I have a MACBook Pro. samsung CLP 310n printer. The printer is attached to time machine router. While printing an error message appears indicating safari can not find Bonjour server. the printer is not networked I want it to be able to print wirelessly from the laptop.
  • biker12 Oct 05, 2008
    how do I ping?
    pinged OXNAS.local and got following
    ping: cannot resolve OXNAS.local: unknown host
    Genius:
  • 1,689 Answers
The printer itself has a built-in printserver which you can use to run IP printing from your Mac, and since you have mentioned that the printer is already connected to a router, all you have to do is use standard TCP/IP printing on your Mac's printer properties and you should be able to run this wirelessly.
Posted on Oct 05, 2008
    Genius:
  • 1,550 Answers
You need to load proper software in the laptop .If you need driver download from the site .
Also ensure that the sharing properties in laptop is configured properly for printer to print in wireless environment .
  • 6,487 Answers
IF you have a wireless router and the printer is wired to that router and your laptop is connected wirelessly to the router and internet is working fine, you just need to install the printer driver on your laptop and everything should be working...
Hope that helps.......
    Guru:
  • 1,894 Answers
Try to
ping OXNAS.local.
Samsung clp 315 warm up and don't print it all
Dear Pl. setup samsung EASY PRINTER MANAGER or SMART PANEL, command a test print it will indicate the right problem with the printer.
Mostly the exit sensor lever may not returned to it home position after getting the print out, so after one page printing it indicate error.
Also check the paper setting in the printer driver and actual paper used Match it.
Thanks.
Nov 19, 2011 | Samsung CLP-315W Laser Color Printer
CLP-310N is printing blank pages
Open the front cage, an eject the Tambor Case, you will find a small case that contain the poudre o laser ink, clean it than replace it
Good Luck
Apr 01, 2011 | Samsung CLP-310N All-In-One Laser Printer
I have a pc and a macbook pro. I can duplex print on the pc but cannot seem to duplex print on the mac using word 2011. How do you duplex print using a mac and printing with a Samsung CLP 510 EMAIL
To print duplex on a Mac:
1. After finishing your document, go to File >> Print. You will see something like the following:tcdb28.png
2. Make sure that Layout is selected: tcdb28_0.png 3. Under two-sided, make sure than Long-edged binding (or something similar) is turned on. tcdb28_1.png
This will allow you to print duplex (two sided) on the Mac.
Feb 09, 2011 | Samsung CLP-510 Laser Printer
My Samsung color laser printer CLP-310N prints a half of a page then stops with the paper still in the printer.
I have the same issue - it is def the driver as deleting all samsung drivers and then getting the printer to produce a self test print works perfectly!
Dec 25, 2010 | Samsung Office Equipment & Supplies
Have just connected Samsung CLP-310n (ethernet to router) and installed the software. However, when I want to print using the CLP-310n driver, it always prints to file rather than the printer. Any...
First make sure the printer is the default printer. If you have office or some other program you can get the print to file setup as the default printer. Just open printer right click and change if required to make it the default. If you don't have a printer hooked up the default is either fax or print to file. So you need to make sure the network printer clp300 is set as the default.
Next go into printer properties and check to see if the driver itself is set to print to file.
Also check your program to make sure it isn't set to print to file. That may be under setup, options, or page setup depending on the program. Usually if you set it to use the default system printer you are ok.
I'd assume its just the first thing ie default printer not set. Sometimes network printers aren't recognized as they should so you have to tell it whos boss ;-]
Aug 14, 2010 | Samsung CLP 300 Laser Printer
How to change the ink toner for clp 310 n
open fron door and slide cartridges out, slide new cartridges in, just remove protective tabs from new cartridges and that is all...
Jul 22, 2010 | Samsung CLP 315 Laser Printer
Samsung CLP-310N when printing it is very noisy
most probably the printer fuser unit is giving you the noise...
Jun 21, 2010 | Samsung Office Equipment & Supplies
I would like to setup my printer to print in black by default, even color images ; Samsung CLP-310N
Right click on the printer in control panel
Click properties
Click the box PRINT IN GRAYSCALE
Click OK
Mar 16, 2010 | Samsung CLP 300 Laser Printer
Print job stops halfway
I have the same problem - reading elsewhere - people talk of an exit sensor failing - that would figure - because one minute it was perfect the next it prints just half way and stops the print in the exit jaws - surely somebody knows the exact solution to this issue.
Any help with ideas about this problem ?
Greg McC
Dec 18, 2009 | Office Equipment & Supplies
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
