Question about Cannon Kitchen Ranges
Fit a striker pin into a cannon c60eks bottom oven door
My lad broke the bottom oven door so i had to purchase a full door and a striker pin seperate, but am finding it impossible to fit this pin and angry with cannon as it should already be fitted after paying £120 for the door please can someone help me with this since cannon customer help is useless
SolutionGuy
  • 331 Answers
SOURCE: fitting a new control switch for the fan oven (model number 10450G)
Sesspod, 2 things... 1.) Pull the oven out and look on the back of it, there may be an envelope back there containing a technical data sheet which includes a wiring diagram. If not on the back, then possibly under the cook top. It is somewhere on your oven, sometimes the hard part is locating it. If you can find it, look closely and you'll see the wiring color and location is labeled. 2.) If you can't locate the tech data sheet, can you post a good macro picture of the back of your new switch so we can see what you're dealing with.
Posted on Aug 11, 2007
  • 833 Answers
SOURCE: KESC307 Oven Door
Hi Mcrae...
Generally, the procedure is a straightforward mechanical one.
First, check below the door for screws and remove them. Next, open the door and find the screws on the side and inside of the door. Remove them. Careful...when the door panel comes off, the door will be much lighter and will slam closed if not restrained. The panel should 'fall away' from the door. Have someone assist you here! At each stage, take a digital picture of the disassembly so you can assist yourself in putting it back. Clean the glass with a blue cleaner and buff out. Use a scrubby or very fine steel wool to gently remove any stains from the old glass you're reusing. Do this on a bedding of newspaper. Always handle glass by the edges.
When installing the glass, it should generally be apparent which way it goes in. Some glasses have patterns on them which correspond to the door opening...if it is the outer which is being replaced. Note them. There may be an up or down as as a result. Any foils or patterns are positioned to the direction you won't have access to later.
You'll likely need a second pair of hands to put it all back together. Take your time. Don't force anything. Tighten screws evenly.
Posted on Dec 03, 2007
SOURCE: adjusting the oven door hindges for a snug fit
i wanna circuit board of inkjet printer and faluts finding
Posted on Dec 19, 2007
  • 2039 Answers
SOURCE: Baby seats ( fitting inyour car with correct seat belt
all cars have lap seat maybe to top and the bottom of the belt are connected together but that our lap belt what kind of car i look at it for you thanks for using fixya pierre
Posted on Feb 09, 2008
aborcass
  • 2651 Answers
SOURCE: The Glass from the front of the oven door is off.
the glass on this door, is held up only by the lower trim, and sits behind the handle escution(very small contact point) as far as the trim for sides, the slip under top esctution,and behind the door glass(sorta keep the glass from contacting the metal frame of door.} much easier to do with door off of unit, refer to manual as how to remove the door if needed
Posted on Dec 24, 2008
Why does the oven door on a 20" Danby stove "bump" as it closes?
check the hinges are not loose or damaged. the door isnt hitting the striker pin is it when you close the door.
May 21, 2014 | Danby DER2009W 20" Freestanding Electric...
I have a whirlpool mh1150xms-3 and the handle is broke! how do i replace it without breaking the glass? i took out the 3 screws on the left side and it wont seperate from the outside case!
Unplug the microwave oven from its power outlet or turn off its circuit breaker. Remove the right fuse from the home fuse-box if your microwave is a built-in model.
Open the microwave door and take the top pin off its pivot bracket. Lift up the door and remove it from the bottom bracket. Lay the microwave door with its front side down on a folded towel. Remove the two choke screws from the door frame using a Phillips head screwdriver.
Remove the choke cover with the knife blade, starting from the microwave door's top right corner. Pry out the bottom and top right sides, leaving the side which houses the door handle in place.
Remove the choke tabs from their slots on the microwave door frame using the knife blade. Continue to work clockwise around your microwave door; remove the choker cover when you get to your handle's side to separate it from your choke.
Remove the two handles with the Phillips screwdriver. Remove the handle from the microwave.
Screw the new handle in the position of the original handle. Lay the choke on the microwave door; set the choke cover right on top of it. Insert the choke tabs into their slots on the microwave door frame using the knife blade.
Secure the two choke screws using a Phillips head screwdriver; set the microwave door back on the bottom bracket. Slide the top pin into the microwave's pivot bracket.
Press the top pin down until it pops securely into place.
Oct 03, 2011 | Whirlpool MH1150XM Convection/Microwave...
I want to know what is needed to change door strikers on a 79 cj7 jeep from the original factory ones to the door pin striker set on like the 83-86 cj7 jeep as these are for full steel doors my email...
the door must be taken apart and the rear welded and reinforced and the captured nut put in a cage that is spot welded to the inside of the striker surface, this is not something u can do at home.
Oct 22, 2010 | Jeep CJ7 Cars & Trucks
Door does not shut flush with oven surround. Hinges could be a problem? (Tecknika)
More likely the door striker pin needs adjustment. You haven't stated an exact model, but on most ovens the pin can be adjusted in and out once a locknut has been loosened and in turn this causes the door to close closer or further from the oven cavity.
Aug 12, 2010 | Photography
Oven door lock pin broke
how did you fix it?? i have the same problem!! :(
May 12, 2010 | Ovens
Oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Apr 13, 2010 | Ovens
Are there replacement door hinges available and how difficult are they to replace
Door hinges are usually available to purchase as a seperate item, you should replace them both together, usually, they are fairly easy to fit.
Mar 08, 2010 | Zanussi ZBM799X Electric Single Oven
Oven door won't stay closed
You don't state the exact model but on every oven I've ever fixed this problem on it's a broken door striker catch. Depending on your model, the catch will either be in the oven door or in the oven body; usually they're straightforward to replace but on older ovens spares can be almost as rare as dodo ****. Usually what breaks is a hardened tempered metal spring, so when they're not available as spares I can usually visit a local spring making company and get someone to make one up as a one-off using the fragments of the old one as a pattern. After the catch has been replaced the striker itself (usually a specially shaped pin) may need to be adjusted to engage correctly once more. Undoing the lock nut and screwing it in and out adjusts the depth, and is done after the striker catch has been adjusted side to side or up and down to meet the centre of the striker.
Mar 04, 2010 | Imperial Ovens
I have a GE Profile Microwave and the handle is broken....
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
May 28, 2008 | GE JVM1190SY/WY/AY/BY Microwave Oven
Kitchen Ranges Logo
83 people viewed this question
Top Cannon Kitchen Ranges Experts
Paul Carew
reyaazm
Level 1 Expert
Tom Chichester
Are you a Cannon Kitchen Range Expert? Answer questions, earn points and help others
