Question about Refrigerators
Motor on frige won't kick in
The motor is on but doesn't kick in everthing melting
it is a frigidaire model frs23hf5aw1
22.6 cub
  • 943 Answers
Hi .thanks for the question . you said the motor is on .you mean the fan in freezer is on . but the compressor is not running . i would replace the relay on the compressor .thanks the appliance doc
Posted on Oct 05, 2008
Frigidaire galaxy series makes ice but won't dispense
If nothing at all happens then check the micro switch on the lever/button section. This will probably require taking the dispenser section off. If nothing at all is happening its as though it doesn't register the dispense, if the switch worked then at least something would happen ie the flap, the drive motor etc
Jul 08, 2013 | Refrigerators
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
Ffu20fc4cwo won't freeze food
Check power to and from the thermostat first
Sep 13, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a Frigidaire freezer LFFU1424DW not freezing. Came home to melting ice and thawed food. I heard clicking noise like a fan but goes off after a few seconds. Help please.
first of all unplug that freezer and wait for 15 mins. move it five feet from the wall. after 15mins, plug it back and kick in compressor at the same time!!!! remember plug and kick at the same time. the ckicking noise come from the starting relais. this says that the compressor has a problem. If it doesn't work ; you will have to call a service person who will replace the compressor for you.
Mar 10, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
I have a cub cadet 2000 series model 2146. When I turn the key the motor spins but doesn't start. When I take the air filter off I see gas spit out when I choke it.
You could have one or more of several problems. With the gas scenario you mention, you're getting gas INTO the carburetor. But the carb could be grungy and in need of cleaning (90 percent of mower problems in my experience). My question is this: is the thing "Firing"? like do you hear it kick in like it wants to start. If not, then it may not be getting any spark. Take the spark plug out and buy a new one for about $3 (match the numbers up on the side of the plug ceramic). It never hurts to replace it anyway. With the info you have provided here, that is all I can give you right now, but hope it helps. Good Luck.
James
May 25, 2011 | Cub Cadet Garden
The AC fan does't want to begin to spin on its own. if I give it a little help, it will begin to work. Why wont it start on its own the fan will spin very easily and is not restricted at all it...
Hello, sounds like you have a bad capacitor, the capacitor gives the motor a boost and improves the running effeciency of the motor. Replace the capacitor it should fix the problem.
Mar 18, 2011 | Frigidaire Heating & Cooling
I have water pooling inside the refriderator. It
there is a drain in the freezer than gets pluged, unplug frige from wall, put food in ice chest take hair dryer and melt ice thats at back wall in freezer remove icemaker if there, and back wall of freezer inside, melt any remaining ice, **** up water with wet vac or sponge,see the pinky size hole in the pan under the coils, point hair dryer at it for a wile. now take the the lower back cover off behind frige and blow all the dust out and find the plastic tube, about the size of your finger and put the wet vac on it until you can hear it sucking in the freezer, take e cup of hot soapy water ond poor it in the freezer pan. put everthing back and your good to go
Dec 09, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Whirlpool Gold freezes up to frige side
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 24, 2009 | Frigidaire FRS6R5EMB Side by Side...
Refrigerators Logo
96 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
