Question about Kenmore Elite 45986 Front Load Washer
Whining noise in washing machine
When it is washing it makes a loud humming/whining noise. The washing cycle periodically pauses and the noise disappears but starts again when the dishwasher resumes washing. I checked the chopper assembly and removed any debris from this area and the sound remains.
  • 15,935 Answers
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
Very noisy and loud vibrations on spin cycle of Frigidaire FTF2140FS front load washing machine
Is it just during the spin cycle that it machine is noisy or the noise is less during the wash cycle? Also is the noise a thumping type of noise or is it more of a whining or steady noise? If is a whining noise, it probally means that water has seeped past the seal and corroded the bearing of the washer. The noise is the failing bearing.
Jun 30, 2010 | Frigidaire GLTF2940ES Front Load Washer
When in spin cycle machine makes a very loud whining noise
Most common cause for your whining noise is because the seals have failed/worn and allowed water into the bearings..Rusty ball bearings are not smooth...Hence the noise.....Probably needs bearing/seal and probably shaft replacement....Big job..Get quotes....Good luck...Nomess
May 20, 2010 | Washing Machines
Hi, our washing machine started making very loud banging and whining noise in the final spin cycle and the machine was shaking. We have taken off the back. The springs look ok. any suggestions?
Loud banging is usually an unbalanced load. whining noise is some times debris trapped in drain pump causing it to squeal like a fan belt on a car. Strings, threads and hoses tend to get wrapped under agitator and cause noise, too.
Jul 24, 2009 | Frigidaire Affinity ATF6000F Front Load...
Washing machine making whining noise during spin only
Its a bearing on its way out. the seal is also probably worn.
May 06, 2009 | Amana Washing Machines
Kenmore washer makes a whining noise
The whining noise is usually caused by the pump. Try replacing the pump. Or cleaning it out.
Feb 01, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore makes whining noise as it tries to spin
The drive coupling has probably broken. Usually happens when you overload the machine. Easy fix. READ MORE
Jan 21, 2009 | Kenmore 24902 Top Load Washer
Front load washer makes whining noise on spin cycle
Check to make sure that your machine is still level using a regular carpenters level. If it is not, You may be able to level it by screwing on the legs until it is level. But carefully and not too much at once.
Aug 02, 2008 | Frigidaire ATF6000ES Front Load Washer
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Apr 11, 2008 | Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
90 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
