Question about Stoves Kitchen Ranges
Heating element went out. we have replaced it but want to make sure we wired it correctly before turning stove on.
YOU CAN TRY TO CHECK THE CONNECTION TO THE ELEMENT ITSELF I HAVE FOUND THAT SOMETIMES THE W IRES CAN GET FRAYED AND BREAK LEAVING ONLY A FEW STRANDS ENOUGH TO LET ELEMENT PROOF ITSELF BUT THE RESISTANCE GETS TO HIGH TO ACTUALLY WORK PROPERLY
Posted on Oct 05, 2008
220 stove has nothing hooked up to the neutral
TURN OFF POWER TO THE STOVE OR UNPLUG IT IMMEDIATELY BEFORE TOUCHING **ANYTHING**. I need the make/model of your unit to help you accurately. HOWEVER, the first thing you need to do is(and this applies if I'm interpreting you correctly)replace the power cord--it will be connected to the terminal block--on the vast majority of ovens, you have a left-hand terminal, generally known as L1(a power wire), a center terminal(*normally* the neutral connection), and then the right-hand terminal, generally known as L2(2nd hot supply wire). Take a picture of the AC outlet so you can purchase the correct power cable for your stove. Also, take a picture of the terminal block in the rear of the stove just to make sure. I'm assuming that the wires are all connected in the stove but the neutral wire is either broken or missing from the power cord. Due to how most ovens operate, THIS IS A VERY DANGEROUS CONDITION. When the unit is plugged in, even though the oven is off, there is still 120v applied to the heating elements. When you turn on the oven, instead of being connected to a ground, the other side of the heating elements are simply connected to 120v from the other side of the panel, adding up to 240v and the elements heat up. I hope this helps you!
Aug 13, 2015 | Kitchen Ranges
I replaced the bake element but it will not heat
Have you checked the oven fuse, there should be one on the stove. To check the element power, remove the element from the back where its attached to the stove Remove the element from the wires (Skip this step if you are absolutely sure the element is not working). Attach your meter clips to the 2 wires (meter set set to at least 250Vac), place a piece of cardboard under the screws and meter clips to isolate them from touching any metal parts of the oven. Turn the meter on, set the oven thermostat to 350, you should have at least 220Vac, if you do the power is fine. Test element for continuity, and for a possible short.
Mar 01, 2015 | Dacor Epicure ERD36 Dual Fuel (Electric...
Frigidaire oven wont heat up but stovetop and digital all works
Hello angeleyez82 - The EOC (electronic oven control/control board) basically sends power to both the broil and bake elements. As long as the power supply to the range (240VAC) and wiring between the elements is correct, then typically only the element(s) or EOC could prevent the unit from heating. I hope this information helps to some degree.
Jun 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
My stove poped and went off. I tripped the breaker and now the oven will not heat. Neither the top or bottom unit.
First I would look at the heating element in the oven and make sure it is all in one piece. there are usually one on the bottom and one on top. sometimes they will burn apart and short out to stove. if they look ok then do a quick check, I would turn off all knob on the stove top and oven. then try to reset the breaker. hopefully it resets ok. then turn on one at a time and see which burner or oven element has a short. when you find the bad burner or stove element it will trip the breaker again.
hope this helps
Jan 09, 2012 | Kenmore Kitchen Ranges
MY BOTTOM ELEMENT & MY TOP ELEMENT WILL NOT HEAT UP IN MY OVEN THE STOVE WORKS FINE
It would be very unlikely that both elements went out at the same time. Is it possible that one element went out a long time again and went unnoticed?
Do this: Turn your oven on BROIL and the temperature up all the way and see if the top element begins heating.
Then turn it on COOK and see if the bottom element comes on.
If both elements fail to work then your problem may be in the selector or thermostat control. You may also have a wire that has come loose (or burned loose).
If you are comfortable working with electricity, you can turn the circuit breaker off and remove the controls for testing. Also, verify that all the wires are properly attached.
If you are not comfortable, have a service technician check it out immediately. It scares me that there may be a loose wire behind the control panel!
If one of the elements worked and one did not then the problem is "most likely" a bad element. Turn off the circuit breaker to your oven and make sure all the knobs are off on the oven and you can remove the element and take it to a parts store for replacement.
It is easy to remove. Take out the wire shelves and unscrew the screws where the element goes into the back of the cooking cabinet. There will be some wires attached which should pull off.
Good Luck!
Oct 28, 2009 | Ovens
Admiral wont heat
Your breaker in the breaker box has a double pole breaker for the stove one breaker is shot so you still have 120volts which runs the lights 240volts for the elements.Turn main power off and replace the breaker. To verify for sure pull the stove out and unplug it check power at the plug you need 240volts at the plug. If i dont have a plug and wired straight in disconnect the wires and check the wires.
Sep 01, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Heat element shorted out saw arching from element itself
An Easy Task.  Unplug stove. Remove old element by disconnecting the wires. Purchase new element and install. Plug stove back in.
Dec 20, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Kenmore electric stove heating element how to replace
A replacement is usually around $40. There are usually 2 screws holding the element in the back of the stove. Turn off the power and remove the element. There are usually only 2 wires. It really doesn't matter which goes where. Install the new element and see if it will shut off when oven reachers temp. If it continues to heat, there is another piece that needs to be replaced. If there is a contactor or relay replace it, If not the thermostat needs to be replaced. Sometimes when the element burns out it shorts to the ground and fuses the contacts forcing the element to stay on. Sometimes you actually have to turn off the power to the stove.
Nov 26, 2007 | Equipex PZ-330 Electric Single Oven
Oven goes into Hyper Hot Immediateley?
It's either a problem in the board or one of the elements is shorted to ground.  Most likely one of the relays on the board is bad so the board would have to be replaced.  If you have a multimeter you can check this.  Unplug the range and take the back panel off to get to the elements.  Take one wire off of each of the elements. Set meter to ohms to check resistance.  Put one meter lead on one end of the element (where you disconnected the wire) and the other lead to ground.  If that shows resistance then the element is shorted to ground.  Do this with both elements.  If neither element is grounded then replace the oven control board.
Oct 10, 2007 | GE Profile JDP47 Electric Kitchen Range
Electric Heating Element Not Heating stove
It's not a fuse, but a wire or heating element has burned up. Please TURN OFF the circuit breaker until you repair the problem, or at least until you know what the problem is! You say "in" the stove, so I'm assuming that you mean in the oven. Whichever element it is, whether it's in the oven or on the stovetop, just needs to be removed and checked for continuity with an ohmmeter. Quite frankly, if it IS an element, then you should see a burned-out spot somewhere on it that's pretty obvious. Then you just need to replace the element. If it's a wire, then you will need to repair the wire so that it safely makes contact with the element again. That process is a little more involved than just replacing an element, but let us know what you find. I can describe a wire-repair procedure if need be. ;)
Aug 13, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Kitchen Ranges Logo
49 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
marley mcelhinney
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
