Question about Maytag Neptune MAH5500B Front Load Washer
Maytag MAH5500B FL Washer
You sent me a solution for my waher not starting and it's intermittend problem. You said to check the fuse or circuit breaker is this for the electrical circuit the washer is plugged into or is there a fuse in the machine itself. Sorry if the question is stupid but I wanted to make sure if there is a fuse in the machine that I may have to change.
thanks
Aida - ortizai@optonline.net
  • 750 Answers
Washer Stops
• Plug cord into live electrical outlet.
• Check fuse or reset circuit breaker.
• Close door and push the start/pause pad to start the clothes washer. For your safety,
washer will not tumble or spin unless door is closed.
• This may be a pause or soak period in the cycle. Wait briefly and it may start.
Check screens on inlet hoses at the faucets for obstructions. Clean screens periodically.
If the sreens are colged or even a little sirty it will stop the washer!
Won't fill
• Be sure the door is tightly closed.
• Plug cord into a live electrical outlet. (Tub light should illuminate).
• Press the start/pause pad.!!!!!!!!!!!!!!!!!
• Turn both faucets on fully.
• Straighten inlet hoses.
• Disconnect hoses and clean screens. Hose filter screens may be plugged.
• Open and close the door, then push the start/pause pad.
May be a bad door sensor!!!!!!!
Huuum
Pleae remember to leave a rating
Posted on Oct 10, 2008
Error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Mar 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
Door won't open
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/27966-maytag-mah5500b-fl-code-door-locked.html
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/13490-maytag-neptune-mah5500-wont-open.html
Dec 31, 2012 | Maytag Neptune MAH5500B Front Load Washer
My neptune washer stop working. has power but doesnt cycle. shows a FL code. cycle i mean as spin to start washing
FL means that the door isn't locked properly. Make sure that its locked tightly and restart the cycle
Feb 16, 2011 | Maytag Neptune MAH5500B Front Load Washer
Have a maytag mah5500bww replaced door lock still do and fl code
fl is usally a water not detected problem,, check ur fill hoses for kinks make sure ur water is on,, possibly have a bad fill valve..
Feb 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
Our maytag neptune frontloader won't start
CHECK PLUG FUSE IF OK CHECK WIRE FOR ANY BREAKS IF NONE THEN IT MAY BE THE ON /OF SWITCH IS FAULTY.
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH5500B, FL code and door locked.
Check your drain and the drain line all the way to the pump. Here is some info on the F1 code.
FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for "FL" to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Waher over fills
get a new washer, do away with the mold machine!
Feb 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer display showing FL
fl is a over fill. clean the pump out and the sump near the pump is in the back the dran hose goes to it
Nov 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytab Neptune FL washer
Hello ortizai and friends
Welcome
If the washer stops here are some reasons why this may happen.
The water lines have screens that can become clogged by accumulating debris in the water,
And then the machine will automatically shut down. And if its not completely blocked it will shut down intermittently!
1. Plug cord into live electrical outlet.
2. Check fuse or reset circuit breaker.
3.Close door firmly and push the Start/Pause pad to start the washer.
For your safety, the washer will not tumble or spin unless the door is
closed.
4 This may be a pause or soak period in the cycle.
5. Check screens on inlet hoses at the faucets for obstructions.
May be on hose ends too,and will be in the water inlets of the washer!!!!!!!!!!
Let me know who gets started, since there are multiple people with this problem.
Huuum
Please remember to leave a rating
I'm trying to figure out more ideas and will forward them soon.
Jun 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
116 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
