Question about Whirlpool MH7130XE Microwave Oven
Model #mh7130xe made grinding noise then in line fuse blew
Unit made loud grinding noise then the inline fuse blew behind touch pad.unit is a 1997 whirlpool
  • Whirlpool Master
  • 9,098 Answers
Did you replace the fuse yet?
Did the new one blow?
If so, and if it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If so, and if if it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the new one did not blow, and the microwave still makes a growling or grinding noise, but does not heat, you probably have a shorted high voltage diode or a bad magnetron.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Oct 07, 2008
Neither the oven's display nor the oven operate why?
Sounds like you have a blown fuse. Sounds also like it is an over the range unit and you definitely would need help if you have to take it down to work on. Depending on the brand and model, the fuse should be behind the touch panel somewhere. If you put in the brand and model with your question, it did not come through, so I cannot be more specific as to how to get into where the fuse might be located.
Jul 23, 2015 | Microwave Ovens
Panosonic Microwave convection Model NN-8501V Touchpad appears dead
The unit has a fuse in the power board, but when the fuse is gone it does not even start up. If it starts it is not the fuse.
Look rather a problem with a faulty touchpad, or the magnetron that is not working and need to be changed.
Check also the door sensor.
Oct 03, 2008 | Microwave Ovens
On the touch pad numbers 3, 6, 7 and 0 dont work
sounds like the touch pad control has failed ... there is a touch pad on this unit and also a control board located behind units touch pad... you can gain access to this by unplugging unit and removing console that houses touch pad /clock assembly ... once removed the only test there really is to do would be with power off remove ribbon cable to touch pad and make sure clear of any dust /debri and reconnect there are 2 small holes in ribbon cable that are used when reconnected fir into small slots and firmly connect... if that doesnt fix i would recommend a new touch pad... not sure what area your located... there is a distributor for sharp in dallas ,texas called
global micro parts... reputable company that if you give them your model number they can assist you with the part.... good luck to you
Jan 27, 2011 | Sharp R305KS Microwave Oven
KitchenAid KCMS1555RSS - display completely blank and does not function. Is it worth fixing?
i would try and see if the fuse is blown in unit ... normally behind control panel there is a in line 20 amp fuse that may have blown.... if the unit makes noises when you touch the buttons but no display then you have a bad control board assembly
Jan 11, 2011 | KitchenAid KCMS1555RSS Stainless Steel...
Microwave making loud noise while heating food. And food does not get warm or hot.
sounds like the magnetron has failed on this unit...it is located in side behind the control panel touch pad and if replaced usually requires disassembly of the outer shell of microwave... it is a common problem with microwaves and can be fixed just requires taking apart unit to do it...good luck to you
Jan 09, 2011 | Kenmore Microwave Ovens
Microwave MH7130XEB-2 stopped working while cooking. Is now dead. Check plug and breaker box, they are ok. Is it an internal fuse? If so what part # do I need?
Hello :
Problem with the power transformer or the power PCB . Or it could be just a fuse . You need to check first . If it's the fuse , then that will be easy to solve , you need only to replace it with new one . But if the problem is with the transformer or with the PCB , you need to take your microwave to the service .
You could check for manual here :
Whirlpool MH7130XE Microwave Oven manual .
good luck .
rate please !
Mar 19, 2010 | Whirlpool MH7130XE Microwave Oven
While unscrewing a light bulb under a microwave a fuse blew out theirs power to the microwave but it wont turn on
you are more than likely gonna hate my answer
fist thing i would check is your inline fuse
depwnding on the model
unplug the unit
open the door, remove the screw holding the control panel in place, lift the panel up and out
do not disconnect, let hang
you should see a grate right behind the control
behind that grate you should see your fuse
looks light a little metal tube
Oct 10, 2009 | Microwave Ovens
My 1450 blew the in-line 20amp fuse, just
sounds like the H.V. diode,capacitor,or mag is shorted first 2 items are cheap, the mag gets pricey, call "Appliance Parts Pro's" they can help you on parts great prices and fast shipping
Jul 27, 2009 | Sharp Microwave Ovens
Blowing fuses
[double post]
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
But I would wait until the authorized servicer gets there (or take it to them) to maintain your warranty.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 02, 2008 | Maytag MMV5207A Microwave Oven
Microwave made loud popping noise
The magnetron is bad. Probably cost about $50 or $60 for the part. Not too easy to replace, but it can be done.
Dec 13, 2007 | Whirlpool MH7130XE Microwave Oven
Whirlpool MH7130XE Microwave Oven Logo
177 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
