Question about Sewing Machines
Error #19 on singer futura ce150
Brand new machine. Set it up, started to sew straight stitch on cotton material, got about 15 seconds into it and got error 19. What is this and how do I fix it? Please HELP!
  • ShysWifey Apr 28, 2009
    Hi, I dont know how long ago you posted this, but I JUST got the machine, have the SAME problem with the error 19.. the thing will sew just fine for 7 stitches, when I reach the 8th it beeps and stops with Error 19 flashing.. the sewing is fine, but it disagrees. How did you get it to stop? Im scared to even try to embroider cause i dont know if it will finish it or not.
    Please email me back,
    Thanks SO much for ANYthing!!
  • Trustfulguy Oct 14, 2009
    I have the same problem. Any luck yet? Any suggestions?
    Thanks in advance!
Try re-threading the machine. Also, when you put the thread trough the clear plastic part on the top left at the back, swish it back and forth a couple times before bringing it all the way through. It is a little tip someone told me and seems to work wonders.
Posted on Feb 19, 2010
  • Jim Yeh Dec 03, 2010
    That worked great!
I actually found that the thread was releasing from the roll too quickly, the machine comes with a little netting that can go over the reel of thread and it keeps it tight until pulled by the machine. once i put the net on never got the error again
Posted on Aug 04, 2010
I ran into this problem as well. Root cause was that I threaded the top thread incorrectly. There is an illustration on top of the sewing machine that shows you the proper way to thread it. Once I re-threaded properly, the problem went away.
Posted on Jul 09, 2010
I am having the same problem, i have had my machine for months and everytime i bust it out it does this. i have checked my threading over and over again, flossed the thread back an forth on the top part. i watched a video on youtube on threading this machine and followed every step to make sure i was doing it right. if you find something out please let us know!
Posted on Jun 14, 2010
  • holly_arens
    holly_arens May 23, 2012
    I am having the exact same problem have re threaded re treaded and re threaded again! I have just about pulled the entire machine apart. This is only the second time I have used this machine...got it for my birthday in early april. I have yet to be able to download the embroidery software on my computer...i am so frustrated I could SCREAM...
My new machine sewed fine in cotton material, but I am having trouble sewing on a silky top.
Machine settings usually need to be re-adjusted when the project materials change, ie the needle size & type, the type/weight of thread, the presser foot pressure, the thread tension, the stitch length, etc. Sewing woven cotton is very different from sewing silk or chiffon. Test on scraps of the fabric before actually sewing on the garment. Even adding tissue paper to the stitching will help prevent fabric puckering.
Top 10 Tips for Sewing With Silk
How To Sew With Silk And Silklike Fabrics
Jul 05, 2017 | Sewing Machines
Adjusting top and bottom stitches...
the stitch length is set by the amount the foot pulls the material through
adjusting the needle thread tension is the main adjustment to ensure that both threads meet at the center of the materials being sewn
Mar 10, 2017 | Sewing Machines
I would like to know how to set the machine up for polyester/spandex material
You need a ball point size 70 or a jersey 70 if you can get it. Stitch length 2.3 to 2.5. Re tension, just normal tension setting. If the machine is sewing an evenly balanced zigzag on regular cotton fabric, then tension is fine. If you find the straight stitch on your fabric pops under stretch, then try using a very small zigzag to put some flexability into the seam.
Mar 28, 2013 | Bernina Activa 140
While sewing the thread will break
Take a small piece of material and take several practice runs of a straight stitch. If the cotton breaks try adjusting the small tension wheel (numbered 1234 etc) . To decrease tension turn to a lower number. Adust as necessary until you get a satisfactory stitch.
Jan 30, 2011 | Brother SE350 Mechanical Sewing Machine
Please could you tell me what the digital reading should be for a straight stitch when sewing with cotton materials and cotton thread?
I could not find any reference to this at the BL website. You can download a free manual from the site if you need one.
Feb 05, 2010 | Baby Lock Espire
Thread bunches up from bobbin feed.
Remove the needle plate and clean the feed dogs there could be fluff gathering.
Check your needle is not damaged.
May 30, 2009 | Singer 1120 Mechanical Sewing Machine
Sewing Machines Logo
1,013 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
