Serpentine belt replacement
There are 2 belts on the vehicle. It is EXTREMELY crirical to make sure you make a diagram of exact path of belt through the pulleys before removing it. If you dont, You will find it difficult if not impossible to figure it out after the fact. If you place it back wrong and it manged to fit severe engine damage could occur.
Standard procedure for any vehicle is to release tension on the tensioner pulley first'
This is accomplished by releasing tension on the pulley it is spring loaded and will release by placing the appropriate socket on the
pully and turning to release tension. (This can be difficult secondary to inadequate clearance. Lisle tools makes a tensioner pulley tool that I consider absolutely necessary.) then slip the belt off while maintaining force to keep tension off. release tension on tensioner again for clearance make sure belt is aligned properly on all pulleys befor you close the hood(bonnet).
ulley tool and I consider this tool essential
SOURCE: how do i replace the
You loosen brackets on tensioners (they look like rollers) and belt slips off when they're loose. NOTE: make a note of how belt is routed before you take it off. If not it's like figuring out Rubics cube
