SOURCE: Hotpoint Ultima WMA61 loud knocking noise in spin cycle
Hello I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. Also another way to check is to move the inner durm up and down to see if there is any play in it..
If you need any further advice then dont hesistate to ask....
SOURCE: not spinning
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
It spins only with the lid closed
For
safety, washing machines are made so that they spin only with the lid
closed. The lid switch prevents the spinning action when the lid is up.
SOURCE: ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
SOURCE: Kenmore 80 series 110 washer making loud noise during final spin
Make sure all springs are still in their place tilt the machine back and look under it and you can see them. 2nd all legs must be level as well as the floor.
SOURCE: Noise when draining
U will find the filter by removing the lower rear panel of the m/c.
Locate the large black hose at the right side, and remove clip securing hose. Get some thing ready to catch any water that will be in there, and remove hose.
There u will see the filter, remove and clean, refit filter and hose,making sure that u get the hose on properly, test for leaks before u put the panel back on.
U will find this much easier to do if u tilt the m/c forward, and support it with something underneath.. Check inside the pump as well.
Plz rate my solution.
Thanks.
