Update Bios I want to update bios my laptop ASUS F5RLseries, cos my friend has inject it with his creature like keylogger, remotex, etc...
  • 1 more comment
  • Bimo Van Halen
    Bimo Van Halen Oct 05, 2008
    I need a help to update bios my notebook ASUS F5RLseries
  • Bimo Van Halen
  • Bimo Van Halen
    Thank's For You'r help..
    Don't Get Bored to Answer My Problems.. :)
    God Bless U All...
  • 124 Answers
Hi stulqhi_mmxc, if you just want to update your BIOS on your laptop, you can get it here v.210 2008/6/30. You need to install also the utility that allows you to flash your BIOS, get it here. Just unzip both files, run the utility, find the BIOS file (F5RL210AS) then that's it. Make sure there are no devices connected to the computer & also make sure you don't have any BIOS update.
About the keylogger, I do recommend just installing an antivirus & running a full system scan on your computer to remove it. You can get a free one here.
Hope this helps.
Posted on Oct 05, 2008
Bios update
Dear Alex,
There is a YouTube video that shows how to update the BIOS for your PC. I'll be posting it right away, but first I have to tell you that, while looking for the answer for your question, I came across to some forum posts regarding the 1401 BIOS update presenting problems with USB and other peripherals. maybe you should first have a look at it:
Unless you have a problem with your laptop that really need a BIOS update, you should remain with your actual version of BIOS. Anyway, the video is posted at:
Hope this info may be of help!
Miguel L. Martins
Oct 24, 2013 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
Asus Eee Pc No networking at all afte Bios update
Help needed after a bios update
Non of my networking options are now working.
maybe I seleceted the wrong bios update
can anyone help
on May 11, 2008 | ASUS Eee 4G Notebook
What are the instructions for flashing BIOS?
Hello use auto detect here to find the right mainboard:
Download asus update, this is the easyest program to upgrade the bios, while windows is running.
Install first asus update:
When the mainboard is found, select download, and select your windows system.
Open the bios folder, and download the latest bios version.
Unzip the bios file.
Run asus update, and select update bios from file, and select the bios file, in the folder you just have downloaded ( the bin file )
Be very carefull when you upgrade the bios, because a power loss will damage the mainboard, while the upgrade process is running.
You also have to setup the bios settings, when the job is done.
You have to select F1 or F2 to enter the settings.
If any doubt download the manual.
Good luck
Feb 07, 2013 | ASUS Computers & Internet
Bat bios checksum problems solve
Step 1:
Update ASUS BIOS b> Insert bootable floppy disk or USB drive. Copy the updated BIOS file to floppy disk or USB drive.
(Note: BIOS file and boot files should fit on a floppy disk. If the BIOS file is too large to fit with boot files, consider using the EZ Flash method described below.) Insert the motherboard support CD into optical drive. Copy AFUDOS.EXE from CD to a floppy disk or USB drive. Reboot. When the DOS prompt appears, type the following: afudos /i[name of BIOS file]For example, "p4c800b.rom" might be the name of the new BIOS file. "afudos
/ip4c800b.rom" is the command that will install it. Wait. Your monitor will display the update's progress with a series of messages: "Reading file," then "Erasing flash," then "Writing flash." The "writing flash" message will be followed with a percentage counter that tells you how far the write has proceeded. The final message will be
"Verifying flash." DO NOT switch off or reboot at any point in this process or you will ruin your motherboard. After the update is complete, the utility will return to the DOS prompt. Remove your floppy disk and reboot. Enter the BIOS Menu and load "Setup Default." Save and reboot. You're finished. b> Update Using EZ Flash Copy your new BIOS files to a floppy disk or USB drive. Reboot. When the system is at POST, press "Alt" + "F2" to enter EZ-Flash. Alternatively, on late model motherboards you may press "Delete" to enter BIOS setup, then access EZ-Flash from the "Tools" option on the navigation bar. (Select Tools > ASUS EZ Flash 2 > YES) Wait for your system to check current BIOS information. Insert your floppy or USB with the new BIOS file. Select the drive letter with the BIOS update file, then select the file. Wait for your system to check the update file. After the file check is finished, click "Yes" to update your BIOS. Wait. Let the update procedure run until it finishes. Do not switch off or reboot or you will ruin your motherboard. When the update is finished, remove the floppy or USB drive and reboot. Enter the BIOS Menu and load "Setup Default." Reboot. You're finished. b> Update Through the Internet If it isn't installed already, install the ASUS Update utility. You can either download it or use the copy on your motherboard's support CD. Close all Windows applications if any are running. Launch the ASUS Update utility from the Windows desktop by clicking "Start>Programs>ASUS>ASUSUpdate>ASUSUpdate." The "ASUS Update" main window will then appear. Select "Update BIOS" from the "Internet option" drop-down menu. Click "Next." Select the ASUS FTP site nearest you, or choose "Auto Select." Click "Next." From the FTP site, select the BIOS version that you wish to download. Click "Next." Start the update. Wait for it to complete.
Feb 05, 2013 | ASUS Eee PC 900 Notebook
Cerna obrazovka nemam disketu bios
Hi, you can download the bios here:
Download the asus update utility from here:
The asus Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows environment.
The Asus Update utility allows you to:
· Save the current BIOS file
· Download the latest BIOS file from the Internet
· Update the BIOS from an updated BIOS file
· Update the BIOS directly from the Internet, and
· View the BIOS version information.
Aug 25, 2011 | ASUS A7V600-X (90M7A820G0EAYZ) Motherboard
Cmos bios bad asus p5ld2-x/1333 i945gc. how i fix?
ASUS Update Utility - an utility that allows you to save, manage and update the motherboard BIOS
The ASUS Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows® environment.
The ASUS Update utility allows you to:
You need an Asus motherboard in your system.
Rules for Safe BIOS update:
1. For safety reasons, always use the most updated BIOS utility!
2. Do not overclock the system/CPU during BIOS update!
3. Load "Setup Default" in BIOS menu before BIOS Update.
4. Make sure you have "Administator" privilege on your Windows system (WinNT4/2000/XP).
5. Close all application programs under Windows.
6. Disable any existing Anti-Virus applications in the system.
7. Reboot the PC after the BIOS update is complete.
8. Switch on the PC and load "Setup Default" in BIOS again.
Hope this helps
May 23, 2011 | ASUS P5LD2-X/1333 - motherboard - ATX -...
I want to update my P4BG-VM asus m.board bios update
Please go to this site and select your operating system. Your bios update options will be listed under the bios drop-down. Hope this helps.
May 22, 2011 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
Failed A8V-VM SE Bios update attempt.
ASUS has a marvelous BIOS upgrade utility that runs from Windows,Download the correct one from the ASUS web site
Dont forget to rate the advice.
Aug 03, 2009 | ASUS A8V-VM Motherboard
How can i get update for Bios
Hi there.
You can download the BIOS update from the Acer website here:
Just select your make and model, then underneath that, select your Operating System. Then just click on the BIOS tab, then the orange icon to the left of the BIOS file.
Hope that helps.
Apr 24, 2009 | Acer Aspire 1640Z Notebook
BIOS Password Problem
The only thing that a bios update would do would update the bio your password info should stay the same maybe your not typing it right try typing with or without cap lock
Mar 10, 2009 | ASUS F9S-B1 Intel Core 2 Duo T7500 2.20GHz...
Computers & Internet Logo
196 people viewed this question
David Payne
David Payne
