Question about Soleus CFM-40 Dehumidifier
Fan runs, no water collected
Only 1 year old. Used periodically in basement storage room. Worked well. Suddenly stopped collecting water while fan continued to run.
  • 1 more comment
  • Anonymous Jan 03, 2009
    Same problem---I suspect the compressor died. It's only one year old!
  • Anonymous Feb 10, 2009
    Same here
  • Anonymous Feb 16, 2009
    Same thing.
    New Friend:
  • 3 Answers
It appears that these units have a history of defectiveness. I bought one in late 2010 and it pooped early 2012. If the model is still made, buy a new one, return the defective one in the new unit's packing materials for a refund. Or keep the second (new) unit as a back-up, because the new (first) one may just fail again a short while later.
Posted on May 21, 2013
    Scholar:
  • 117 Answers
Possible compressor problem or coolant leak.
Coolant system warranty is usually more than 1 year- check your warranty.
Posted on Jan 07, 2010
The unit still makes a running noise but seems to collect no water. this unit is about 4 years old but stopped collecting water about 2 years after purchase
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 30, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Product is about 6 years old. Used in basement. Worked great until this year. Now will run continuously but collect little water. What type of service do I need? This is a 65 pint per day Whirlpool.
There is some service that you can do ... Clean the filter and the cooling coils, regularly. Check the humidity level that you have the unit set on. It may be set to low and there's just not that much humidity in the air at this time, for it to collect. From what you said, it sounds like you may have it set on continuous cycle which could account for the lack of a lot of water in the bucket. In continuous run, the fan stays ON all the time. It's supposed to do that, so that the air is constantly moving and the sensor only turns the compressor ON, if it senses a humidity level 5% higher than what you have it set for. Try running the unit on a 1 or 2 hour cycle (if your model will do that) rather than continuous cycle.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
May 18, 2011 | Whirlpool 75-Pint Dehumidifier
The unit runs but does not collect any water
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 26, 2010 | LG DH404E Dehumidifier
No water collecting in bucket.
There are many reasons for a dehumidifier tto not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
heatman101
Apr 30, 2010 | Goldstar DH504EL Dehumidifier
A challenge dehumidifier not collecting water
If the room tempature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defost over night.
Only specially made dehumidifers work below a room temo of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensot from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Jan 03, 2010 | Maytag M7DH65B2A Dehumidifier
Dehumidifier does not collect water.
If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Aug 05, 2008 | Haier HDN655E Dehumidifier
Not collecting water
If everything is running and no water is being produced the system may have lost its refrigerant. There are two motors in dehumidifiers. One is the fan and the other is the compressor. Make sure they are both running.
Jun 18, 2008 | Goldstar DH304 Dehumidifier
My unit does not collect water any more. It was fine until I lent it to my brother in law and it was returned damaged. Do you know how to fix this
Dec 06, 2006 | Kenmore 54501 Dehumidifier
Everything works, but does not collect water
I have the same dehumidifer - make and model. I bought it less than a year ago. It too runs fine, but now collects no water. Did you ever discover how to fix the problem?
Sep 04, 2006 | Goldstar DH504EL Dehumidifier
Soleus CFM-40 Dehumidifier Logo
972 people viewed this question
Top Soleus Dehumidifiers Experts
NOEL
NOEL
J.D. Browning
J.D. Browning
Are you a Soleus Dehumidifier Expert? Answer questions, earn points and help others
