Question about Kenmore Elite HE4 Electric Dryer
KENMORE TOP LOAD WASHER - MODEL # 11022422100
Hi I have a Kenmore top load washer , it's about 5 years old the model # is 11022422100. We had a power surge in the neighborhood and all the power went out, while the washer was running. After the power came back on we tried to turn on the washer but it wouldn't drain. The washer fills with water , spins and when it is suppoesed to drain it just shuts down.Theres no sound at all. I checked the pump and it spins freely. The motor shaft rod also spins the propelor freely. When I turn it on now the dial still spins and when it gets to the postion where its supposed to drain it stops. Could this be something with the control panel. I was also told it could possibly be the motor itself or the drive belt, but I'm not sure where the drive belt is. I'm am pretty sure it would be something electrical because of the power surge.
Thanks
Paul
  • 1 more comment
  • paulyes Oct 05, 2008
    Hi would the washer still spin if the lid switch is bad , because the washer still spins , just shuts down when its time to drain.
    Thanks
    Paul
    Hi Doc
    Thanks again for the reply
    Yes the water did drain when I tipped it to at the pump and motor
    Hi Doc
    The water that drains is just excess water in the hose , the thing is that this all happened when we had a power surge , so wouldn't it be the control panel, the motor or one of the components with them. The pump propelor spins freely.
    Thanks
    Paul
  • 943 Answers
Hi. thanks for the question . i would check the lid switch ,on that washer. it could be the problem thanks. the appliance doc
Posted on Oct 05, 2008
  • john gagnon
    john gagnon Oct 05, 2008
    hi .lay the hose down on the floor, in a bucket .see if it drains then
  • john gagnon
    hi then the pump is the problem
What is the capacity of Kenmore model
This may or may not help.
http://www.managemyhome.com//mmh/lis_pdf/OWNM/L0305295.pdf
Nov 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
How do you tell how old a kenmore Washer model # 110.82982100 is?
there should be a date on the same label... it will read the month and year such as 02 or something. it's randomly placed but it is the date.
Feb 22, 2009 | Kenmore 22422 Top Load Washer
Kenmore top load washing maching flipping the breaker
Maybe the breaker is going bad or you have added something else on thatcircuit
Feb 09, 2009 | Kenmore 15864/15862 Top Load Washer
No power to washer
Hi!!! say check your lid switch make sure its good..
Jan 01, 2009 | Kenmore 24032\24036 Top Load Washer
Washer full and then stops and gives a beep while flashing F 51
On Kenmore F51 means Motor RPS Failure, the motor is not spinning or the motor sensor detects a fault.First unplug the power cord for one hour or so to check if it is a jammed sensor, and see if reset.
Dec 06, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore top load washer won't drain
Could be the pump itself or the belt driving it... many of the older type washers run the pump off of a drive belt and many of these pumps get clogged with material so that they do not pump... usually, you can unbolt the pump and seperate the pump casing to access the impellor and clean out the insides.. As always.. be certain to unplug the washer first..
Hope this helps
Sep 21, 2008 | Kenmore Elite HE4 Electric Dryer
Washer stops after wash cycle
the timer is bad you could try cleaning the points by taking it apart very hard to do though
Aug 27, 2007 | Kenmore 23822 Top Load Washer
Kenmore Elite HE4 Electric Dryer Logo
290 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
