Question about Frigidaire FGQ1442ES Gas Dryer
Clean Lint Filter Light Keeps Dryer from starting
Someone turned on a light the same time someone else opened the dryer door. The fuse blew. Now the clean lint filter light stays on and keeps the dryer from starting even though we cleaned the dryer of all lint.
  • 2 more comments
  • mysticjade31 Oct 07, 2008
    Ok so I did the function test sequence. Every function worked just as the test indicated. Now when I press start it just beeps 3 times and won't start. I looked at the parts manual and I can find no fuse to replace. It looks to me like I may have to replace the control board. It's an expensive part. Any other suggestions?
    Oh yes, I did unplug the dryer for several hours.
    Yes, I followed the reset procedure. No change.
  • Anonymous Mar 14, 2014
    cleaned the dryer vent and hose from lint. now there is water in the dryer vent hose
  • Frigidaire Master
  • 19,396 Answers
Evidently the fuse blew for some reason.
Keep the dryer unplugged from power for one hour or so. If it still does start, you will have to take apart the dryer, check the fuse, check the thermal fuse, and test the wirings inside.
If you need to call arepairman use the number listed on the owner manual.
Posted on Oct 06, 2008
    Scholar:
  • 116 Answers
It seems that the door closure switch is a common failure point. The common theme is the dryer interior light burning out. The door switch fails, so the light stays on, and burns out. Then you try to do a load and the dryer will not start due to the switch not making contact.
the door switch and a light bulb Total cost---$20
Thanks
for more detailed help click the link below see page number three
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208558723.pdf
Posted on Oct 07, 2008
  • 2,071 Answers
Just click below for the solution;
WHAT IS WRONG WITH YOUR DRYER?
For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
Gas Maytag Style
Gas GE Style
redarrow.gif Electric WhirlClean Lint Filter Light Keeps Dryer from starting - redarrow.gifersion 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
  • 69 Answers
Check your manual to see if there is some sort of reset procedure to bypass the error.
  • Kevin Croissant Oct 07, 2008
    Hmmm.... power cycle the unit about 5 times, see if it goes off.
    You may need a new logic/mother board. IT may have been damaged and frozen in this state.
    Sergeant:
    Champion:
  • 334 Answers
Have u tryed to unplug the dryer 10 min reset breaker then plug back in thx nick
  • 2 more comments
  • nick helpap
    nick helpap Oct 06, 2008
    so try that hard reset like i said let m eknow how it works out thx nick i can get u # close by u also just need zip
  • nick helpap
    make sure that buton that pusshes in goes in so it knows doors shut
  • nick helpap
    nick helpap Oct 07, 2008
    yes control board
  • nick helpap
    will it start up with no lint thingy in it
I own a Bosch Nexxt Series Electric Dryer, the clothes come out with a petrolium smell, grease or something. I have cleaned the trap, duct work, bearing shield to no avial. It is not the washer, the
Instructions
Dryer Does Not Turn On
Ensure that the dryer's power supply cord is firmly plugged into an electrical outlet.
Inspect the structure's fuse box for a tripped fuse. Each fuse is assigned a single "On/Off" switch. If any fuse switch is in the "Off" position, flip that switch to the "On" position. If the problem persists, contact a professional electrician.
Press the "Start/Stop" button on the left side of the dryer's control panel.
Close the dryer door firmly so that the door clicks into place. The dryer will not operate if the door is not shut.
Lint Filter
5
Clean the lint filter. Twist the program selector knob on the control panel to the "Off" position, then open the dryer door. Pull the lint filter out of the dryer. The lint filter is located at the front of the dryer's tumbler, and is inserted vertically into the dryer. Gently stroke your hand over the filter to clear the lint, then reinsert the filter and close the door.
6
Turn the dryer off and allow at least 30 minutes for the dryer to cool, as excessive heat can cause a drying program malfunction.
7
Increase the ventilation of the room the dryer is located in, such as by opening a door or window. Excessive heat will cause the dryer to automatically turn off until it cools as a safety measure. Increasing the ventilation will help keep the dryer cool.
Clothing Not Fully Dry
8
Clean the moisture sensor. Open the dryer door to access the moisture sensor. The black-colored sensor consists of two bars, and is located at the front of the dryer's tumbler, to the left of the lint filter. The sensor should be cleaned with a clean cloth and white vinegar once per month.
9
Clean the lint filter. Twist the program selector knob on the control panel to the "Off" position, then open the dryer door. Pull out the lint filter. The lint filter is located at the front of the dryer's tumbler, and is inserted vertically into the dryer. Gently stroke your hand over the filter to clear the lint, then insert the filter back into the dryer and close the door.
10
Spin the laundry at a higher spin speed in the washing machine before placing the laundry into the dryer to reduce the moisture content.
11
Turn the dryer off and allow at least 30 minutes to pass for the dryer to cool, as excessive heat can cause a drying program malfunction.
Jan 09, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
Sears 417.80042990 keeps blowing thermal fuse
Did you clean out the lint filter at the front, heat is the enemy. Clean out all lint from front, if you are handy, get around back and remove all lint and dust by blowing compressed air.
Sep 21, 2012 | Frigidaire FEQ332E Electric Dryer
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
Dryer turns on but does not start when i push the start button. The timer comes on all the buttons light up, light is on inside dryer, but does not start just makes a sound when i hit the start button
if it's a humming sound the motor is bad or something is jammed keeping the motor from spinning.open the dryer door and move the drum by hand if the drum can't be moved the belt could be jammed on something or there's something stuck in the blower wheel.the blower wheel is behind the duct that the lint filter slides into.if you can move the drum then you most likely have a bad motor,try spinning the drum and push the door switch in and have someone else push the push to start button and see if the dryer will start,if the motor has a flat spot it could start like this.let me know what you find
Jul 14, 2010 | Kenmore 62602 Electric Dryer
LGDLE0442W Dryer check filter light on. Flter clean dryer sounds like it wants to start but doesn't. Is there a reset button?
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 10, 2010 | LG DLE2514 Electric Dryer
Kenmore 80 Series Gas Dryer wont turn back on after blowing fuse
Good day,
First, reverse the washer and dryer plugs in the outlet.
If that works, then the outlet needs changed.
If not,
The light switch is hot wired to the light circuit. Which means, if the machine is plugged in, the light will work.
Two possibilities.
1.The cord is bad, and needs replaced.
2. The light switch, which also runs the circuit to the motor is bad.
To access the switch, remove the lint filter, remove the 2 screws under it, then with a screw driver, pry up the top lid, one side at a time.
Lift the lid, but do not go above vertical. You will see the switch, and how to remove it.
You will need a VOM meter to test these items.
As well, make sure the machine is unplugged.
The following clip, at the beginning will get you started if you have to access the switch.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Dec 19, 2009 | Kenmore Dryers
Lg dle3777w dryer filter light remains on and dryer is not working even after cleaning the filter.
I'm sure you solved the problem but as i had the same problem on my electric LG front loader and saw no response i figured I would leave one for anybody else in the future. My girlfriend told me the dryer would not start and as i looke i saw the panel would not power up, I unplugged the power cord for 5 minutes and the LG reset and the panel was on and reading clean filter after checking the filter which appeared clean I tried to restart the dryer at which time it powered off. I again unplugged the dryer and replugged it and again the display read clean filter. I then gtabbed a phillips #2 and unscrewed the filter lint sceen which had a total of 4 scews in the interior of the dryer holding the filter housing unit. Youll see a piece of the housing unit remains screwed into the washer hooked up to two electrical plugs. Seperate both plugs from the unit and unscrew it and remove the unit youll notice two silver strips on the unit and I'm guessing will be covered with a small amount of lint. Clean the unit with a brush and damp cloth inside and out reattach the unit screw first and housing unit and turn on. If the dryer again turns off unplug and youll see the clean filter light. Simply push the custom program light or anything similar and the panel should start working again. I hope this helps someone.
Aug 08, 2009 | LG DLE3777 Electric Dryer
Bosch dryer lint light flashes
My Bosch Nexxt electric dryer had the same problem with the lint filter light blinking and the dryer not running. It turned out that the door switch was not engaging. The service technician informed me that there is a plastic tab (available only by opening the top access panel) that was not fully snapped in place. When he snapped the tab back in place and then secured it with a screw, the door switch fully engaged, the lint filter light went out, and the dryer ran perfectly! I hope that helps you!
Feb 28, 2008 | Bosch Dryers
Bosch Dryer lint filer warning
The Bosch Dryer has a temperature probe in the heater exit and in the exhaust area visible when you open the door. If the temperature difference between the two gets to high, the lint filter is assumed to be plugged and the alarm goes off.
It seems that the temperature probe at the heater, can end up with a faulty connection to the control panel over time due to corroded contacts or lint build up. When this happens the control panel thinks the filter is clogged and it may also not turn on the heating elements properly. Remove the back cover over the heating element (12 screws) and then remove the one screw holding the red wiring connection to the dryer body. You can then wiggle out the wiring connection and clean / unplug and replug in the connector for the sensor. (plug with two small wires only). A little hard feeding the connector back through the hole so take your time and don't damage the wires). Should all work again. May want to inspect inside the heater at same time and make sure the overheating switch is not tripped. ( press in the red button).
May 21, 2007 | Bosch WTMC3510UC Gas Dryer
Frigidaire FGQ1442ES Gas Dryer Logo
376 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Electrolux
Electrolux
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
