Question about HP Computers & Internet
Not starting up says status faild - replace hard disk 1 i have no recovery disk so what can i do its a compaq 6720s
    Problem Solver:
  • 14 Answers
First try booting into safe mode by pressing f8 as the computer starts up if it gets that far, if this does not work then check to make sure all the cables are fastened securly to the hard drive itself, still no luck your going to need a new hard drive.
Posted on Oct 05, 2008
Trying to restore back to factory settings
System Recovery
When you've tried other methods of repairing your
system software (like System Restore or Application
Recovery), you may want to use the Compaq System
Recovery program as a last resort to reinstall the software.
When necessary, you can reinstall the operating system and
the application software that was originally installed on the
PC at the factory by using the System Recovery program.
WARNING: The Compaq System Recovery
program will delete any data or programs
that you installed after purchase. Be sure to
back up any data that you want to keep onto
a removable disc.
The System Recovery program uses a special recovery
partition on the hard disk drive that stores an image of the
original software.
NOTE: The System Recovery image is in a partition area
of the hard disk drive and takes up part of the total drive
space. This disk space is not usually available for your use.
In the unlikely event that you replace the hard disk drive,
or somehow damage the data in the special recovery
partition on the hard disk drive, use recovery discs to
reinstall the operating system and software on the hard disk
drive. See "System Recovery Using Recovery Discs."
Make your own recovery discs (CDs or DVDs) before you
need them; see "Creating Recovery CDs/DVDs." You can
also make the Recovery Tools CD. This CD contains utilities
that allow you to make changes to your hard disk drive; see
"Using the Recovery Tools CD."
Starting System Recovery
if the PC Is Responding
1 Turn off the PC. Disconnect all peripheral devices from
the PC except the monitor, the keyboard, and the mouse.
Turn on the PC.
2 Click Start on the taskbar, choose All Programs,
choose PC Help & Tools, and then click Compaq
System Recovery.
3 Wait until the System Recovery window appears asking
Do you really want to start System Recovery?
4 Click Yes to continue with the recovery process. If you
created recovery discs, you may be directed to insert
recovery disc #1. If the Recovery disc is a DVD, be sure
to put the disc in a DVD drive.
5 The PC starts the recovery; wait for the onscreen
instructions to display, and then follow those instructions.
6 Complete the PC startup, finish the registration process,
and wait until you see the desktop. Then, turn off the PC,
reconnect all peripheral devices, and then turn on the PC.
Starting System Recovery if the PC
Is Not Responding
1 Turn off the PC. If necessary, press and hold the On
button until the PC turns off.
2 Disconnect all peripheral devices from the PC except the
3 Press the On button to turn on the PC.
4 During the startup, do the following to enter the System
Recovery program:
When the black screen with the Compaq logo appears,
press the F10 key on the keyboard. (You have only a few
seconds to press the F10 key before the normal startup
process continues.)
reconnect all peripheral devices, and turn on the PC.
Oct 05, 2013 | HP Compaq Presario SR1115CL PC Desktop
I have dell inspiron 1525, with windows 7, and this message appear whenever trying to login to my pc.. "Windows failed to start, a recent hardware or software change might be the cause. File:...
The hard drive may had a BAD SECTOR ( corrupt section )
try to format with normal mode,NOT quick format.
try using LLFTOOL ( hard disk low level format ) http://hddguru.com
quite bit longer to fix the bad section,but works.
akee.4shared.com
Aug 15, 2011 | Dell Inspiron 1525 Laptop
I have a laptop HP Compaq 6720s and now I get the following code t.w. 0x4001001300001002 and when I will restarted the computer the message boot.mgr missing. What must I do?
That error means that the Boot Manager is Missing. This is usualy caused by either a failed hard drive, or a failed attempt at recovery. If you try to do a recovery and then suddenly halt the process, weather on purpose or due to somthing like power failure, then the first bit of the Recovery boot process, the BTMNGR, can be hosed. If this happens then your only option is to order recovery disks from the manufacturer and install the OS that way.
You might boot into bios (F10 on startup) and do a hard drive self test first to make sure you dont have a hard drive problem...
May 31, 2011 | HP Compaq 6720s Notebook
Hp 6720s it says non-system disk or disk error
Hi,to confirm if your drive is still functional please go to BIOS,by press F10 when the system has just been switched on,go to Diagnostics on the Bios Menu,select Hard Disk test to verify the state of of your drive,if after test drive is still ok back-up files and format,if not replace drive.
Jan 08, 2011 | HP Compaq 6720s Notebook
Does a Hp 6720s laptop with XP pro have a built in recovery feature without a disk.
Hello, Most newer laptops now come without a recovery disk because the recovery is usually on the hard disk partition D.If you check yours and it has the partition for recovery, you can still burn this partition into a DVD media because the partition are usually large, incase something happens to your laptop recovery, you still have your recovery on your DVD MEDIA. Go to start>computer and check. Regards
Nov 25, 2010 | HP Hewlett Packard Compaq 6720s Laptop...
How do i reboot my hp compaq 6720s laptop i have no disk
rebooting is just restarting.if you want to get new, reset by recovery partision think you press F11.
hope this helps.
Apr 28, 2010 | HP Compaq 6720s Laptop
Message appears : Non system disk or disk error replace and strike any key when ready during start up.
a) You have a disk in the floppy drive or CD and the computer is trying to boot from that drive. Remove disk and reboot computer. Or ...
b) Your hard disk has failed
Or ...
c) Your operating system is damaged.
Apr 05, 2010 | HP Compaq 6720s Notebook
Replacment sound card for hp compaq 6720s.
Your system does not have, in a soundcard per se. It uses integrated audio that is capable of delivering the features and high-end performance of an add-in audio card.
Ergo, assuming you are lacking sound, you can mosey on to the HP site and look for what they refer to as a 'softpaq'. Use the HP search engine on their website (rather pertinent results if i may say so myself).
1. Download the SoftPaq .EXE file to a directory on your hard drive.
2. Execute the downloaded file and follow the on-screen instructions.
Jan 19, 2010 | HP Compaq 6720s PC Notebook
Compaq 6720 Hard Disk replacement
Try seagate it's one of the best.
May 14, 2009 | HP Compaq 6720s Notebook
RAM UPGRADE FOR HP COMPAQ 6720s
Well, your hard drive is ok.
Oct 04, 2008 | Computers & Internet
Computers & Internet Logo
70 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
