Question about HP LaserJet 3030 All-In-One Printer
ADF not working.
I was getting a black line whenever I faxed or printed using the ADF. Printing from my computer or copying from the glass did not have the same problem. I took it apart an cleaned everything and of course now my adf is not working at all. I was careful to put everything back the way I took it off, but obviously have done something.
Any suggestions?
  • Dandywalls Nov 06, 2008
    My HP3030 does not detect when paper is placed on the ADF feeder.. It worked fine for 6 mos.
  • HP Master
  • 4,338 Answers
If the black line shows only when you use the ADF, lift the whole document feeder, and look on the very left of the glass (the area onto which the paper is travels from the ADF). Check that the glass is clean in that area.
On the ADF:
Open the small ADF cover on the top right. There you will see rollers and a paper sensor. First make sure the isn't any paper stuck in the rollers. Clean the rollers with a damp cotton pad or cloth a small amount of dish washing detergent. Make sure it is damp. Then check to make sure that the paper sensor lever is working by toggling it. The paper sensor is spring loaded, check that the spring is in place.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 07, 2008
When I fax it copies a black line is on the page. And when I copy from the top part it copies a black line. How can I fix that?
are you getting black lined copies while you are trying to send a fax or black lined images are obtained at the receiving end. Is there any problems while copying from platen glass. if it's ok, then check if there is any thing on the stream reading glass (the small sized glass plate meant for ADF) & clean it.
Apr 14, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
When I send a fax through the document feeder it prints out at the other end with a black line down the page. I have cleaning my cartridges and everything else.
If the line only shows on ADF and not off the glass copies (where you lift the lid and place then item right on the glass), then there is something on the glass that the ADF uses. If you open lid you should be able to see the section of glass where documents that are fed through the ADF pass over. Make sure that this glass is spotless and use a cloth dampened with window cleaner to ensure that you get any label adhesive off the. Often even very faint bits stuck to the glass that you can hardly see will show up as black lines.
Mar 04, 2011 | HP Officejet 5610 All-In-One InkJet...
SCX 4826FN everything that goe in through the top feeder (scans, copies, faxes) comes out with a solid vertical black line on the paper. All other printing jobs that pull paper from the tray are ok. It...
This black line sounds like it is definately coming from the ADF scanner glass. This is the thinner strip of glass that is located just to the left of the large original glass. You can verify this by making a copy from the large glass instead of using the feeder on top. If the copy comes out clean then it is definately the scanner glass. Just clean the glass well with glass cleaner and a soft cloth. This glass is only used when copying/scanning using the top automatic feeder
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 04, 2010 | Samsung Office Equipment & Supplies
Copies run through the feeder have black line on them, copies on glass & faxes are okay
Clean the ADF scanner glass. This is the small strip of glass that is just to the left of the large glass. Normally there is a label on the machine right by this glass that instructs you to clean this strip of glass whenever streaks appear when using the ADF or Automatic Document Feeder. Sometimes toner/dirt gets stuck on this strip of glass so clean it well using a soft cloth with some glass cleaner.
Apr 29, 2010 | Ricoh Aficio 1035 Copier
I have a black streak all on one side when i copy ?
If it is just when you copy and not when you print then it is a cleaning issue. Toner cartridge would cause the line to appear on copies, printouts and faxes. There is a piece of glass inside the auto document feeder that is probably dirty. Open up the document feeder as if you were clearing an original document jam. Look for a piece of glass inside the ADF, it will run the length of the document feeder. There is probably some dirt or another popular problem is white out. Clean off the glass with glass cleaner or alcohol and it should fix the problem.
Oct 04, 2009 | Brother IntelliFAX 4100 Laser Fax
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
HP 3055 printing black lines when using collate feature to copy
All you need to do is to clean the small wide glass (that at the LEFT of the main flat big class). The Auto Document Feeder (ADF) specifically uses this glass to scan for copy (and fax). When it is dirty (such as small dirt or particles on the surface which is easy to gain in long run), it will create thin vertical line(s) as the result.
Jan 28, 2009 | HP LaserJet 3055 All-In-One Printer
Has line down center of page when using ADFfor copying
Hi There,
There is a piece of glass that the machine uses to scan the page. it's like a 1/2 in wide, and the width of the paper.
This glass is dirty with a spec of toner or white out on it.
Clean this glass very good. you may have to use a razor blade, but be very careful not to cut the plastic around the glass or it will jam.
Steve C.
Jan 24, 2009 | Office Equipment & Supplies
Vertical lines
hi,
I just want to know that which did you try to use to scan. is that by using the ADF (automatic document feeder) or using the scanner glass?
Jun 18, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Canon Pixma MP780 Fax Problem (horizontal line)
Solution is here: http://www.fixya.com/support/t136826-printer_problem
Mar 05, 2007 | Canon PIXMA MP780 All-In-One InkJet...
HP LaserJet 3030 All-In-One Printer Logo
162 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
