Problem with coloured vertical lines covering a 5" section of a 32" logik lcd tv
I'm trying to repair my Logik LOG32LW782 lcd tv. The fault is a set of numerous vertical coloured lines running from the top of the screen to the bottom with an overall width of about 5 inches. The affected section is on the very right side of the screen, and the rest is completely fine and shows a good picture from all inputs.
Can anyone help in suggesting what the cause might be? I've had a bit of experience before in changing inverter boards, but not seen this before. I'm trying to diagnose the cause before I resort to taking it in for repair.
So if anyone can suggest what might be causing it, and/or what part might need replacing or looking at, I'd be very grateful!!
Thanks very much!
Dan Henderson
  • 1 more comment
  • danatoakhill Oct 05, 2008
    Thanks for the answer. If the driver is having a problem, is there any way of fixing that rathger than replacing the screen? Surely the actual screen is in working order as it's showing light? I've taken tv's apart before, so do you know what part I'd be looking to replace, or what I'd be looking for?
    Also, is there any way of finding out how to restore the tv to it's factory defaults? I've not got a manual and can't find anything on the internet...do you know if there's a sequence of buttons that can acheive it at all?
    Thanks very much,
    Dan
  • danatoakhill Oct 06, 2008
    Thanks very much,
    Dan
  • Ash Lewis
    Ash Lewis Jan 15, 2014
    i have just fixed this problem on a friends tv you will need to change the 4 1000uf capacitors on psu board then clean connectors on or replace the timing control board located behind the metal chassis the psu board is attached to hope this helps
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
You have to change your screen the driver having problem
Posted on Oct 05, 2008
Logik log32lw782
Sounds like back-light fault. It will be best to contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 22, 2014 | Televison & Video
Logik log32lw782
Go to settings resolution and try to play with it. See which is the best fit for your screen.
May 09, 2014 | Computers & Internet
I WORKING ON LOGIK TV LK74PF LOPT WAS FAULTY NOW IT HAS AND EAST WEST FAULT.THE EAST WEST TRANSISTOR 2SC5248 IS SHORT CIRCUIT.REPLACED IT BUT IT BLEW AGAIN.THE TRANSISTORS THAT DRIVE IT 2SC1815 AND...
Hi, The Logik lk74pf flyback that you replaced. What did you replaced it with. I also have the same tv with the same problem. Also found a 1k resistor blown in the supply line from the flyback to the vertical deflection circuit.
Sep 12, 2013 | Cameras
Where can I get a manual for a logik TV model LOG26LW782
The link in post one has a LOG32LW782 listed this is the same TV with a larger screen and the instructions are the same
Dec 12, 2011 | Televison & Video
I have a 22" Logik
The problem is related to the section which processes the video/picture information in the TV. Most likely an IC or its surrounding components.
Try consulting TV repair technician.
All the best
Rjn
Sep 20, 2011 | Televison & Video
Logik LCD 32 Signal problems
Have you tried having your outdoor antenna upgraded? and do you have an antenna booster in the back of the tv where all the antenna cables connect into.
Nov 05, 2009 | Televison & Video
Harwa tv childlock code
For Harwa (also branded Logik) 54cm colour TV with remote RC-A07 showing blue screen with red lock in the corner, hold down "music" button on remote for 10 seconds to unlock.
Oct 24, 2008 | RCA TruFlat 27F520T 27" TV
New Logik TV Standbymode
If you're relying on cheap cables - like the ones that are usually tossed in with electronics - you could be running into a signal issue because they aren't shielded and they lose alot of signal due to leakage.
You don't have to overpay for Monster cables, mind you, but cables that are shielded - in gold is even better - should help improve your signal.
J. DeRuvo
[url=http://www.digitaladvisor.com]Digital Advisor[/url]
Nov 30, 2007 | Televison & Video
Televison & Video Logo
566 people viewed this question
Top Televison & Video Experts
