Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
I have a SONY FD Trinitron WEGA KV-40XBR800 TV that will not turn on with the power button. Sometimes it will turn on if you hit the power button and quickly hit the tv button,then it will turn on and work just fine, but this will not work all the time. When it will not turn on,the red standby light will blink 6 times continously. I would appreciate some help. THANKS, JOHN
  • 10 more comments
  • billyb_hall Oct 11, 2008
    same problem except mines 36"
  • Anonymous Nov 05, 2008
    im having the same problem.. just to get it fix cost up to $430.... this is crazy.... im never buying a sony tv again..I will tell family and friends to do the same.
  • smauric Nov 08, 2008
    Sony KDFE60A20 I have the same problem. Red power light blinks six times and TV set will not turn on. I am frustrated.
  • Anonymous Nov 16, 2008
    Yup! Same thing here...At first it would shut off and red light would flash for a while until the pic would eventually come back on. Then it got worse and wouldn't come on at all. The cost to fix it is more than the cost of the TV in 2002. How frustrating...I've already fixed it once for a seperate issue. grrrrrrr! Nice TV while it lasted. I'm going HD.
  • Anonymous Nov 23, 2008
    Mine developed this problem shortly after I bought it. I just dont turn it off. I switch to one of the videos, so the screen goes dark. Every now and then, Ill turn it off. Sometimes it turns back on immediately, sometimes it takes days. I hate this TV!
  • Anonymous Dec 11, 2008
    mine blinks 8 times I press the power button nothing and noonoe willcome repair it.
  • dkramcha Dec 27, 2008
    I have the same problem with a Sony kv-40xbr800.the standby red light(of death)blinks 7 times ,the tv degauss,makes several clicking sounds but it remains as dead as a door knob.
  • Anonymous Feb 15, 2009
    sony trinitron tv worked perfect..but after i turned it off..it will not turn-on..no redlight for power or anything..nothing....
  • franksolomon Feb 27, 2009
    pretty much the same problem,but mine blinks 7 times, sometimes 6.If I do get it to come on I'm afraid to turn it off cause it takes forever to come back.I even scheduled service and noone showed or called!
  • rdagusto Mar 29, 2009
    I just resolved this problem with the help of some of the postings on this site. Thanks! I ended up replacing both of the DIP IC's on the "D" board at a cost of $10. There are two Shindengen MCZ3001D on this board that have a high failure rate. I purchased a couple of replacements on ebay and now I'm all set. I highly recommend doing this only if you have experience in removing IC's from printed circuit boards. Otherwise you can cause more damage than you bargained for.
  • Anonymous Apr 16, 2009
    My Sony Wega Tv will not turn off.
  • Anonymous May 07, 2009
    I have the same problem on my 36" sony wega tv.
  • 61 Answers
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Dals123
Posted on Oct 15, 2008
My sony wouldn't turn on so I called a local tv repair; costs me 256.00 for a circuit mcz3001db(shindengen) works fine now but I think I was ripped off; however, I certainly can't repair myself what I don't understand, so left it to the "Pro" at least he left me the part so I know he really did change something. This has been a great tv so far.
Posted on Jul 03, 2010
3 Suggested Answers
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
  • 115 Answers
SOURCE: Sony FD Trinitron WEGA KV-32FS120 timer flashing 9 times
WARNING- VOLTAGES STORED INSIDE YOUR TV CAN KILL YOU EVEN AFTER ITS BEEN UNPLUGGED FOR DAYS..your problem is in the zero cross detect circuit . youu should take it to a repair facility. -Or replace diode D647 . Or on remote in this order press "display -5- vol down - pwr ." and then you could watch it right now ..kinda
Posted on Oct 01, 2009
Testimonial: "Thanks for the amazingly quick response. This is very helpful information."
Sony kv-40xbr800 blinks two times
  1. Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Jun 09, 2012 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sony WEGA KV-40XBR800 Standby light blinks seven times when trying to power on, will not turn on
there is a problem on the power supply section of your tv.try to check the regulators horizontal output,and bad capacitors.
Jun 14, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
The standby light keeps blinking and tv won't turn on
when it blinks 6 times,you have to replace an ic.
its named mcz3001d and is located near the flyback transformer.when you heat it up ,the tv will work.
so you can check if that is the problem
Apr 07, 2010 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sony wega tv won't turn on. The standby light blinks six times..
sorry, 6 blinks is a bad board!!!will cost around 1000 bucks,just by a new set
Oct 09, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
HELLO I HAVE A SONY 40XBR800 TV. WHEN I POWER THE TV ON THE STAND BY LIGHT STARTS BLINKING AND THE TV DOES NOT COME ON
My Sony XBR800 won't start and the standby light blinks 7 times with a 3 sec. interval before blinking again.
Aug 30, 2009 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sony FD Trinitron KV-40XBR800 wont turn on
30 YR SERVICE TECH.
YOUR UNIT IS EXPERIENCING A POWER SUPPLY FAILURE.(INTERNALLY)
TAKE TO A SONY AUTHORIZED SERVICER.
Jan 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KV-40XBR800
You have the famous regulator problem, or the bad regulator problem, or the cold solder connectioin is on or around the flyback transformer.
Sep 09, 2006 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
7,719 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
