A c prog to convert decimal to hexadecimal number.
I need a c or c++ programming to convert a decimal number to hexadecimal
    Problem Solver:
  • 13 Answers
Sure, here you go:
int main(void) {
int input;
printf("Enter a decimal number: ");
scanf("%d", &input);
printf ("In hexadecimal, that is: %X\n\n", input);
return 0;
Posted on Oct 06, 2008
  • Josh Anders
    Josh Anders Oct 06, 2008
    Oh, and add "#include " to the top. The new code should read:
    #include
    int main(void) {
    int input;
    return 0;
How can i convert decimal to binary number in casio fx 82ms calculator?
This gentleman explains it very well. The trick seems to be to enter the number and then hit the equals sign, and then do the conversion.
Good luck,
Paul
Decimal to Binary and Hexadecimal conversions using casio fx 991MS HYONKOWS
Dec 20, 2016 | Casio Office Equipment & Supplies
Converting from BASE-N to Decimal
If you want to convert from another base to decimal, press MODE 4 to enter the BASE-N mode, select the initial base (binary, octal, or hexadecimal), enter the number, then switch to decimal to see the value in decimal.
If you want to exit the BASE-N mode, press MODE 1 to switch to the computational model or MODE 2 for complex mode.
Oct 04, 2011 | Casio FX-115ES Scientific Calculator
How to get from dec. to binary
If you're already in decimal mode, press SHIFT BIN to switch to binary mode.
To convert a number from decimal to binary, press MODE 4 to switch to BASE-N mode. You'll find yourself in decimal mode. Enter the number to convert, press =, then press SHIFT [BIN] (the log key) and see the number in binary. To convert another number, press SHIFT [DEC] to return to decimal, enter the number, press =, then press SHIFT [BIN]. An analogous process works for hexadecimal and octal as well.
To return to "normal" use, press MODE 1 for COMP mode or MODE 2 for complex mode.
Mar 12, 2011 | Casio FX-115ES Scientific Calculator
How do you convert decimal numbers into binary?
Press MODE 4 to enter the BASE-N mode. Type in the decimal number, then press BIN to convert to binary. Press DEC to switch back to decimal for the next conversion.
You're limited to numbers in the range [-32768...32767] in binary. You can extend the range if you convert to octal or hexadecimal and then mentally convert each digit to three or four bits.
Dec 01, 2010 | Casio FX-115ES Scientific Calculator
What is the serial number for this model
VX8500 does not have an ESN. The VX8500 has an MEID. The MEID is a 14 digit hexadecimal value with the following format:
The decimal representation is calculated as follows:
a). Separate the 14 digit hexadecimal MEID into two parts:
Part 1 – the first 8 digits representing the manufacturer code (digits RRXXXXXX in
the figure).
Part 2 – the last 6 digits representing the serial number. (digits ZZZZZZ in the figure).
b). Convert the hexadecimal value of each part into the decimal equivalent:
Part 1 – 10 decimal digits zero filled.
Part 2 – 8 decimal digits zero filled.
If the decimal equivalent of each part is less than the number of required digits, right align
and zero fill to create the required length.
c). Concatenate Part 1 and Part 2 to create an 18 digit decimal number.
Example:
Hex MEID = AF 01 23 45 0A BC DE
Part 1, manufacturer code is 0xAF012345 = 2936087365
Part 2, serial number is 0x0ABCDE = 00703710
Therefore, the decimal representation of the MEID is 29360 87365 0070 3710
Sep 10, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Java code for adding octal, hexadecimal subtracting binary,
Hello desireejane,
One method is to do the following
  1. Convert the octal, hexadecimal or binary to decimal.
  2. Add or Subtract the decimal normally
  3. Convert the result back to octal, hexadecimal or binary.
  • Convert the octal to decimal:
public static long octalToDecimal(String octal) throws NumberFormatException {
// Initialize result to 0
long res = 0;
// Do not continue on an empty string
if (octal.isEmpty()) {
throw new NumberFormatException("Empty string is not an octal number");
// Consider each digit in the string
for (int i = 0; i < octal.length(); i++) {
// Get the nth char from the right (first = 0)
char n = octal.charAt(octal.length() - (i+1));
int f = (int) n - 48;
// Check if it's a valid bit
if (f < 0 || f > 7) {
// And if not, die horribly
throw new NumberFormatException("Not an octal number");
} else {
// Only add the value if it's a 1
res
+= f*Math.round(Math.pow(2.0, (3*i)));
return res;
Mar 24, 2009 | Sun Java Programming Language (cdj-275)
Programming in c
To convert numbers you can use the printf() function
printf("%d", x'FF') hex to decimal
printf("%o", x'FF') hex to octal
If you want to save the value in another variables use sprintf
e.g
a = x'FF';
b = sprintf("%d",a)
Jan 15, 2009 | Computers & Internet
C++ program for the conversion of decimal numbers to hexadecimal
all your solution is at
http://www.c.happycodings.com/Beginners_Lab_Assignments/code18.html
Dec 07, 2008 | Computers & Internet
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
