Question about Enterasys Distributed Forwarding Engine w/12 1000BASE-X Ports (mini-GBIC) ( 7G4270-12 ) (7G427012) Transceiver
Forward ports in linksys wrt45g so magicjack will work
Need to forward ports in linksys wrt45g so magicjack will work. MJ says ports 5060 & 5070. I have entered linksys web based and tried to forward ports but, magic jack still does not work. Just not sure I am entering the right information.
I need detailed instruction on how to forward ports.
Thank you
Larry
  • 6,487 Answers
Check this link it has the step by step instruction on how to do a port forwarding on your linksys router , this is just a sample so what you need to do is just replace the value for the port number of your magicjack... http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/Lingo_VoIP.htm
Hope that helps..........
Posted on Oct 05, 2008
Is it possible to forward calls to my MJ to my cell phone?
I presume your MJ is Magic Jack.
If so, the answer is yes.
You have to go to
http://my.magicjack.com
Login
goto Your Account
Call Features
Forwarding
a screen appears
Enter Phone number and click forwarding ON
Click submit
Your calls will be forwarded to that number from then on
**************** CAUTION *******************
The Magic Jack phone will no longer ring nor receive calls, but you can dial out.
ONLY the number you forwarded it to will ring!!
May 25, 2017 | Lands Phones
I am on auto refill and my magicJack quit working I use for my fax machine and do not get any dial tone. I have tried unplugging etc and still does not work, What is wrong?
Is your Magic Jack plugged into AC wall current with a Power Adapter?
If so, try powering the MJ directly off a USB port on a computer.
The MJ power adapter is prone to failure. On the MJ plus, there is a blue power light in the shape of a cross near the word "plus". That light should be illuminated when plugged into a USB port or a power adapter. If the light is out when using the power adapter, then the power adapter is dead. If the light is out either way, then the MJ is probably dead.
Mar 13, 2015 | magicJack Plus
Script error
On your softphone, please do the following:
1.Click "Menu" on the top right-hand corner
2.Click "Advanced Users"
3.Click "Restart"
If your magicJack is plugged into your modem or router, unplug it from the power source, wait 30 seconds, and plug it back in.
If that does not work:
<Requires some technical understanding. Explanation below. >
Please open port 49152-65535 UDP on ALL firewalls and your router, if you have one. (Router ports can be opened via the web application applicable to your router).
Restart magicJack again by following the steps above.
How to access Web Application for router
1.Start > Run > Type in cmd > Press ENTER
2.A command prompt will open
3.Type ipconfig > press ENTER
4.Make note / write down name of the default gateway and IP address
5.Open your Internet Browser
6.Type in the default gateway IP (Example: 192.168.1.1)
7.Type in Username and Password
8.Find "Port Forwarding" and Forward Port 49152-65535 UDP for the IP address you located earlier.
Apr 20, 2014 | magicjack.com
My magicjack phone stop working since yesterday problems
I assume you mean no green light meaning when you plug the MJ into a USB port the internal light fails? If so, the MJ unit itself has died. You should still be able to access your MJ via the USB port and the dial pad shows up on the computer screen. Even if you did not re-register, the keypad should show up and you can go to the web site to get another 12 months or so. If you have to get a new device, I suggest the MJ+ that allows you to plug it into a computer or directly into the router.
Jan 06, 2014 | Computers & Internet
Won't work with new router
3.Click "Restart"
Nov 23, 2013 | magicjack.com Computers & Internet
I can not get my magicJack Plus to work
If you're using the MJ Plus, it can be connected directly to the computer's USB port, or directly to the internet using the provided adapter. It must be connected properly in order to work.
The MJ program (on the computer) will not work if the MJ is not connected to the computer.
It goes without saying (but I'll say it anyway)... The MJ will not work if you have not paid for at least one year of service.
If you have paid for service, check your connections to ensure nothing is loose. The wall adapter can get loose and disconnect you from service.
Sep 22, 2013 | magicjack.com Computers & Internet
Magic jack error 3
3.Click "Restart"
Mar 02, 2013 | magicjack.com
Magic Jack Phone System...
I haven't had any problems with my MJ, but that, I think, is because I port forwarded MJ. That's what seems to be your problem. You need to port forward your MJ into your firewall/router. If you don't think you have a firewall and/or router, your a noob. All pc have a firewall, at least. Windows has a firewall. If you get your internet connection is from broadband then you most likely have a router with a firewall. Some routers are buit into the broadband modem. Figure out what kind/name your firewall, router, modem is, and go to www.portforward.com. Click on the routers model number, then click on MagicJack. If you just have a firewall, and no router, they have a page just for firewalls. If your not sure what you have then click the "Start Here" link on their first page.
Feb 22, 2009 | Lands Phones
MagicJack VOIP sound cuts in and out
MJ ran fine for me from July 2008 to October 2009, when choppiness and cutouts started and continue to today. This is a MJ network problem, there is no fix in your own computer, as I have tried everything - computers, internet speeds, headset with phones unplugged, other Magicjacks. The MJ servers have just become overloaded. MJ is dead.
Nov 05, 2008 | Lands Phones
Enterasys Distributed Forwarding Engine w/12 1000BASE-X Ports (mini-GBIC) ( 7G4270-12 ) (7G427012) Transceiver Logo
3,284 people viewed this question
Top Enterasys Computers & Internet Experts
George Nalley
Level 1 Expert
Marcin
Nathaniel Berrios
Nathaniel Berrios
Are you an Enterasys Computer and Internet Expert? Answer questions, earn points and help others
