Question about Samsung HL-R5078W 50" HDTV
Color wheel replacement.
Samsung HLR5078W color wheel replacement, step by step procedure.
Possibly with some digital photos.
Thanks, Ed
  • 76 Answers
Here is photo step by step replacement of color wheel.
Hope this helps
Posted on Jul 16, 2009
  • 647 Answers
I have no jumper on my samsung dlp to change colors back after changing the color wheel.
after the color wheel replacement you need to get the restore sequence procedure using button combination of your remote..
try to to this link
and get any of my services..
Feb 03, 2012 | Samsung HLP6163W 61" Rear Projection...
Repair Procedure
Does it do this on every input? Like no matter if its DVD or something else? How long have you had this problem? Are you attempting to repair it yourself or have it repaired? Once I have more information I can assist you further.
Oct 29, 2008 | Samsung HLN5065W 50" Rear Projection...
Replace color wheel on samsung HLP6163W
that needs experience of electricals first
Jun 10, 2008 | Samsung DLP HL-P5663W 56" TV
good day
your problem is in the color wheel..because when the color wheel malfunction or out of timing the color of the screen is not good
color wheel is available at the market you can buy it to or
replacing of color wheel is D.I.Y. its easy for you to perform
watch this video to guide you the proper procedure
thank you and good luck..
Apr 07, 2011 | Samsung Televison & Video
Samsung DLP R&R Color wheel Model #HLR5078w
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
May 02, 2010 | Samsung HLR5064W DLP Projection TV
No picture after replacing color wheel
every time I see this itbis a cable or plug that was left out or one that got pulled on and pulled the connector up out of the plug a little, you need, and not by sight by your hands to go over every plug and connector till you find one.
Larry Dillon
Aug 01, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Replacement color wheel for samsung 50'
I am having the exact same issue with the exact same TV. They no longer make that color wheel, so I am looking for a replacement part as well.
I am looking at the 01103A as well from here:
I think I might just order it, and if it doesn't work just return it.
Jan 15, 2009 | Samsung Televison & Video
Samsung dlp model hl- S5086W making continious humming noise, has nothing to do with volume. Can I replace fan or wheel myself?
Most likely color wheel since most are defective right out of the factory--- someone has a step by step procedure to replace with pictures-- try google- samsung colorwheel -- fun job easy to do!!!
Jan 04, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung HLP4663W Color Wheel
 The color wheel that goes in an HLP4663WX/XAA is:
 This is the correct color wheel.
Oct 20, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HL-R5078W 50" HDTV Logo
1,705 people viewed this question
Jerry Greenberg
Jerry Greenberg
