Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
The tv tries three (cycles) times to power on but no picture or sound
I unplugged tv for over an hour but same results - no picture or sound
  • 1 more comment
  • bc69 Oct 05, 2008
    tv green light stays on for 2 seconds but tv will not turn on
  • tersa_harris Oct 05, 2008
    When I push the power button the tv will make a sound like it is coming on three times and every time it makes the sound the green power light will flash but the tv will not turn on.
  • tjb85 Oct 05, 2008
    how can I fix this without spending another $300?
    or does it have to be serviced??
Had the same problem removed back panel and blew with compressed air now it works yeah
Posted on Oct 09, 2008
I'm having the exact same problem. So far, all info I've found states it's probably a loss of high voltage. My RCA bigscreen is 4 years old & just started having this issue. Many other websites I've looked at regarding this say that a repair will only keep the TV going for another year or two before it could happen again. The price of TVs has come down a lot, so will probably just be more cost effective to buy a new one. I'm going to contact local repair shops today, but people have informed me that this type of repair is almost 500 bucks :( I will post any new info I might come upon.
Posted on Oct 06, 2008
  • 69 Answers
What source is the video and sound coming from? try unplugging and resetting the video and source sources too.
Posted on Oct 05, 2008
How do i fix a non responsive tv set?
Do the ballast first. That should get the picture back. The main board controls everything else.
Oct 08, 2016 | Televison & Video
Sony rear proj tv, no picture, menu appears, but in three seperated colors pin cushioned.
Best to first if you have not done so---UNPLUG the set for several minutes and plug back to power to see if that fixes it (it does a lot of the time especially if you had a power outage).
Nov 30, 2012 | Sony Televison & Video
Tried turing on but just keep clicking.. no picture or sound
Tries tv unplug,replug it back about an hour later,by letting the tv resetting itself back to the factory setting.The tv now should be work again.If it have the same result.Mean the power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries website like Ebay.com to buy a refurbish power supply board for the replacement.
Feb 01, 2011 | Philips 50PFP5332D 50 in. Plasma...
Screen is turning purple and green dose this cost lots to fix?
It sounds like your tube Shadow Mask may have got magnetised and need to be degaussed.
Turn off your TV at the mains and unplug it for at least two to three hours. Longer the better. After that time power up your TV it should degauss the tube at power up.
Worth a try before you give up on it. Or else get your picture tube replaced. It may be more economical than purchasing a new television. Also try to have the picture tube of an old color T.V as modern picture tubes lacks quality when compared to older ones. But check those tubes thoroughly before buying it.
Apr 07, 2010 | Hitachi 43FDX01B TV
My Sony Trinitron has stopped working mid viewing. The on/off/stand by light just flashes. Any idea how to get the TV back on?
You can try unplugging the TV power chord, leave unplugged for several hours, then plug back in and try it.
If no results you will need it serviced as there are many possibilities. If the light is blinking in a pattern, example flashes three times then pauses then flashes three times again, the number of times it is blinking can give the servicor a clue as to what circuit is at fault.
Oct 11, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My RCA D52W20 will not stay on
Clicking sound is power relay engaging. If all systems are not functioning properly, unit will shut down to prevent further damage and/or fire hazard
Apr 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Will not turn off
It sounds like the contacts on the on-off relay are stuck on. You can tap the top of the relay cover and that will shut it off (releasing the contacts) For a permanent fix, try taking the plastic cover off the relay and clean the contacts with a file (or just replace the relay)
Aug 16, 2007 | Hitachi 57S700 57" Rear Projection HDTV
No picture or sound
If you had a burning smell, well the board is toast. These sets are made to replace the entire board at one time. Before installing the replacement module, the picture tube should be checked. A defective picture tube ( such as a G1 short) may cause a failure in the power supply section.
Sep 07, 2006 | Zenith C32V36 32" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
55 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
