Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Refrig seems to be barely cooling and freezer isnt enough to keep ice from melting.
I began cleaning the dust under the unit and I thought it might have helped. I can still clean a little more. While under there, as any man that touches stuff he shouldnt I guess, I noticed a silver box with a red cam dial sticking out of it. I turned it to the right(will not go left at all) and the fan kicked on, unsure if the compressor did anything. The compressor is hot ( I did unplug the frig). All controls are on coldest position, but it is simply barely cooling. Any suggestion would be appreciated.
  • 943 Answers
HI thanks for the question. that part that you turned is the defrost timer. turn it again and leave it see if it defrost the freezer. if it does. replace the defrost timer. thanks the appliance doc. please rate my answer. thanks
Posted on Oct 09, 2008
Refrigerator keeps clicking and isnt cooling
The small box is probably the compressor start device and this starts the compressor. They go bad. You will have to remove this "box" and replace the start device. when you remove it shake it it should not rattle. If it does then it more than likely is the problem.
Apr 06, 2014 | LG LSC27931SB Side by Side Refrigerator
Freezer side not cold enough, similar temperature as Refrigerator side
It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
Nov 12, 2013 | Refrigerators
Helloi have a Maytag Plus side by side refrigerator (about 10 years old) and I'm having trouble keeping the refrigerator side cold enough. This unit has dual slide bar controls on the ceiling of the...
remove the rear panel inside the freezer,your evaporator coil is iced over and cant transfer cold anywhere,deice it,then check the defrost heater under this coil,its probably open and cant heat to defrost the unit
Jul 19, 2010 | Refrigerators
My freezer leaks when not freezing
Drain tube
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer. If this repeatedly happens with yours, you may can prevent it by taking a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Mar 02, 2010 | Refrigerators
It is a profile side by side model tfx25pabg and at the bottom of the freezer it gets a pool of ice that I need to keep breaking up and removing. if it goes too long, then i see a puddle on the kitchen...
Feb 05, 2010 | Refrigerators
After thanksgiving, and loading the fridge with cooked food, after a couple of days water started accumulating under & in the vege drawers. How to correct?looks like the hing in top center of...
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Dec 10, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Warm
If you need freon you can't do it yourself
Could be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 23, 2009 | GE Refrigerators
GE REFRIG. MODEL#TFX30PRYAA. side by side both
It sounds like your defrost control timer is working, but your defrost heater is most likely burnt out. It is a part number WR51X443
and is located behind the back wall inside the freezer. Turning the refrig off for 24 hours helped melt some of the accumulated frost, but not all. You will have to take that back cover off inside the freezer and melt all the frost with a hair blower, replace the defrost heater and reassemble.
Jul 01, 2009 | Refrigerators
The refirgerator is not cooling
Their are a few things you can check before calling a dude out. make sure your condenser coils are clean on bottom of refrig. Hair dust and cobwebs can constrict airflow in those coils. Look ffor frost on the back wall of the freezer, a sign the defrost heater has blown. Remove the rear access panel of the freezer and inspect for ice, use a hair dryer to melt the ice and check the defrost components. MORE
May 09, 2009 | Refrigerators
Freezer running, ice maker not producing, hot in middle divder.
The dividing section should be warm, to keep unit from sweating. (by design). Cleaning under the refrigerator was what cooled it down. You cleaned the condenser. The condenser allows the refrigerent to cool down. When it was dirty, the condenser could not get enough air to cool down.
Mar 14, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
59 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
