Question about Toshiba 36A40 36" TV
Television response. Hi guys, my problem is that my t.v. responds occasionally to the remote. Most times not than usually. It's not the remote as i've tested it on my other t.v. and it works fine. can you help?
  • 1 more comment
  • Dreammaker5 Oct 06, 2008
    Thanks for the advice kevin, but i forgot to tell you that my t.v. model# WAS 19A20, an older t.v. model. Sorry about that. would the answer still apply to this model t.v.? Thanks again.
    Thanks a million Kevin once again kevin,i was going crazy trying to figure out what the problem was. I thought it was some electrical interference in the room that was causing it. Thank You!!!
  • Knoxy1 Feb 22, 2009
    I have the same problem, but the remote no longer works at all on a Toshiba 32" ? TV. Remote: CT9952 The Tv worked fine manually, until the channels were reprogrammed recently. Now we cannot get Channel 3 without the remote- which does not work..... Any ideas? I'd prefer not to get another tv. Where would I look for an add on port- for the previously mentioned sensor?
    Or is there another way to change the TV to channel 3? It skips by Channel 2 and 3 when using the channel buttons on the TV.
I have a Toshiba 36ZP 36 inch TV Repair, no picture and it kept flicking up and down with blue screen..any hlp please.
Jay
Posted on Oct 30, 2008
  • 69 Answers
Its the IR sensor. You could go the DIY router and solder a new one back on, or buy an add on one if your set accepts it.
Posted on Oct 05, 2008
  • Kevin Croissant Oct 06, 2008
    You could do the re soldering to any age tv, though i must warn you, as i forgot, always make sure NOT to use a coldheat soldering iron if you do! they put out raw voltage, and can kill the tv. The addon IR can only work for some TVs that have the ports for it. Also, Try cleaning the copper contacts leading to the IR sensor with an eraser and see if it works better.
    Hi again DreamMaker5. I was just following up to see if you got this fixed. I hope I was able to help.
LCD2710HDAF television will not respond to remote control
Hi Alan,
Here are a few steps to troubleshoot.
1) Make sure that the new batteries are correctly installed.
2) Make sure that there is a line-of-sight between the remote and the TV while operating.
3)Not recommended- but might work. Give your remote a little shake. If there is a small circuit loose connection it will be adjusted. :P I do this all the time.
4) Buy a new remote. You can buy a universal remote which are available on the market. They are cheap. It will NOT be harmful to your TV.
OR
you can buy a genuine one.
May 12, 2014 | Televison & Video
I have a Sony KDF-55WF655. I think the IR sensor is going bad. My remote occasionally stops working for no reason. I have tried numerous different remotes, but I get the same problem no matter which...
Hi:
The IR receiver inside the television is becoming intermittent and needs to be replaced. You might also check the connections on the receiver small circuit board for cold or loose solder joints.
Sep 09, 2011 | Sony Grand WEGA KDF-55WF655 36" Rear...
My Harmony 890 remote has a difficult time inputing numbers
Hi. This problem is caused because the 'repeat' setting on the device that you use to change channels (TV or cable box) is too high.
1. In the software, click 'Troubleshoot' next to the icon for the device that you change channels on.
2. Select '<device> responds to some commands either too many times or only occasionally' and click NEXT.
3. Decrease the setting by one (the default is usually 3).
4. Update your remote and test it.
Apr 25, 2010 | Logitech Harmony 890 LCD Remote Control
Try to locate the line of sight sensor on your TV that does not respond to the remote. The lack of response indicates that the sensor on the TV needs to be cleaned. It does not take much (dust, wax, cleaner residue) to block the signal.
Jan 13, 2009 | Televison & Video
No response from remote
user manual
FINALLY no need to thank me
User Manual
Aug 31, 2008 | Televison & Video
Remote problem could arise from either tv or remote. First check your universal remote on some other tv and if it is okay your tv's infrared sensor has stopped working. You can get it from the local component shops, take the existing sensor with you. This problem could be from the micro processor in rare cases. Best of luck.
Jan 27, 2008 | Panasonic CT-32SL14 32" TV
Television wont respond on/off
Sylvesteru8
I do not see any customer support phone number.....
What EXACTLY did the management of Wal-Mart tell you
Chicken217
Dec 10, 2007 | iLO 3200 32 in. LCD Television
Check whether the remote control is working properly or not by using remote checker. Even if it is the universal remote control you have to set the code for the particular model. Otherwise it will not work.
Sep 17, 2007 | Panasonic CT-32SF37 32" TV
Remote control
Without a name, thats almost imposable my friend. Try a Good universal on the manual search. maybe you will get lucky and the remote will work. Good Luck
Jun 14, 2007 | ViewSonic NextVision N4000WP 40 in....
Toshiba 36A40 36" TV Logo
119 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
