you ask here. Please rate highly
SECTION 303-05: Accessory Drive
1998 Escort/Tracer Workshop Manual
REMOVAL AND INSTALLATION
Belt -2.0L SPI
Removal
- Relieve the drive belt (8620) tension.
- Use a (A) ratchet or breaker bar inserted in the square hole in the drive belt tensioner flange.
- Rotate the (B) drive belt tensioner (6B209) in a clockwise motion to release belt tension.
- Raise and support the vehicle. For additional information, refer to Section 100-02 .
- Remove the engine splash shield.
- Remove the drive belt from the accessory drive belt routing pulley (6C348) and then the remaining accessory pulleys.
Installation
- Position the drive belt over the accessory pulleys. Raise and support the vehicle if necessary; refer to Section 100-02 .
- Install the engine splash shield.
- Rotate the drive belt tensioner in a clockwise motion.
- Slip the drive belt under the belt idler pulley (8678) and release the tool. Remove the tool from the drive belt tensioner.
- Accessory Drive-With A/C
- Accessory Drive-Without A/C
Belt -2.0L Zetec
Removal
- Raise the vehicle on a hoist; refer to Section 100-02 .
- Use a 13 mm wrench to rotate the drive belt tensioner (6B209) in a clockwise motion.
- Remove the drive belt (8620).
Installation
- Position the drive belt on all the pulleys and the drive belt tensioner.
Item
Part Number
Description
Generator
19A216
Drive Belt Idler Pulley
3D673
Power Steering Pump Pulley
Water Pump Pulley
5
6B209
Drive Belt Tensioner
6
19703
A/C Compressor
7
6316
Crankshaft
8
19A216
9
8620
Accessory Drive Belt
- Install the drive belt and gently release the drive belt tensioner.
- Run the engine for several minutes to seat the belt into the pulley grooves.
