Kodak EasyShare CX4310 Digital Camera Logo
Larry Hammer Posted on Dec 31, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cx4310 4GB how do I format a 4GB for this camera
Jeffrey Groves
Level 3:
  • Master 573 Answers
  • Posted on Feb 11, 2012
Jeffrey Groves
Master
Level 3:
Answers
573
Questions
Helped
140421
Points
1832
Please read page 45 of the user manual for this camera for directions. The user manual is available online here: (click here)
4helpful
2answers
Camera says out of memory won't let me take pictures. i cleared all the pictures out and still cant take pictures. What do you think the problem is?
I'm assuming you are trying to use an SD card in your camera and not the internal memory. I suggest you format the memory card if you are sure there is nothing on the card. Formatting the memory card deletes everything on the card and sets it up with a file system that your camera recognizes. Follow these steps to format your memory card using your camera. 1. Turn camera off 2. Insert memory card 3. Turn camera on 4. When the memory card is inserted in the camera, the [Format card] option appears in the setup menu 5. Choose Format to format the entire card. Don't choose Quick Format 6. Wait until your card is formatted
After formatting your memory card, try turning your camera off and on and you should now be able to take pictures to your memory card.
P.S. If you remove your memory card you can choose Format Memory from the setup menu to format the camera's built-in internal memory
In olympus fe 280 when i have placed the xd in the camera and turn on the camera then it displayed two options either to clean up or format then i have chosed format then it displayed after some time like...
A camera memory card should always be formatted IN the camera.
Do not format camera memory cards in a computer card reader.
If the card is formatted in the camera and after that the same error pops up,
you should replace the memory card and recheck.
When I plug my camera into the computer it won't format. The battery is charged, there is no memory card in the camera.
What makes you think you need to use the computer to format the camera? Why do you need to format the camera at all? We format memory cards and we format internal memories of cameras but these functions are done in the camera, not the computer.
Format error
Format error means memory card in camera is unstable and need to be formatted. You will lose all data/ files on memory card after format.
Format option is available in camera Menu.
This will solve your format error problem in camera.
Why My kodak dc280 can not read the memory card?
Try formatting your camera memory card If you own camera memory cards that have been used in other digital cameras, the card may not be properly formatted for use in your camera, or that data on the card may become corrupted. When these issues arise, your camera indicates that the camera memory card needs to be formatted.
When you format a camera memory card, all of the information on the card is erased. This includes any borders supplied on the card.
  1. Set the Mode dial to Camera Setup.
  2. Slide the POWER switch to the right to turn on the camera. The main Camera Setup screen appears.
  3. Press a updown_icon.gif button until the format_icon.gif icon is highlighted. format.gif
  4. Press the DO-IT button. The Format Memory Card screen appears.
  5. Press a updown_icon.gif button until CONTINUE FORMAT is highlighted.
  6. Press the DO-IT button to format the camera memory card and return to the main Camera Setup screen.
2answers
Memory card requires formatting- I select continue then it says "formatting will delete everything on memory card-I select "continue" then it reads "formatting" and repeates itself
1. Make sure your SD card is not locked so the camera can format the card. If the camera still cannot format the card, try to format the card with a computer. If this doesn' t work, the card may be defective.
If the computer can format the card, the put the card back in the camera and then the camera should be able to format the card. The camera MUST format the card before the camera can save to the card.
Camera will not format 4 gig card
I am having the same problem. I phoned a camera store and they said the camera is too to accept a 4GB card may only accept to a 2 Hope this helps
3answers
Memory Card Format Fail
Hi I think its a compatibility issue. Try formatting it using your camera. else format it using Windows.
1helpful
2answers
"Memory card cannot be read"
My camera used to do the same thing--once I got the pictures off my card, I left it in the card reader, right clicked on removable media (my computer + removable storage) chose to "format" and formatted it on my computer. It seems to have fixed the problem, and my camera now reads it fine. I tried to format it on the camera before, but it didnt work.
2answers
The camera screen displays error message
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
