Question about Philips Magnavox Learning Universal Remote
NO SOUND/CLEAR PICTURE
I HAVE A 27' PHILIPS MAGNAVOX SMART PLUS SERIES TELEVISION
NEVER HAD A PROBLEM UNTIL RECENT. THE PICTURE IS STILL CLEAR BUT I HAVE NO SOUND..... PLEASE HELP I LOVE MY TELEVISION AND I THINK IT IS SOMETHING SIMPLE THAT CAN BE RESOLVED. ALSO ALL THE CHANNELS HAVE "MONO" ON THEM WHEN CHANGING THE CHANNELS.
  • 69 Answers
Please do not do all caps. It makes it harder for us to understand your problem.
Check the speaker settings in the menu and in the case, BUT NOT UNTIL IT IS UNPLUGGED FOR ABOUT 10 MINUTES! TVs have caps that hold up to 30,000 volts and take a while to discharge.
Posted on Oct 05, 2008
Can't find install code for philips magnavox smart series plus
Universal remote codes for Philips Magnavox TV are: 0062 0204 0207 0183 0226 0288
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Sep 27, 2012 | Philips Smart Plus TP3285C 32" TV
I have a hdtv magnavox 27 inches flat screen, it does well for a while and the I loose the picture or the sound goes crazy
This television is having problems with intermittent component operation. The components have not failed as yet but will with continued use. This could cause more problems with your television. The television should be test for faulty component operation. The Magnavox customer support telephone number is 1-800-705-200. Tell them the model number of the television and the problem you are having with the intermittent operation of the video and sound.They will be able to help you find a service center to test and repair the television.I hope this information helps you with your problem.
May 18, 2009 | Philips Magnavox 27MS343S 27" TV
Philips magnavox smart series pr1920c601 turning off itself!
well let me ask ya something so it is coming back by its self then going back out may be solder connection okay call tv shop good luck shad
May 03, 2009 | Zenith B27A11Z 27" TV
My tv turns on, but there is no picture or sound. It makes whistling and clicking noises. How do I fix it?
This television has had a problem with component failure. You will need to take this television in to a service center for testing and repair. You can reach Magnavox customer service at this telephone number. 1-800-705-2000. Give them the model number of the television and the problem you are having with the failure of the picture and sound.They will be able to tell you how you can get your television tested and serviced. I hope this information helps you with your problem.
Mar 31, 2009 | Philips Magnavox 27MS343S 27" TV
TV WENT BLACK WITH BUZZING/SOUND
hi the problem is the picture tube of ur television has got damaged.. its better to replace a new picture tube...
Jan 24, 2009 | Philips Magnavox 27MS343S 27" TV
HOW TO REMOVE CLOSE CAPTION FROM SMART SERIES TV
on your remote go to cc push that until it sayes closed caption off not positive but pretty sure
Jan 11, 2009 | Philips Magnavox 20MS233S 20" TV
TV makes "Pops" and "Crackles" sounds from the back while viewing
remove the cover and observe the source of the light. if its in the picture tube it can be fixed with a picture rejuvonator. if its a cracked solder joint a soldering iron and solder will fix it.
Dec 06, 2008 | Philips Magnavox 42MF521D/37 Television
27 in Magnavox Smart TV
problem in vertical circuit 100uf 35 volt cap also could have poor solder connections on vertical ic
May 02, 2008 | Philips Magnavox 20MS233S 20" TV
Magnavox Mod. # HD 2715 C 202
Your set in in closed caption mode text 1....Go into your menu and un-do the closed caption mode.
Feb 18, 2008 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 27" TV - no picture and buzzing sound
Are you using the video input? Do you get on screen display? If so you probably have the video (yellow) wire connected to one of the audio inputs.
Feb 08, 2007 | Philips Magnavox SC3127N 27" TV
Philips Magnavox Learning Universal Remote Logo
66 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
