Question about Refrigerators
Lg lfx25960st water dispenser stopped working
  • 943 Answers
Hi. thanks for the question . i would look at the water valve at the back of the fridge. replace the valve .thanks the appliance doc
Posted on Oct 05, 2008
Trouble shooting LG french door ice dispenser
LG French Door Refrigerator - In Door Ice Maker Troubleshoot
? 4:41
https://www.youtube.com/watch?v=rA1DhfTwuwM
Feb 4, 2013 - Uploaded by ExperienceLG
Ice makers are great, but not if it means you can't fit all of your food in the fridge. The Slim SpacePlus Ice ...
LG fridge ice maker troubleshoot/ repair. How to fix ice ...
? 8:06
https://www.youtube.com/watch?v=arJpFgMnvPY
May 19, 2013 - Uploaded by spartacus1234567890
The ice maker quit working in my LG refrigerator so I decided to take it apart ... LG French Door Refrigerator - In Door Ice Maker Troubleshoot ...
LG Refrigerator Ice Maker Not Working - Model LFX25960ST
www.repairclinic.com/RepairHelp/...Fix...-/LG-Refrigerator-ice-maker-n...
LG Refrigerator Ice Maker Not Working. LFX25960ST. The part(s) or condition(s) listed below for the symptom Refrigerator ice maker not working are ordered ...
Jan 05, 2016 | LG LMX28988ST Refrigeration : Refrigerator...
Is there a tube or "tip" that fits over the water spout in the door water dispenser?
No, your tube may be too far up in the dispenser causing it to splash or dribble. Try turning the water to the refrigerator off then push the water switch while pulling the dispensing tube to see if that will bring the water tube closer to the dispensing area.
Mar 09, 2010 | LG LFX25960ST Stainless Steel French Door...
Water is dispensing very slowly and I just
yup,
i would turn your freezer down a few degrees, you are more than likely expeiancing, whats called migration frost, cold air from the freezer, could be freezing your water resivoir or the line from it
causing bad pressure
Oct 19, 2009 | LG LFX25960ST Stainless Steel French Door...
I have a LG 3-door french refrigerator that will not dispense the ice. It makes the ice just fine and it dispenses the water just fine. PLEASE HELP!
the most be a chunk of ice stuck since this refrigerator cool way much it freezes the water in the dispenser area i have cleared wit a bit of hot water and emtying the ice bucket
Oct 05, 2009 | LG LFX25960ST Stainless Steel French Door...
No water, no ice-LG LFD21860ST
Sound like a water supply problem, as both get water from the same source. Both valves are connected to the water line that supplies water to the frig, in the back, bottom, behind the cardboard cover. Make sure the water valve is on for that line. The noises indicate thew valves are probably working, but are not getting any water.
Sep 19, 2009 | LG LFX25960ST Stainless Steel French Door...
Water is slowly trickling out of water dispenser
This is usually because the water filter on the supply line needs replacing.
If it has not been replaced within 6 months, then this will probably cure it.
Thank you for using Fixya,com
Aug 05, 2009 | LG LFX25960ST Stainless Steel French Door...
Frig has stopped making ice.
Open the left door open the ice maker door, up in the left hand corner you should see a green light, check to make sure that you have a selection chosen(either small of large cubes.
Jul 15, 2009 | LG LFX25960ST Stainless Steel French Door...
Low water pressure on door dispenser
i have a similar problem. my water dispenser worked perfectly with the origional filter for about 8 month . then there was a decrease in water output. i then changed the filter.this worked fine for about 2 weeks . changed the filter again 2 days of water output. i have since changed the filter 2 more time with the same results. i do not have a kinked line . i have had the refer for about 1 1/2 years. ice production is down also . any thoughts?
Jul 01, 2009 | LG LFX25960ST Stainless Steel French Door...
Refrigerators Logo
381 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
