process has completed, the line should no longer appear in images you subsequently capture and download.
  • Cameras Master
  • 1,879 Answers
The part of of your digital camera (software that is embedded in the internal electronic circuitry) that processes image that is taken via the lens is malfunctioning and it is not user-serviceable.
You need to have it repaired.
    Genius:
  • 1,124 Answers
Reset your camera to factory settings, if the problem continues, the camera must be serviced.
  • 10,594 Answers
Please check FAQs at Olympus Stylus 700 site might helpful for you.
Can you post here a snap (jpg) describing its problem? Please re-size it up to 150k before posting here.
Thank you.
Posted on Oct 05, 2008
    Genius:
  • 1,689 Answers
Try this:
set the camera to recording mode, press the MENU button to bring up the Record mode Menu, then use the shortcuts to locate the "RESET" option, reset all settings to factory defaults...
  • marlon john madrid
    marlon john madrid Oct 06, 2008
    margita please leave a comment everytime you don't accept a solution, so that we will know what is goin on...
    no problem, you may try to check on the other solutions provided by other expert and accept their solution if one worked...
  • Cameras Master
  • 6,487 Answers
If you want you can try first to reset the camera to its default settings and check if it correct the problem but if still the same Expert sweet_rascal can be right that its a problem with the CCD...
Hope that helps.......
  • Mark Gil
    Mark Gil Oct 07, 2008
    IF that's the case the CCD is the one that is really the problem and needs a replacemnet already..
    Brigadier General:
  • Cameras Master
  • 3,614 Answers
First try to remove the unit battery, reset the settings, and lets see if it will correct by resetting the menus. remove the batt pack at least 4hrs..
    Guru:
  • 1,894 Answers
This is a problem with your CCD and not any software fault
and so best solution wil be to get this serviced by authorized service center
  • dewan nafees ahmed Oct 05, 2008
    when the camera image is having the line it must be either some small thread stuck to lens or else small faulty portion in CCD.
    what else can it be?? there is no other go.
    but its ok. you can try many solutions for your satisfaction. may be you can get it solved if lucky.
    thank you
Vertical lines in my pictures with olympus stylus tough 6020 camera
If its appear in the printer picture and also came in camera screen then its a camera CCD fault. time to buy a new camera.
Aug 05, 2012 | Olympus Stylus Tough 6020 / mju Tough6020...
I have a red line through my photos.
Answer ID 16497 Why do I sometimes see a faint vertical line in my viewfinder? Why do I sometimes see a faint vertical line in my viewfinder? --> With some DSLR cameras, a normally clear LCD screen is used to display Auto Focus area brackets in the viewfinder. When power is supplied to the screen, you may sometimes see a faint vertical line appear in your viewfinder. This is perfectly normal and is just part of the finely etched circuitry used to power and illuminate the liquid crystal segments of the AF area brackets.
Jul 24, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Olympus 700 error code 5e02 The camera lens goes out and back in on switching on, then shows the error code.
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Mar 16, 2010 | Olympus Stylus 700 / 700 Digital Camera
White turns to green
Check the white balance settings. You may have accidentally altered them to "fluorescent light" settings.
Jun 29, 2009 | Olympus Stylus 790SW Digital Camera
OLYMPUS STYLUS 740 ALL WEATHER
If it works, use it as long as you can.
Fixing snap-shooters is generally not worth it,
since digital cameras evolve rapidly and lose
value even faster with age.
Martin
Nov 09, 2008 | Olympus Stylus 700 / 700 Digital Camera
Olympus digital code D : 5f08 5e02 Camera not functioning
Camera will not turn on and displays D :
5E02
shutter will not remain open then the above is displayed
Jun 28, 2008 | Olympus Stylus 700 / 700 Digital Camera
No sound when making video clips
Yes there is an option to turn the sound off, so you can take up less space on the memory card. Try turning to the video clips on the dial then push the menu button for options!
Nov 05, 2007 | Olympus Stylus 700 / 700 Digital Camera
Write protect card
thos pictures are lost... u ken fix the problem by format...menu- setup- format...they are problems with the pictures because the camera was shaken allot...dont worry this will do it... or u ken get a card reader to get thos photos back, but the format is required
Sep 22, 2006 | Olympus Stylus 700 / 700 Digital Camera
Cameras Logo
83 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
