Question about Belkin Computers & Internet
Modem is set up but does not connect to aol - Belkin Computers & Internet
  • Belkin Master
  • 6,487 Answers
You need to contact your Internet Service Provider for them to setup the modem properly and also to put some information of your modem to their system in order for it working and provide you internet...
Hope that helps.......
Posted on Oct 05, 2008
Can't locate a Modem connection
Ok, First off, Yes, if you have a plug in the back of your computer that allows a standard phone connection wire from computer to the wall, that usually means you have a modem. If you have the ability to get Broadband internet, my suggestion is to get that instead. Its more reliable and doesnt have an automatic disconnect feature that AOL has always had. Also, if you already have broadband, then you can connect with AOL directly through the broadband connection and skip the Modem use entirely. Best i can tell you, other than if your computer is not finding the modem, that means its been either disabled or is missing the drivers.
Oct 29, 2008 | Dell Dimension 2400 PC Desktop
The speed i get through this modem from aol is diabolical only 0.44 can you please help me the modem number st586vb peterlane06@aol.com
The problem is not your modem.
The problem is your internet provider connection.
However, if you refuse to take my council you can call AOL as a paying customer and ask for help tweaking your settings which they will help your for free.
After you have spent hours on the phone to no good result, you will change internet service providers *S*
Thank you and good luck.
Oct 26, 2008 | Computers & Internet
NetGear DG834G Router
First use the Netgear setup wizard:-
Open Internet Explorer
Enter http://routeraddress e.g http://192.168.0.1
Click Setup Wizard (top left)
Then for With AOL make sure you have set these values in the Netgear
ADSL settings as PPPOa
VC 0,38
MTU setting to 1400
If you still have problems
Start -> Control Panel -> Add/Remove Programs -> select AOL Connectivity
click Add/Remove -> use the repair option
Follow instructions to repair.
Once complete make sure modem is configured and switched on and
try restarting AOL.
It should search for your connection, find it and allow you to log on.
Feb 06, 2008 | NetGear DG834G 54 Mbps 802.11g Wireless...
Speedtouch 576
Have you tried to reset the device using a pin or paperclip, this should restore the device to factory settings and allow your new internet service provider help you with the setup to connect to thier service.
May 12, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Thomson SpeedTouch 576 wireless modem router
Connect your wireless modem router Sign on to AOL. Download the AOL Easy Installer for Thomson 576 Wireless Modem Router. When prompted to save the file to a location select an appropriate place (desktop is a good example). Once the AOL Easy Installer is downloaded, double click the file: ST_V1.exe This will launch the modem router installer and show the "Welcome" screen. Click the Start Installation button to continue. If you wish to cancel, click the Cancel Installation button. Read the next page carefully. The text advises to close any running programs, ensure to close your AOL software also. Click Next to continue. Please Note: Connect a DSL filter to each telephone socket that is in use for telephones, dial-up modems and fax machines, etc. If you require additional DSL filters, order online at AOL Keyword Broadband Extras. Notes: Ensure to use AOL 8.0 or above. The AOL account to be used for the modem router set up must be a General (18+) account. This installer is not supported with a modem router containing beta firmware.
Apr 24, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Belkins router not connecting to cable modem
You need to start from beginning. Clear all temp internet files and run this programme Start>Run ipconfig /flushdns and hit enter. Get into the routers settings(probably 192.168.2.1) and ensure in the Lan settings that 'DHCP Server' is on and wireless is enabled.(you might need to be connected by RJ45 lan cable first) If it's a 125mbps router change settings to 54mbps to try that speed first(especially as your wireless cards will be 54 mbps) look in Mac address Filtering is off. Look in the DHCP Client list and see if your pc's were allocated ip addresses, if so it should allow an internet connection. Go to both your pc's wireless cards properties and under TCP/IP properties ensure obtain ip address automatically is checked. Restart both pc's and the router, disconnect cable and try wirelessly
Mar 07, 2007 | Belkin (F5D9230-4) Wireless Router...
AOL DSL Plus
AOL DSL+ now uses PPPoE for authentication bypassing the client software. To set up your router: Step 1 Log into the web-based configuration of your router by opening a web browser such as Internet Explorer or Netscape and enter the IP address of the router (192.168.0.1). Enter admin for username and then your password (blank by default). Configure the WAN side to use PPPoE. Please consult your manual for login instructions since all routers are not the same. Step 2 Enter your screen name followed by @aol.com for the user name. Enter your AOL password in the password box. Step 3 You will have to set the MTU to 1400. AOL DSL does not allow for anything higher than 1400. Step 4 Apply settings. Step 5 Unplug (turn off) the power to the modem and router. Wait 1 minute and then power on only the modem. Wait about 1 minute and then power on the router. NOTE: If you connect to the Internet with a different Internet service provider and want to use the AOL software, you can do that without configuring the router?s firewall settings. You need to configure the AOL software to connect using TCP/IP (LAN). Contact AOL for more specific configuration information of their software.
Feb 16, 2006 | D-Link DI-707P Router (DSDLDI707P)
AOL DSL Plus
Feb 16, 2006 | D-Link DI 707P (DI-707P) Router
Internet connection provided by AOL DSL Plus
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Computers & Internet Logo
26 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
