I used to get on chat roullette and everything worked fine. i just got my new dell laptop this christmas, but just a couple days ago they stopped working on chat roullette. i setup everything again and i kept clicking enable cam and enable mic in settings but it wouldnt turn on. even in settings when i closed it, id open it back up and it was like i didnt click the buttons cuz they were off again.
SOURCE: Door clicks and wont open and washer runs but wont do anything
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure You should remove machine's top cover and then you will have an access to the door lock unit. Be aware you should discconect machine's power cable first !! Good luck!
SOURCE: Opener wont open makes clicking noise
Your opener has been hit by lightning or power surge.
If it's not too old you can replace the 'back board' (the computer board on the back of the opener.) Also If the opener has safety sensors one or both of them may be burnt out too, and if it was really bad then the rpm sensor will go too. So you could be looking at paying half the cost to repair or just get a new opener. Up to you, and get a surge protector. Lift master has a good line of products and makes thier own surge protectors for thier products.
SOURCE: Microphone doesn't work in Yahoo & msn messenger
i need help i've tried every setting for my webcam and i cant get my microphone to work!! i use vista if that helps. But what setting can i use to fix this... Is my mic broken or my camera a manufactor default?
SOURCE: cyberlink youcam
got to your desktop and right click then choose personalize then go down and click display settings then choose the highest resolution
SOURCE: asus mousepad stopped working after windows vista update
1.) Try reloading the touch pad drivers, should be on the CD that came with it or check the Asus website for new ones.
2.) Have you accidently disabled it? There is a Fn key combination to do this. Try Fn+F9. Also, there is an option to automatically disable the mouse pad when a USB mouse is plugged in. And of course, you can disable it from the Device Manager.
3.) Try going into :: Control Panel, find "Mouse", select the "Device Settings" tab, select the touchpad and click the "Settings" button). Check the settings in the "Tapping" section.
