Question about Amana Heating & Cooling
Amana heater/airconditioner model no. ptc093a35ab dont turn on
The on/off switch did not work had to unplug it all the time now it dont work all.and cant get any info on this model no.ptc093a35ab i want to find a repair manual
2 Suggested Answers
SOURCE: Carrier Heater/Airconditioner Model 58DRC045-GB fan
You can temporarily cut off the power, expose control board, pry off upper rear relay plastic cove, remove spring and stretch it out just a little from its original length because the relay is either getting weak or there are other problems with the board supplying the proper voltage to it... anyway, when putting the spring back on be sure the relay switch is properly aligned in the holes furthest away from the board.. This should provide at least several more months of proper operation before board needs to be replaced... Quick fix, install new board... Tech Chris w/ Absolutely Fabulous! AFSO.US
Posted on Mar 31, 2009
How to get the airconditioner to change to heat ?
a little help so you can be helped...make and model please.
Jan 07, 2018 | Heating & Cooling
I have an Amana heater/airconditioner (Prestige I think) that is not cooling. The outside compressor fan was not spinning, so i I changed the capacitor on the unit. It now spins, yet vent air not cold
If that fan stopped your compressor overheated, shut off on thermal overload. Carefully cool compressor with water hose and restart. If the big copper is cold ,small copper warm, compressor is running. Check capacitor on compressor
Jun 06, 2016 | Amana Heating & Cooling
Hi, my radiator fan comes on as soon as i start the car. Alos when i switch on the airconditioner the fan stops working..theres 2 fans actually and only one works.. dont know what might be the problem
one fan is for a/c and the other is for the rad.the a/c fan will come on if the a/c is turned on or if the heater mode is on defrost.this is normal operation.turn a/c off and change mode to anything but defrost.now no fans should be on.
Mar 09, 2011 | 1994 Toyota Camry
Amana AFB2534 freezer is regularly getting frost buildup at the back. first 2 times it was so bad that it blocked the vent & prevented cold air from reaching the refrigerator. Freezer just doesn't seem...
This is either of three defrost parts. The timer, heater or defrost limit switch. Most amana's I fix have a bad limit switch which is clipped to the freezer coils directly. Spin your defrost timer till it clicks and check the same frost laden wall to see if the frost starts to steam and melt. If not, unplug the fridge, then try disconnecting the limit switch and join those 2 wires together. Replug and see if the heater starts steaming. If it doesn't it is most likely the timer. The heater is usually the last thing to die, unless your heaters are encased in glass. In which case a quick visual inspection for decay and separation will pinpoint the problem.
Mar 05, 2010 | Amana AFB2534DE Bottom Freezer French Door...
I have a amana ptc123B35AJ split unit. Used very little had heat on the other day than turn off. the heater came back on in the off position so I unplug from wall. Today I plug it back in but will not come...
theunit is in freeze protection.what you need to do is hold the t-stat buld to bring the temp up and it will come back on shortly.dont unplug the unit.when it gets to cald it goes into freeze protection so pipes in house dont freeze
Jan 12, 2010 | Amana PTH123B25AJ Heat Pump Air...
Looking for manuel reset on heater amana ptac unit heat won't come on new control board
I dont know about this model but in general electric heat wont have a reset button the heat is controled by a sequencer and each elememt has a safty limit switch incase the sequencer sticks in the on mode here is a link to where you can get more info on this model http://www.fixya.com/support/p51773-amana_ptc153b35aj_air_conditioner
Oct 30, 2009 | Amana PTC153B35AJ Air Conditioner
Amana #srd2555w bought from a friend in working condition. 3 yrs old brought home on its side. vacumed coils working 3 days then stopped cooling in fridge followed by ice build up and not working in...
You have a defrost problem. 3 parts: Timer (or "adaptive defrost control"), defrost heater and def. termination thermostat.Find the timer, it shoud be nehind the bottom front grille to the right on Amana (if you see a blck box under there with a sticker on it, it's the ADC model) turn the timer CW until it clicks. Take the back off the bottom of the freezer and listen. After 5-10 minutes if you hear the sound of the sound of water hitting a hot grill. If you hear this the heater and thermo are working and the problem is the timer/ADC. No hiss? Unplug fridge. Check thermo and heater for continuity. Replace the one that's open. If the heater's open, replace the thermo too: Maybe it didn't open soon emouhg and caused heater failure.
Sep 25, 2009 | Amana SXD524VW Side by Side Refrigerator
The air from the airconditioner and heater only will blow out the
Sounds like a vacuum leak. Check the vac supply on the intake manifold. Passenger side front of intake.
Jun 24, 2009 | 1997 GMC Safari
Amana arb-190zc not defrosting
Im sorry, its not defrosting? I suppose you have unplug it, it will defrost eventually.
Jul 28, 2008 | Amana Refrigerators
Heating & Cooling Logo
140 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
