Question about Kenmore Dryers
Kenmore gas dryer does not get hot
Kenmore model 110.72812101. Spins, etc., but no heat. ?
  • 943 Answers
Hi. thanks for the question .check the thermal fuse, at the back inside the dryer. remove back panel .thermal fuse is on the air duct , a small piece of plastic with 2 blue wires to it. replace the fuse also clean all venting .thanks the appliance doc
Posted on Oct 05, 2008
Kenmore model 110.63942101 (electric). everything works but no heat... drum spins, timer works. Should I buy heating element replacement kit? does it need to be installed from the back of the dryer...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 19, 2011 | Kenmore Dryers
Dryer spins but doesn't get hot. Model #11077522600
heatman101
Sep 09, 2011 | Kenmore 73952 Gas Dryer
Hi, i am experiencing issues with my Kenmore 80 series , model no. 110.76832500, natural gas dryer. The issue seems to be overheating or a faulty sensor. The dryer heats normally and spins fine when first...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 06, 2011 | Kenmore Dryers
Hi. I have a Kenmore Dryer Model #110.86870100. The dryer spins and times but it doesn't get hot. Thermal fuse? Heating Element? Both? Too, where can I get visuals of this Dryer for the "how...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Apr 19, 2011 | Dryers
Kenmore gas dryer model #76812690 will not heat.
does the dryer heat initially when you first turn on the dryer Or no heat at all?
the first thing i would check is tthe thermal fuse thats located on the back of the unit. test it with a multimeter and see if it has continuity, if it doesnt then replace that and your operating thermostat. the check to be sure you venting to the outside of your house is not clogged
Apr 29, 2009 | Kenmore Dryers
My Kenmore gas dryer wont heat up.
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor READMORE
Dec 29, 2008 | Kenmore 73952 Gas Dryer
My Kenmore Elite dryer spins with no heat
please check the thermal cutoff. these are the parts with 2 thick wires attached to it. they are normally located near the heating element ( if electrical ) and (near the exhaust if it is gas).
these parts control the heating element.
tnx 4 using fixya,
drcool
Nov 05, 2008 | Kenmore 73952 Gas Dryer
Dryer not getting hot
fist make sure the fuses are good.. unit will run on 110 but not heat.. check connectores and cables or pigtail. it not.. then check heater coils and or thermostat...
Jun 13, 2008 | Kenmore Dryers
Kenmore 73501 Model No. 11097350100
it could be your gas dryer ignitor, flame sensor or gas valve..do you smell gas? can you see the ignitor glow? if you can answer these questions I can help. Thanks
Sep 05, 2007 | Kenmore 73052 Gas Dryer
Dryers Logo
119 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
