Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Undoing sensor. Can we undo sensors from the equipment, if yes how?
  • 118 Answers
No it will not work without safety eyes. It is not legal, but some people will mount on ceiling or tape them together.
Posted on Jun 16, 2010
  • 74 Answers
The equipment it doesn work with out the sensors in some models
Posted on Mar 10, 2009
Incoming water does not stop
Almost certainly your solenoid operated water inlet valve has failed. This is a quite common thing, and you can change it yourself with a bit of undoing and removing.
A less common possibity is failure of the water level sensor which is usually a diaphragm operated switch connected to a tube to the side of the tub.
May 01, 2016 | Washing Machines
Where are the 02 chevy impala 3.8L o2 sensor locations, I only see three. the top bank one sensor 1 is stripped out, how do i get that one out?
you can apply pressure to the sensor while undoing it to force it out or you will have to cut out the thread area and get an O2 sensor bung hole replacement at an auto supply store and weld into place and install a new O2 sensor. bank 1 sensor 1 is located in the front pipe off the manifold that has cylinder #1 on and bank 2 sensor 1 is on the side that cylinder #2 is on like sensor 1. sensor 3 is the one just before the cat.
Sep 17, 2014 | 2002 Chevrolet Impala
Change the o2 sensor but still have code
Reset your computer by undoing the - neg connection off your battery for 30sec then reconnect the battery terminal this resets your computer.
Mar 10, 2014 | 1999 Chevrolet Camaro
Walking camshaft on 99 dodge neon
  • 1 Park your Neon on a level surface. Engage the parking brake. Open the hood and loosen the bolt on the negative battery cable terminal and pull the cable from the battery.
  • 2
    Remove the Neon air filter by undoing the side clips and lifting the cover of the air filter off. Pull the air filter from the bracket. Undo the clip on the air filter hose and pull the hose off the inlet. Use a socket wrench to loosen and remove the four bolts holding the air filter bracket in place and pull the bracket from the engine
  • Locate the camshaft position sensor. It will be at the rear of the cylinder head, centered on where the air filter housing was about midway down. It will look like a black plastic square (4"x4") and have four bolts holding it to the engine.
  • 4
    Disconnect the wiring of the sensor from the wiring harness feeding into the car's electrical system. Press in the tabs at the sides of the connector and pull the two halves apart to do this.
  • 5
    Remove the four bolts holding the sensor in place and remove the sensor from the engine.
  • 6
    Clean the engine of any gasket material from the old sensor by scraping the surface gently with a paint scraper.
  • 7
    Install the new sensor by placing it in the same position as the old one, replacing the bolts and then connecting the wiring harness. Replace the air filter bracket, hose, filter and cover. Reconnect your battery and you are done.
  • buy F150 Parts.
Jun 03, 2012 | 1999 Dodge Neon
I had my throttle position sensor changed and the check engine light is still on
that usually means you have to have the computer system cleared of codes by using a scanner tool ... Some codes won't clear with just undoing the battery... Most any shop should be able to access it, or if it was done at a shop they should have... Generally it shouldn't cost over 50 bucks no matter what type of vehicle
Apr 28, 2012 | 2004 Pontiac Grand Prix
I have a peugeot 307 rapier and the ABS light keeps coming on, any ideas?
hi had rhis on a few 307's what you need to try first is remove the o/s/r wheel, brake caliper and brake disc, and hub, remove the wheel speed sensor by undoing the 5mm allen key bolt and clean where the sensor sits then rebuild and give it a run all being well it should clear the fault. if that doesnt work it will probably need the sensor replacing
if this helps please let me know
cheers
big mike
Mar 03, 2010 | 2006 Peugeot 405
I need to change out the front hubs on my 2000 4wd suburban. Is is better to have a certified mech. do it because of the abs brakes?
the abs really doesn't complicate anything, it is just a connector you unplug. just be careful and you wont have any problems. if i can make one recommendation however, buy a quality hub assembly such as a delco, or you may have abs problems. some of the cheaper hubs have caused problems in my experience.
Dec 28, 2009 | Chevrolet Suburban 1500 Cars & Trucks
My asko T760 dryer shuts down after a few minutes. It starts again after hitting reset button on back. I read a similar problem was fixed by cleaning the sensor behind the safety cap fixed the problem, but...
Remove bottom panel. The condenser unit is on the left side. Open the section by undoing the clips, and look inside the little "cage". That's the sensor. Remove any lint using a toothpick and you should be good to go!
Nov 28, 2009 | Asko T780 Dryer
Removal and replacement of oxygen sensor located on catalyser
If done properly the right size ring spanner and oxy/acet will get this part off throwing water at it while hot is not advised.It needs to be heated evenly until it is anice red color,put the ring spanner on it and try to tighten,yes tighten,until it moves.once its moved undo it.Oddly enough tightening a jammed bolt will ,before undoing it ,make it easier to release the threads seal.
Oct 17, 2008 | 1999 Toyota Camry
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
80 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
