Question about Refrigerators
I have a bottom drawer freezer in my refrigerator and it is making a rattle/ratchet sound when closed. It stops when I open the freezer drawer.
  • prfraker Oct 05, 2008
    Thanks for the quick response....good thought. In the past, it seems I could correct the sound by opening the door and then closing it again, ice would then drop in the ice maker and the sound would be gone. That has not worked this time. Any other thoughts?
  • 943 Answers
Hi .thanks for the question . i would look at the fan in the freezer. it sounds like the fan is hitting ice .check the fan , thanks the appliance doc
Posted on Oct 05, 2008
Whirlpool gold French doors freezer in the bottom it's making a knocking or rattling sound like it's coming from the back panel in freezer open freezer it stops close it starts
SOUNDS LIKE YOUR FAN MOTOR IS EITHER LOOSE OR THE MOTOR IS ABOUT TO GO OUT(NOISE INSIDE COULD BE GEAR IN MOTOR GRINDING WHILE WORKING) it stops when you open the door which shuts off he fan motor to help prevent loos of refrigerated air.
Dec 04, 2016 | Whirlpool Refrigerators
When freezer drawer is closed, very noisy. Noise stops when you open freezer door. Is is the fan?
It sure sounds like the fan is either just going bad or there is possibly is hitting the blades. if it is a buzzing sound then ice is probably the problem. if it is a rattle or squeal then the motor is bad.
Mar 13, 2015 | Samsung RF4267HARS Stainless Steel French...
The bottom freezer drawer is not closing so the freezer is getting an ice build up
It sounds like you either have a drawer that's off track, or something has fallen behind the drawer, not allowing the drawer to close. Empty the freezer, and pull the drawer all the way out. Look behind the basket of the drawer and see if some thing has fallen behind it. If nothing is behind the drawer, then the drawer must be off track. At this point, you'll need to pull the drawer out to the most extended point. Now push the drawer back in about 3-4 inches an **** it open fairly hard. Not hard enough to move the whole refrigerator. Just enough to put the drawer back on track. Hope this helps. : )
Apr 24, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
I get a constant rattling noise out of the back of the regrigerator, UNLESS the freezer drawer is open, then it stops instantly
From your description it must be the drawer that is rattling against a wall or shelf. You may have bent something or lost a damper. Openclose it to see at what level it rattles, then see if you can tape a piece of sponge where it hits against something.
Mar 18, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Jenn-Air JCB2059ES refrigerator makes weird noise
Sounds like the plastics are just rubbing from vibration. redistribute the contents of the drawer and see what that does. Good Luck.
Nov 21, 2009 | Refrigerators
Making a sound like fan is hitting something stops when pull open the drawer and ice tray
For me it was easy to fix. Ice had built up around the fan. I removed the bottom drawer. And remove the plate over the fan. That's the one in the back. 2 screws. remove the ice. Like new. The reason noise stops when you open the drawer is that the fan stops when you open it.
Oct 23, 2009 | Sub-Zero 611 / O Bottom Freezer...
Freezer making grinding noise ice maker not working
Sounds like the icemaker may need to be replaced. When you open the freezer drawer it cuts power to the icemaker.
Jun 18, 2009 | Maytag MBL2256KES Stainless Steel Bottom...
Trio 596.76502500 Mystery Noise
Does the noise only occur when the compressor is running ? My unit has this problem, similar symptoms to your unit, they stop when the freezer door is opened, etc., Several service calls have not completely eliminated it - yet ! The problem seems to be that the compressor coils are too close to each other and rattle. Adjusting them helps for a awhile.
Jul 31, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
110 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
