Question about Kodak I260 Captiva IA-Express Path-Through Scanner
Kodak I260 paper tray not lowering after tray emptied
My Kodak I260 paper tray does not automatically lower after all pages have been scanned or feed into the unit. This condition appears several times a day after scanning 25 to 100 hundred documents at a time - we are using Windows 2000. The tray sensor does not appear to be clogged or dirty and the unit requires a power cycle to recover.
    Problem Solver:
  • 10 Answers
The Kodak i260 has a fixed Paper Tray and does not automatically move up and down?????
Posted on Jul 06, 2009
What causes a kodak i700 scanner to keep running?
Could be the setting in the driver (scan validation tool) time out or if the feeder roller continues to turn clean the sensor located on the paper tray inside the square hole approx 8 mm X8 mm just below where the feed rollers are located
Jun 19, 2014 | Kodak i780 Sheetfed Scanner
Kodak i260 paper jam
cluch motor problem or senser probelem,
tray first front side scan only its pass the paper than
scan next back side if not pass problem from fron or back senser
Aug 03, 2013 | Kodak i260 Duplex Color Scanner
Does not sense lower feeding tray as full
One suggestion is to check if there is paper behind the tray which is stopping the paper lift mechanism from functioning properly. The paper senso rcould be dirty or broken and will need to be serviced. Or, the papersize dial could be set to the wrong paper size.
Nov 10, 2011 | Canon imageRUNNER 2200
High pitch scream after i260 scans a few pages. Scanning stops
the main board in that scanner is going bad which is why its making the high pitch sound. Time to get another scanner or call Kodak and get a replacement scanner or go back to the store where you got it from and get a new one.
Jan 23, 2010 | Kodak Office Equipment & Supplies
Lasejet 4 plus- try to print. lower paper cassete full. printer screen says pc load letter and have to manualy load paper. print icon on computer says out of paper
There is a paper empty flag sensor, looks like a plastic paddle, in the tray area. Pull out the paper tray and flick it; make sure that it is not jammed.
Also on the right hand side there is a paper pick- up roller, clean it with a cloth with some alcohol. See page 4-13 for the location of paper feed pick-up roller. page 5-27 shows the paper empty sensor flag
Here is the service manual:
http://home.comcast.net/~wannabeyote/hp-lj-4-5-m-n-plus.pdf Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 06, 2009 | HP LaserJet 4 plus Printer
Kodak I260 large black line.
It may be inside see this website for how to fix an Hp which is similar http://www.willshak.com/scanner/
Apr 20, 2009 | Kodak I260 Captiva IA-Express Path-Through...
Will not automatically feed
I had to fix similar if not the same problem in the office today. After you load paper, the paper holder steel plank should pop up. In my case it didn't, the result was what you have described. To solve, before you close (push in) paper tray, on the lower right side of the paper tray there is a little plastic button, push it up from the buttom. This will pop up the steel plank on which paper rests, then close tray.
It worked for me...
Aug 14, 2008 | Sharp AL 1631 Copier
Kodak i260 Scanner
This is practically impossible. This can happen only when the file is over written! Check your software settings. May be you have selected 'multipage' option. Try scanning one page and two pages (same sheet). If the file size is different, then it means two files are scanned.
Reload your Driver and check your scanning software. I am assuming you are usning winXP/Win 2000.
S. Mohan
Jul 30, 2008 | Kodak I260 Captiva IA-Express Path-Through...
Kodak PD6000 Printer Dock will not lift and feed paper from paper tray
Greetings,
Here's the link for your products Troubleshooting Guide
Keep us posted and thank you for using our service.
FixYa - Technical Support, Instructions & Repair Service
Jul 30, 2008 | Office Equipment & Supplies
Kodak I260 Captiva IA-Express Path-Through Scanner Logo
105 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
