Question about D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge
Im having a problum
I have hocked ur wired router up and im getting internet on one computer and not the other
  • 1,689 Answers
Without being there to carefully look through the networking setup, I will speculate about this.
A simple thing to check is to see if the computer that is not seeing the net is set to DHCP, and that it properly sees the router to start with. Go through the network setup and compare it to the working computer.
Do the command for ipconfig at the system prompt. Use the /all switch to see that the IP address of the modem is displayed. You can compare this to the working computer.
Sometimes a conflict with the firewall can cause such problems.
Another suggestion is to check to see if your modem or internet service has MAC address filtering applied. Some internet services apply MAC address filtering because they want to charge a fee for each additional computer that is on their internet service.
Jerry G.
Posted on Jan 02, 2009
Amp turns on but no output
1 make sure its hocked up properly .2 see i if the protection comes on.. with out the speaker wires hocked up if it does the u have a bad amp.3 if the amp protection light is off with out the speaker being hocked up and after hocking up the speaker it comes on the u have bad wiring to your speaker or a bad speaker
Jun 14, 2013 | Jl Audio 500/1 Car Audio Amplifier
Is it possible to connect PC wirelessly? If so, how? I can connect via wires but prefer wireless.
Hey william,
Ok. A portible computer can connect wirelessly as long as you have a router from a supporting cable provider. what this means is lets say you have cable They will set you up with a router like any other company. This router pravides a wireless adaption to your computer that can last about 3 floors up and 3 miles away. Click the bars on your task bar and click "scan for available connections" and choose your connection. sadly you can only go wired but after that get a yellow support wire and plug in to the computer and hock it up to the TV and put the computer`s sleep mode off. this sleep mode will basicly turn off all programs and go to sleep cutting off the internet on your TV.
Apr 28, 2012 | Panasonic TH-50PZ77U 50" Class Plasma HDTV
Ps3 nat bs purdon the french!
I had the same Problem with a Linksys WRT54G router had to get different router to fix it for me
Feb 24, 2010 | Sony PlayStation® 3 (60 GB) Console
Ps3 nat bs purdon the f858ABAD4 rench!
My computer shows connected but I can't get online I have a wireless netgear card in the laptop and a linksys router. I can see the network, and the computer shows connected with the icon at the bottom and...
check that u have properly configured ip address
gateways and dns
try pinging gateway if u get ping then try pinging ur dns servers.
if u get ping from dns server ur brouser might got curropt if not you need to reconfigure ur wireless router.
Feb 06, 2010 | NetGear (IM-WG511T) Wireless Adapter
I have 2 laptop computers with built in wireless and I am trying to connect to internet via a D-Link 615. I have tried multiple things but it keeps telling me that my cable is disconnected and I have no...
HI. you have to check first what kid of modem u have.. im sure if the laptop is connected directly to the modem, u have a wired connection and u can connect to the internet.. if ur modem is a cable modem, u need to mac clone the mac address of the computer that can connect to the internet. u need to connect the computer that can connect to the internet to the router and do a mac clone and the internet connection settings is dhcp..if u are using a username and password to connect to the internet, u need to use the pppoe settings on the router, and if ur isp give u a static ip address, u need to set the router on static ip. how u can check the ip address, click on start, run and type cmd and it will show a dos prompt, type ipconfig/all and it will list the ip address, subnetmask, default gateway and dns server.. u need to setup the router first in order to talk to ur modem..
Jul 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I dont know what my computers name is? Help!
firstly u r not scanning 4 ur computer, u r searching 4 ur modem router, oh it needs 2 be a wireless router, secondly you need to goto the internet bit on ur psp and go into that, it will usually prompt you to scan. im hopin you know the basic ins and out of the psp, or read the manual. thirdly once it has scanned and comes up with a load of access points use ur intuition, is ur provider bt? tiscali? etc,,,and look 4 the one with the best signal, thats probably urs. lastly u need to know the wep key wen it prompts u 4 the key, u will find it on the underside of ur router or modem or wateva u use, its usually a combination of numbers and letters code. hope this helps.
Apr 08, 2009 | Sony PlayStation Portable (PSP) Console
Hard Wired Port Problem
please dont assign any manual addresses in ur computer..let it be automatic...
u said that u connected the computer to Ethernet ports in the router...
check whether the light are lit in the router corresponding to that particular port..
check the ip address to that particular computer(hard wired to the router)
ip address should be or 101 or 102..if the ip addres comes in this range means its working good...
if ther is no ip means please follow this steps...
1,connect the blue cable between the computer and the router(any 1 of the 4 ports in the
2,connect the other Ethernet cable between the Modem(came from ur internet people) and the
Router's Internet port(standalone port at the back of the router)
3,In the rear panel of the router u can see the reset button.with the help of the paper or
ball point pen,press it hardly and hold it for 1 minute..
4,Now turn off ur modem and the router..wait for other 1 minute..
5,turn onn only the modem first and wait till all the lights turn on the router and wait
till the power light is the internet Explorer it should work..
May 31, 2008 | Linksys Wireless-G WRT54GS Router...
Kicked off x-box live whenever more then one x-box is hocked up to internet.
make sure u dont have more than 3 pc connect to router i have service with roadrunner and i am only allowed 3 pcs or xboxes connected to them
Apr 29, 2008 | Microsoft Xbox 360 Console
Im haveing a problum hooking it in
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
Apr 07, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Open Questions:
See all D-Link DI-604 4-Port Cable/DSL Router (DI-604) Questions
D-Link DI-604 4-Port Cable/DSL Router (DI-604) Broadband (di-604 (dont quote)) Bridge Logo
160 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
