Question about Dell Dimension 3000 PC Desktop
No Audio Device
Sorry about the earlier posting, this is my first time. Anyway please see my problem below.
Replaced hardrive in a Dimension 3000, installed Windows XP Professional and have no sound. I go to control panel and the Sounds and Audio devices are grayed out saying No audio device installed. I tried to install the driver from Dell and I receive a message during setup that the Audio driver does not suport your computer hardware. There is only one driver and it is the R94481.exe. I did a diagnostics and the sound passed the test for the 8 tones. Other than that, I have no sound.
  • wlynnr Oct 05, 2008
    I did that. I installed the OS, then installed the additional drivers for the video, ethernet, etc. It just won't let me install the audio driver and it's the only driver available from Dell. The plug n play worked with everthing else, so yeah, this is weird.
    I may just reinstall the OS again and see what happens that time.
    Champion:
  • 208 Answers
Hmm strange.. sounds like plug n play service issue or a bad xp install. with dells usualy u have to install 1st desktop system software then chipset then audio, video, ethernet.
Posted on Oct 05, 2008
  • Arnold G
    Arnold G Oct 06, 2008
    seems like sound chip is going bad?. one good way of testing is install linux with a known working distribution for that model.
    updated bios already? reset to defaults might help too!
Replaced video card in Dell Dimension 3000 with NVIDIA GeForce FX 5500. Can't find video controller driver
Hi.
Click on the link below and download the driver for the card, if you are unsure then click on the Supported Products tab and you will see that the FX 5500 card is supported in the download.
http://www.nvidia.com/object/winxp_175.19_whql.html
Regards.
Feb 04, 2013 | Dell Dimension 3000 PC Desktop
Had to reformat C: on Dell Dimension 3000. Now can't get any sound. Tried to download drivers from Dell but it comes as an application and I can't open it. Any advice please?
Most of the Dell driver downloads are .exe files. They are self-extracting executables (much like a ZIP file). You need to first double-click the downloaded file and when the extraction window pops up, make not of the directory that the file is going to extract to (usually c:\dell or c:\drivers). Once you noted the directory, continue with extracting the files. Then go into your device manager (control panel, system, hardware, device manager) and find the sound device that is either disabled or not loaded properly (usually will have a yellow exclamation mark next to it). Double click the device and "update driver". When prompted, point to the folder that the files extracted to earlier, and then the device should load properly.
Some Dell drivers include a setup.exe file, but most of them follow the above-listed format.
May 27, 2010 | Dell Dimension 3000 PC Desktop
I have a dell dimension 3000 and i can't get any audio sound. it came with a samsung sw-2525 CD/RW . come to think of it i don't get any sound through the external speakers. it has no internal...
check to see the sound is working under the control panel .. system icon click and goto device manager
you might have a bad driver for the sound device or the device is bad on the motherboard
also test under sound devices.. and set the default device to use ..
Sep 28, 2009 | Dell Dimension 3000 PC Desktop
Front panel connector J16 dell dimension 2350
Visit http://support.dell.com select your product and download user manual and maintenance manual. It may solve your problem.
Jul 15, 2009 | Computers & Internet
Dell Dimension 3000 system recovery
AH yes, Kristen very familiar with your issue, it is trying to load the primary boot record from a device it dosen't see , ( re: a floppy thats not there) you need to check the BIOS and make sure the booting sequence is correct (re:disable floopy if one dose not exist, etc) please write back if you need help doing all of these things
Apr 18, 2009 | Dell Dimension 3000 PC Desktop
Low speed working
If you would like to take a drastic measure to fix this problem, just take everything you have on your computer that you want to keep and save it. Burn it onto a CDR, DVD or put it on an external device such as an external hardrive or a memory stick. Make sure you have all the dics that came with your computer. Such as the Operating system CD and the CD which contains your drivers. I believe that disc is called the Dimension Resource CD. Then wipe you hardrive clean. I used a program called D-ban to do this on my computer. It was free and I found it on the internet at http://www.dban.org/ Now that your hardrive is clean and you saved the stuff you wanted to keep, just reload windows by placing the operating system CD into your cd drive and reboot your computer. When the first window opens hit your F12 key then boot from the CD drive. Folow the onscreen directions and this will reload your operating system. Then install all the drivers from the Dell dimension resource CD. WOW!! Now your computer will run like it is brand new. It will seem like you just bought it new. I have done this several times to my computer. It is a little time consuming but it works like a charm. It will also remove a computer virus if you have one.
Other than the solution above I have used the restore points on my computer. If you have set a restore point on your PC from an earlier date you can go back have all the settings changed to that date. Here is a link to information on how to do a system restore. http://www.computeractive.co.uk/computeractive/q-and-a/2230699/pc-help-system-restore This is easy to do. Good luck with eveything.
Mar 15, 2009 | Dell Dimension 2400 PC Desktop
My dell wouldnt post,
It sounds like the motherboard is damaged. Did you try to start with a boot cd? Or will it just not get to the bios setup screen?
Nov 28, 2008 | Dell Dimension 3000® Pentium® 4...
Sound windows xp dimension 3000
hi if your motherboard have you install sound properly....Or not your sound driver you Go to driver Zone.com then download it
Jun 06, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Logo
167 people viewed this question
Alun Cox
