Question about Teac DC-D2831 CD Shelf System
CD Player does not recognize CD
CD player rarely used . Very dusty when opened. Suspect CD read
device (Eye) needs cleaning..What is good way to clean it???
    Problem Solver:
  • 8 Answers
If using computer generated dics , disc usally bad burn progam , bad disk, burn speed to fast. Check out NERO burn. OR dirty eye, clean, laser eye with disc clean disc
Posted on Dec 11, 2008
Hi ..I have Pionner PD-M701 CD Chanager .the player works so fine and recognize all cds in the trays but the issue is in the reading .
hi Sam.
you could try this.
Clean the CD if it skips or the player can't read it. Use a clean lint-free cotton cloth and make sure the CD is not scratched. Use a lens-cleaning CD in the player. If you can access the lens without opening the case, clean it with a cotton swab and lens cleaner.
Why does a CD player skip? They don't scratch as easily as vinyl LPs, but I've damaged half a dozen CDs over the years. If a CD is skipping, first give it good clean using a CD wipe or mild soap and water. Dry carefully with a lint-free cloth in a straight line from the centre to the edge. Rubbing in circles can cause more damage.
.or try this link for more info.
cd player skips Google Search
Dec 03, 2017 | The Audio Players & Recorders
Asus DRW-241st stopped recognizing any DVD's though it still reads CD's. Other then that it seems to be running just fine.
Good day sir, Try to clean it with a CD lens cleaner if problem persist.I recommend replacing your optical disk drive or use it as a slave for reading CD's so that your new ODD will last long. in my opinion most DVDRAM, player etc. can read most formats except Bluray disc. using the device from reading CD,VCD and DVD lessen's the device life span.
sometimes if we rarely use the ODD its already not working.
Jun 29, 2011 | ASUS DRW 24B1ST Disk drive DVD RW ( R...
DVD player does not recognize DVD's. Icon "No
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Mar 04, 2011 | Insignia NS-BRDVD Blu-Ray Player
Cant read the discs,dvd,cd or blu ray, "no disc"
You need to purchase a dvd disc cleaner or buy a can of air from wal-mart and spray out the drawer and the inside of the player with the drawer open,the eye of the dvd player is probably dusty and can't read the disc...and make sure the dvd is clean with no finger prints on it.
Feb 26, 2010 | Sony BDP-S300 Blu-Ray Player
Re Hitachi AX-M80 - cD Player. When put into PLAY mode - there is an ERR message displayed and CD is not played.
This evening my daughter revealed she had the same problem. I wiped the eye with a tissue - now it works!
Some times the obvious is the answer.
Oct 23, 2008 | Audio Players & Recorders
Constant 'Err' and 'No Cd'
Your post/description could be indicative of just that, your unit can no longer read the disc.
This could be brought about by:
1. dirty, dusty, smeared optical lens or the laser eye;
2. stuck lens carriage;
3. defective laser eye.
#1 could be corrected with the use of a CD cleaner commonly available at computer stores/shoppes. Alternately, you can use a fine, clean small brush;
#2 if visible on top could be cleaned with cotton buds and household alcohol. You need to re-lube when it has dried up;
Additionally, a can of compressed air would also be of help in removing any dust or foreign materials inside the disc mechanism.
#3 would require the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 19, 2008 | Philips AZ1300 CD Boombox
CD Player problem
Most DVD players that would not play a disc even with a known good disc inside signifies that the llaser eye/lens is not reading the disc. This could probably be attributed to:
1. dirty, damaged, inverted, blank, un-finalized burned CDs or DVDs;
2. defective, weak, dirty/dusty burned-out laser eye/lens;
3. dirty, dried up lubrication of the slider shafting (where the laser eye's carriage moves) or some other components; and/or
4. dirty, dried up lubrication, defective spindle motor.
A few things you can try:
1. Use a CD cleaner (readily available from most computer shops);
2. use a can of compressed air and blow through the inside of the loaded disc area;
3. gently tap on the top cover where you estimate the reading/laser eye/lens would be;
4. gently press on the tray door once the disc is loaded;
5. relube, clean as necessary
Should this not be corrective, perhaps your best bet would be to seek the services of a qualified professional such as those in a Service Center. Alternately, your friendly neighborhood electronic shop should do just fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Feb 10, 2008 | Audio Players & Recorders
CD player
All this cd systems have the same problem. If you're using burned cd's sometimes they don't work so you need to close the session after burning in your burning program. If you're using original cd's it means that the device needs to be cleaned up (especially the lens) because the structure of a 5 cd combo device gets very dusty after a while. Also from my experience after cleaning it put a cd in each deck (even if it's off) so they could prevent it getting dustier again. Hope it helps, good luck!!
Feb 12, 2006 | Panasonic SC-AK29 CD Shelf System
Teac DC-D2831 CD Shelf System Logo
846 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
