Question about FrancisFrancis! X5 Espresso Machine
The steamer control dial broke off. How can I reattatch it? I can adjust the control bolt that's underneath it with pliers- but that's ugly.
    Problem Solver:
  • 5 Answers
That splined shaft is a common style used with other control knobs. Your nearby Radio Shack may have some repair options for you, though not identical to the original. Bring the old parts with you if they give a sense of the size & pattern of the splines. If not RS, any well-equipped electronics parts house should have something that works - or if you see a pile of old (OLD) radios somewhere, start pulling off knobs. A setscrew type would also work - the screw clamps on to the shaft.
Posted on Oct 18, 2008
Have a second hand Homemaker chest freezer model hmbd155....recently noticed fluid around the floor....? Leaking..don't have a manual and noticed a dial on the bottom left hand corner .What this do..?
The dial Adjusts the temperature. If it is adjusted too cold you might have ice build up underneath the freezer thus causing the fluid that you see. As the freezer is old it can also be that the insulation underneath is a bit old causing the ice build up and fluid leakage. A broken thermostat (dial) will also cause too low temperature inside and possible ice build/fluid leakage.
Oct 04, 2017 | Refrigerators
1984 mercedes 560sec hood latch broken,how i open hood
try gripping the end of the cable with a pair of pliers if its the interior part broke ,had a 500 at the long term parking which had broke and for the life of me i opened it fairly easly but at my age i cannot remember what i done ,think i went up with a long screwdriver from underneath ???
Jan 17, 2015 | Cars & Trucks
Broken water pump bolts
If you remove the water pump and the shank if the broken bolts are exposed,try removing them with a bolt extractor.you may have to heat it up with a small torch. A propane torch used to sweat plumbing fittings will work.If the bolts are broken off in the block you will have to center punch them and drill them out.
Nov 10, 2013 | Pontiac Firebird Cars & Trucks
Are steaming baskets made out of plastic or metal? I would like to buy one but think they look quite ugly when they are plastic.
I have seen some all plastic steamers that didn't look so attractive. The metal ones are lovely but they are more expensive. Take a look at this link to the Debenhams site, which shows all the different steamers that they sell. You can check out the materials that they are made from and see what you prefer;
http://www.debenhams.com/webapp/wcs/stores/servlet/Navigate?ps=&storeId=10001&catalogId=10001&x=0&y=0&txt=Steamer&CMP=KNC-GoogleAd-Generics&tmcampid=26&tmad=c&_$ja=kw:steamer'cgn:Steamers'cgid:1609400717'tsid:20490'cn:Home+-+Generics+-+Kitchenware'cid:58447757'lid:13207130'mt:Broad'nw:search'crid:16780260437&gclid=CI-2wrC5ybMCFYXLtAodHmwASg
Feb 18, 2013 | Home
The lever on my rice steamer won't stay down any more, anything I can do?
Adjust ur THERMAL lever, underneath the cooker there is a SCREW w/ metal lever, adjust it till ther lever stays down!
Nov 05, 2010 | Aroma ARC7031G 6Cup Rice Cooker
4X4 gear shifter pulled off
It is held on underneath with 2 small 8mm head bolts. They probably rotted and broke off.. You will have to remove the 2 bolts and the big bolt on the side of the transfer case and remove the whole bracket if they are broke off. Only 1 might be broke because I believe the bottom hole on the shifter is slotted and the top one has the hole. Either way you will have to look at it from underneath. Hope this helps. Cobra..
Jun 04, 2010 | 1992 Ford F150 SuperCab
Chain broke off ceiling fan
Is it broken off inside the pull switch? If so, I would recommend replacing the switch. The chain attatchment assembly is riveted onto the electrical part of the switch. It is possible to drill out the rivets to separate the two sides of the assembly to replace the chain, however you would need to use small bolts with nuts to reattatch pieces together after installing new chain. It's a pain in the back side.
(of course all this repair work needs to be completed after removing the fan from its ceiling location and disconnecting the wiring)
Sep 17, 2009 | Hampton Bay Dryers
Steamer filler cap is sealed
You need a little more leverage--either a strap type tool or a pair of adjustable width pliers that span the width of the cap. Try running hot water over the cap first which may loosen it enough to remove by hand.
Sep 09, 2009 | Euro-Pro Shark SC-505 Handheld Steam...
Seat bolt broke
drill the original bolt out and place another bolt from underneath, screw on a nut from the top
May 16, 2009 | 2004 Honda VT 1100 C2 Shadow Sabre
FrancisFrancis! X5 Espresso Machine Logo
65 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
dharmanos
Level 1 Expert
Joe Lalumia aka...
Joe Lalumia aka...
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
