Loud noise in washer center still spinning draining fine but still loud noise trying to get center out but just got fabric softner top off Sears Kenmore washer
  • 943 Answers
Hi. thanks for the question. the problem you are having is with the motor drive coupling. which is located at the motor and transmission .replace the coupling .thanks the appliance doc.
Posted on Oct 05, 2008
Whirlpool wtw5100sq0 clunks when put on spin cycle
Does the washer currently work fine aside from the loud clunking noise? Does the clunking noise continue or is it just one loud clunk when it starts to spin? If its just one loud clunk then that is not a problem just ignore it as that is the clutch spring releasing, it probably starting making noise from the grease getting washed off when the washer over filled.
However how did the washer overfill? That issue should be addressed too. Sometimes though, if the tub is not centered from a heavy load the water will spill over the back but its not really an overfill.
Mar 25, 2013 | Washing Machines
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
May 30, 2012 | Amana Washing Machines
you can try putting a dishwashing tablet in it with some hot water and let it sit overnight ...the tablet has something in it made to desolve build up for water ,soap,ect...and it safe to the washer and to you too.I used one in my water drain on a water in the door ice box worked like a charm.
Dec 03, 2009 | Kenmore Washing Machines
Fisher Paykel Gw11, leaking, loud noise, not going through cycle
pump is a common fault and easy to change for about $25. all sound related. new machines are pretty inexpensive. your call
Aug 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
Top load won't agitate or spin
If it is a direct drive (no belt) Your motor coupler is broken. The washer would make a grinding noise but do nothing. Basically it is like a belt it connects motor to tranny. It is a fairly inexpensive part $20-25 retail.
Apr 25, 2009 | Washing Machines
Terrible noise when agitating
Your transmission has gone out. The reason the spin cycle works is because the transmission spins two different ways and you agitate way stripped the gear. Some places rebuild them. Try with your local stores maybe they can rebuild it or get you a good used one. If not you can order a new one from
Nov 12, 2008 | Kenmore 24032\24036 Top Load Washer
Clothing stuck inside at bottom of Washer.
This keeps happening to me too. Solution :The fabric softner cap has two bevels on the side if you place something in it the fabric softner top will come off. Under the that cap there is a bolt, losen the bolt and the agitator pulls up. Hope this helps, my problem is that the agitator moves back and forth while spinning and causes the close to get stuck. I don't know what is wrong if you can help let me know.
Jul 08, 2008 | Kenmore 22422 Top Load Washer
Kenmore 80 Series Heavy Duty Super Capacity Plus
that is a whirpool source washer suspect wire underneath console may be where connector from wall plug connects underneath ckd all wires around timer possible power loss has been problem from the first but try to some action going again first good luck
May 21, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
