Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Music not synchronized
I copy songs from Media Player to the c250. The songs are listed on the computer, but not on the device. Can't play them on MP3.
  • newtechnewbi Oct 05, 2008
    When I look at the 250 menu on MediaPlayer, it lists all the songs that I've copied. Once I remove the 250 from the computer, the songs aren't on it.
  • 3 Answers
If you turn off your SANSA connected, you will have the reported problem.
If your SANSA is in the USB MTP mode ( it is the default mode ), you should disconect your USB cable when the SANSA is on. This is strange but it is the instruction on the manual:
Simply disconnect the SANSA USB cable from the SANSA c200 player after you
have completed charging, transferring, firmware upgrading, or synchronizing
files when you are using MTP mode.
WARNING: Do not disconnect the player while it’s transferring data.
Disconnecting the SANSA device from the computer while data is
being transferred can damage the device.
Another worse way that works is to turn off your computer.
Posted on Dec 19, 2008
Try going to the actual file the music is in on your computer, then right click Send To sansa 250. If that doesn't work look on the options menu for USB mode and change it, that works on my 280.
Posted on Oct 05, 2008
Bought a gpx8gb digital media player for my daughter for christmas. I have downloaded her cd's into itunes library. Now how do I get those songs onto her media player?
Check to see that when you rip a music CD that your music is not copy protected. The RIP function in your Windows Media Player will allow you to convert the music CDs you have purchased into either an MP3 or a WMA format.
To adjust the copy protection setting on your ripped music files,
  1. Open the Tools tab at the top of your Windows Media Player.
  2. Select Options and then select the Rip Music tab.
  3. Choose the type of music file as well as the quality with which you would like to save the music. (Your GPX player has the ability to play music files in both the MP3 and WMA format.)
  4. Make sure to use MTP when transferring copy protected WMA files.
If you are using Windows Vista with Windows Media Player 11, you will need to follow these instructions.
Note: You will be able to download purchased/subscribed songs to the unit.
  1. Start Windows Media Player 11 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
  2. In Device Setup - Configure Sync, write a name for your mp3 player.
  3. Click Finish. The window closes and the Sync feature in the Player is displayed.
  4. From the left pane of this Sync feature, you can select from Playlists or Library and you will see the content of these folders in the center pane.
  5. Select the songs or entire albums from the center pane.
  6. Drag these songs or albums into the Sync List, which is the right pane of the Sync feature.
  7. Click the Start Sync button on the Sync List pane.
  8. Repeat steps 4-7 for any other items that you want to copy to your unit.
If you are using Windows XP with Windows Media Player 10, you will need to follow these instructions.
  1. Start Windows Media Player 10 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
  2. In the Device Setup Wizard, select Manual.
  3. Click Finish. The wizard closes and the Sync feature in the Player is displayed.
  4. Select the Library option. On the left pane select Sync List.
  5. From the left pane you can select All Music or My Playlists and you will see the songs located within these folders in the center pane.
  6. Select the songs from the center pane, and drag them to the Sync List.
  9. Good Luck, I hope this helps
  10. Please rate me, Thank you
Dec 09, 2009 | GPX MW3836 MP3 Player
How do I download music on my mp3 player? I bought the mp3 player(gpxml638b) and it did not have any soft ware. I have the wire to plug from mp3 to computer, but how do I start downloading music?
Sir,
1. Turn on the MP3 Player by holding the PLAY/PAUSE button.
2. Take the USB Cord and plug the corresponding ends into the MP3 Player and a Computer.
3. When connected the LCD Display will either say “USB” or “MTP”.
4. Press the “M” (mode) button to switch between “USB” and “MTP” mode.
“MTP” mode will only work, when your player is connected to Microsoft
® Windows® XP and Windows® Media Player 10.
The MP3 Player will only work in “USB” mode when it is connected to Windows® 98SE, ME, or 2000 Professional.
1. Start Windows Media Player 9 and connect the MP3 Player to your computer.
2. Click “Copy to CD or Device”.
3. In the drop-down list, on the “Items to Copy” pane, click the play list, category, or other item that you want to copy.
4. Clear the check boxes next to any files you do not want to copy.
5. In the drop-down list, on the “Items to Copy” pane, click the device that you want to copy files to.
6. Click the ‘Copy’ button.
7. Repeat steps 2-5 for any other items that you want to copy to your unit.
1. Start Windows Media Player 10 and connect the unit to your computer. On your player’s display it should say ‘MTP’. If not, then while the unit is connected press the ‘M’ (mode) button to change from ‘USB’ to ‘MTP’ mode.
2. If you have not set up synchronization between your computer
and this device, the Device Setup Wizard starts. In the Device Setup Wizard, select Manual.
3. Click Finish.
4. Select Library option. On the right pane select Sync List.
5. From the left pane you can select the Play list or Library and you will see the content songs in the center pane.
6. Select the songs from the center pane, drag and add them to the Sync List.
7. Click the ‘Start Sync’ button in the Sync List pane.
Thanks
Good Luck
Aug 17, 2009 | GPX ML648B MP3 Player
I just want to know how to get music off my computer to the mp3
I have copied the method that GPX uses to transfer your music from PC to player.
If you are using Windows 2000, Windows 98SE, and Windows ME with Windows Media Player 9, you will need to follow these instructions.
Note: You will not be able to transfer purchased/subscribed songs to this unit using Windows Media Player 9. You need Windows XP with Windows Media Player 10 to do so. However, you will be able to download regular MP3/WMA songs.
1. Start Windows Media Player 9 and then connect your unit to your computer.
2. Click Copy to CD or Device.
3. In the Items to Copy pane, in the drop-down list, select the playlist, category, or other collection that you want to copy.
4. Check the box next to any file you want to transfer to your mp3 player.
5. In the Items on Device pane, in the drop-down list, click the device to where you want your music files transferred.
6. Click the Copy button.
Jan 03, 2009 | GPX MW3837 MP3 Player
I got a gpx MW3836 1gb mp3 player. i cant get any music on there from my wondows media player lists. my playlists songs might have been copy rights protected on it. i want toknow how to get my play lists...
Converting wma's to mp3 costs money unless you are getting the songs from an actual CD. Better to get an mp3-only music service like Limewire, Rhapsody Mp3, etc.
-Tha Mp3 Doctor
Nov 27, 2008 | GPX MW3836 MP3 Player
Synchronize to continue your music subscription
it's asking that you verify the DRM status (i.e., that you bought it and it resides on YOUR computer.) It cannot play the file until you synchronize it with windows media player. You can delete them off of the MP3 player just by noting which songs don't play and deleting them through windows explorer when the player is connected.
Mar 25, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
The media device has either stopped responding or has been disconnected
Make sure you're not using the media with another program while you attempt to copy/sync it to your device.
Pretty late response, but meh.
Feb 28, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Lost Music Files
Use Windows Media Player instead
Dec 22, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Music stopped playing "synchronize to continue..."
Your device has to be connected to Rhapsody every 15 to 30 days to verify your account.
If you are connected and signed in, and still receive this message, you should contact Rhapsody Technical Support as the error is on their end. (866-597-5507)
Best of Luck.
Oct 10, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Won't play songs
If you used Windows Media Player to copy the Cd's to your PC the default setting is to "copy protect my music". To change that go to Windows Media Player>Tools>Options>Rip Music and uncheck the "copy protect my music" box. You will need to delete the previously ripped music from your device. Then re-rip the Cd's and transfer them to your device. Best of Luck.
Sep 19, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
